Home » Eclipse Projects » GEF » Multiple nodes as target or source from one connection
Multiple nodes as target or source from one connection [message #241777] Fri, 14 March 2008 08:34 Go to next message
Originally posted by: extra8325.yahoo.co.jp
is it possible that one connection has more than one target or source? I
mean, if a connection model has multiple targets (e.g. as a list), then
the connection branchs out on about its middle point to the multiple
targets. And inverse direction, too. I've serached information in
internet but I couldn't find out any... If it is possible, how can I do
it? I would be very grateful for any suggestions. Thank you.
Tomoko
Re: Multiple nodes as target or source from one connection [message #241794 is a reply to message #241777] Sat, 15 March 2008 10:08 Go to previous messageGo to next message
The simplest way is NO, which is confict with the framework design.
But maybe there are 2 ways to do this:
1, Customize an anchor for multi target figures.
2, Customize a router for connection branches.
Qinxian
Tomoko Kitamura 写道:
> Hello,
> Best regards,
> Tomoko
Re: Multiple nodes as target or source from one connection [message #241798 is a reply to message #241794] Mon, 17 March 2008 06:35 Go to previous messageGo to next message
Thank you for your response Qinxian,
ach, it conflicts with the framework design... Even though I've supposed
it but it's sadly. :(
The two way sound difficult for me ... but, I'll try it.
Do you think that connections can have multiple sources/targets and
reflect it on its figure with customized anchor or router? Maybe in
createFigure() in Connection EditPart...? If you have an idea, I would be
very grateful for your suggestion. Thank you.
Tomoko
Qinxian wrote:
> Cheers,
> Qinxian
> Tomoko Kitamura 写道:
>> Hello,
>> Best regards,
>> Tomoko
Re: Multiple nodes as target or source from one connection [message #241811 is a reply to message #241798] Mon, 17 March 2008 15:04 Go to previous messageGo to next message
Originally posted by: shady_86.sify.com
i have one more crude idea is that you can use a sort of invisible editpart where your branching will take place.
the logic will be like when you will be connecting with a list an invisible edit part will be made which will act as a target for the main connection and for the several splits it will act as a source, in this way you will be able to move your point where the branching will take place, or can make it static using the edit policy for that edit part..,
Re: Multiple nodes as target or source from one connection [message #241822 is a reply to message #241798] Tue, 18 March 2008 11:32 Go to previous messageGo to next message
I speak too fast:)
Sorry, "Customize an anchor" is not an option.
IMO, bendpoint policy and manual router can be applied in your senario.
When move bendpont to multi-targets, the code must attrack the point
like behavior of anchor with endpoint.
So a target/source part be a bendpoint.
If no click interaction, this can be done in part automatically.
If you can accept, an invisible part maybe another option which stated
by sharad.
Qinxian
Tomoko Kitamura 写道:
> be very grateful for your suggestion. Thank you.
> Best regards,
> Tomoko
> Qinxian wrote:
>> Hi,
>> Cheers,
>> Qinxian
>> Tomoko Kitamura ��:
>>> Hello,
>>> source? I mean, if a connection model has multiple targets (e.g. as a
>>> list), then the connection branchs out on about its middle point to
>>> the multiple targets. And inverse direction, too. I've serached
>>> information in internet but I couldn't find out any... If it is
>>> possible, how can I do it? I would be very grateful for any
>>> Best regards,
>>> Tomoko
Re: Multiple nodes as target or source from one connection [message #241887 is a reply to message #241822] Mon, 24 March 2008 07:00 Go to previous messageGo to next message
Hallo,
Thank you for all your suggestions, Qinxian and Sharad, and sorry for my late response.
Qinxian, sadly I can understand not all of your idea, because I don't know the behavior of anchor.. Do you mean, I should write a subclass of BendPointEditPolicy with own getCreateBendpointCommand method? But I don't know how I can connect Bendpoints and a real node programatically. Can I use a Bendpoint like invisible node and make it one of nodes without figure?(then it is nearly to the idea of sharad..?) I need more information about how to create connections between bendpoint/invisible nodes and real nodes. I must also ask how I can generally create connection without click action...(maybe in another thread, because it is an another thing).
Sorry, that I ask so much, but it is very difficult for me.
If you can give me more suggestions, I would be very glad and grateful... Thank you.
Tomoko
Qinxian wrote:
> I speak too fast:)
> by sharad.
> Regards,
> Qinxian
> Tomoko Kitamura 写道:
>> supposed it but it's sadly. :(
>> Best regards,
>> Tomoko
>> Qinxian wrote:
>>> Hi,
>>> Cheers,
>>> Qinxian
>>> Tomoko Kitamura ��:
>>>> Hello,
>>>> a list), then the connection branchs out on about its middle point
>>>> to the multiple targets. And inverse direction, too. I've serached
>>>> Best regards,
>>>> Tomoko
Re: Multiple nodes as target or source from one connection [message #242360 is a reply to message #241887] Sun, 13 April 2008 21:48 Go to previous message
Times not read the news.
Your proplem solved?
If that continued, Maybe you can mail to my mailbox, feel free.
I use the thunderbird read news, Maybe I should pick up my news reader
years ago:)
Qinxian
Tomoko Kitamura 写道:
> Hallo,
> late response.
> Best regards,
> Tomoko
> Qinxian wrote:
>> Hi,
>> I speak too fast:)
>> by sharad.
>> Regards,
>> Qinxian
>> Tomoko Kitamura 写道:
>>> would be very grateful for your suggestion. Thank you.
>>> Best regards,
>>> Tomoko
>>> Qinxian wrote:
>>>> Hi,
>>>> Cheers,
>>>> Qinxian
>>>> Tomoko Kitamura ��:
>>>>> Hello,
>>>>> Best regards,
>>>>> Tomoko
Previous Topic:Memento returning null
Next Topic:GEF as GUI engine ?
Current Time: Fri Jul 25 19:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.05840 seconds
