Home » Eclipse Projects » GEF » Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.eclip
Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.eclip [message #241405] Sun, 10 February 2008 06:40 Go to next message
Originally posted by: freelancer.armin.googlemail.com
Well,
I've found the problem in the createImage(String name) method of
org.eclipse.gef.examples.shapes.model.Shape class.
The new Image(null,stream) statement throws a null pointer exception, if
the image does not exists!
The workaround or fix is to encapsulate it with a try/catch.
protected static Image createImage(String name) {
Image image=null;
try{
InputStream stream = ShapesPlugin.class.getResourceAsStream(name);
image = new Image(null, stream);
try {
stream.close();
} catch (IOException ioe) {
catch(Exception e){
e.printStackTrace();
return image;
Im getting the following exception, when I click the Ellipse and move
into the graph viewer each time when i move the mouse into the viewer:
Unhandled event loop exception
org.eclipse.gef.examples.shapes.model.EllipticalShape
at sun.reflect.GeneratedConstructorAccessor7.newInstance(Unknow n Source)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at
org.eclipse.gef.requests.SimpleFactory.getNewObject(SimpleFa ctory.java:39)
at
org.eclipse.gef.requests.CreateRequest.getNewObject(CreateRe quest.java:73)
at
org.eclipse.gef.examples.shapes.parts.DiagramEditPart$Shapes XYLayoutEditPolicy.getCreateCommand(DiagramEditPart.java:167 )
at
org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(Lay outEditPolicy.java:199)
at
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.get Command(ConstrainedLayoutEditPolicy.java:154)
at
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:473)
at org.eclipse.gef.tools.TargetingTool.getCommand(TargetingTool .java:122)
at org.eclipse.gef.tools.CreationTool.handleMove(CreationTool.j ava:239)
at org.eclipse.gef.tools.AbstractTool.mouseMove(AbstractTool.ja va:1038)
at org.eclipse.gef.EditDomain.mouseMove(EditDomain.java:248)
at
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Moved(DomainEventDispatcher.java:359)
at
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove( LightweightSystem.java:533)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:198)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Im using
gef 3.2.101v20070814
eclipse 3.3.1 Build id: M20070921-1145
Any ideas?
Thx
Re: Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.e [message #241435 is a reply to message #241405] Mon, 11 February 2008 10:52 Go to previous messageGo to next message
Hi Armin
Why would the icons be missing in the examples? What are you testing?
Cheers...
Anthony
"Armin" <freelancer.armin@googlemail.com> wrote in message
news:fomnso$ef6$1@build.eclipse.org...
> Well,
> Image image=null;
> try{
> try {
> stream.close();
> catch(Exception e){
> return image;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Im using
> Any ideas?
> Thx
Re: Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.e [message #241440 is a reply to message #241435] Mon, 11 February 2008 19:47 Go to previous messageGo to next message
Hi Anthony
i tried to compile the source code and run the gef shapes example. I
started with a blank plugin project to learn it from the base.
I added the icons in the build properties of the plugin. The icons
directory in the eclipse plugin development workspace contains the icon
files.
I dont know why eclipse do not find the icons in the plugin debug
workspace.
Cheers
Anthony Hunter schrieb:
> Hi Armin
> Cheers...
> Anthony
>> Well,
>> Image image=null;
>> try{
>> try {
>> stream.close();
>> catch(Exception e){
>> return image;
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Im using
>> Any ideas?
>> Thx
Re: Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.e [message #1841064 is a reply to message #241440] Sun, 02 May 2021 16:41 Go to previous message
Hi, you can try to discuss with a freelancer from we are hiring
[Updated on: Tue, 04 May 2021 01:05] by Moderator
Previous Topic:GEF5 FX: Using Connection
Next Topic:Group/ungroup elements
Current Time: Sun Jul 27 22:20:50 EDT 2025
Powered by FUDForum. Page generated in 0.14634 seconds
