Home » Eclipse Projects » GEF » Open a new shape editor instance
Open a new shape editor instance [message #241683] Tue, 04 March 2008 04:32 Go to next message
Originally posted by: s.luedigk.de
I'am currently using the shapes example and try to extend it. My goal is
to open a new editor tab by double-click on a shape.
I have included into the ShapeEditPart the following code:
public void performRequest(Request req) {
if (req.getType().equals(RequestConstants.REQ_OPEN)) {
System.out.println("double-click in a shape");
ShapesEditor se = new ShapesEditor();
The double-click is already catched.
But ... how can I open a new ShapesEditor tab in the eclipse workbench?
The input should be another *.shapes file.
Sebastian
Re: Open a new shape editor instance [message #241704 is a reply to message #241683] Wed, 05 March 2008 07:17 Go to previous messageGo to next message
Originally posted by: shady_86.sify.com
try using the openEditor method?..,
Re: Open a new shape editor instance [message #771481 is a reply to message #241704] Tue, 27 December 2011 06:24 Go to previous messageGo to next message
Me too need the above concept, have you opened new editor by the double click event in the shape. If so kindly help me in the same.
Thanks & Regards,
Karthikeyan.B
Re: Open a new shape editor instance [message #774565 is a reply to message #771481] Wed, 04 January 2012 02:36 Go to previous message
Kindly go through the below link, then you will get an idea
http://www.vogella.de/articles/EclipseEditors/article.html
of creating new editor using plugin.xml
(or)
Go through the book Eclipse Plugin of Eric Clayberg, Dan Rubel, Chapter-20
In that chapter it has provided of opening editor using IEditorInput which is the best way.
Thanks & Regards,
Karthikeyan.B
[Updated on: Tue, 10 January 2012 02:15] by Moderator
Previous Topic:Custom layers
Next Topic:Eclipse does not close until GEF editor is closed
Current Time: Mon Nov 10 16:15:25 EST 2025
Powered by FUDForum. Page generated in 0.05523 seconds
