Home » Archived » Test and Performance Tools Platform (TPTP) » finding a memory leak
finding a memory leak [message #24108] Mon, 01 August 2005 14:19 Go to next message
I am using TPTP 4.0.0 to try and find a memory leak which shows up after
a long time of running tests.
I can see one class of object that has more than the number of expected
instances, but I can't find out how to get the stack trace of where
these instances are allocated (or at least which objects point to these
instances).
I looked at the documentation that is around and see that enabling
instance level object collection should show at least some of this
information. I have tried to do that, but the number of references and
details columns in the object references view are consistently blank,
and each line of object reference never has subordinate objects.
Is there something I am missing?
Francis
Re: finding a memory leak [message #24144 is a reply to message #24108] Tue, 02 August 2005 02:32 Go to previous messageGo to next message
I figured out how to get the object references; apparently you have to
do this while the test is running. Is this the only way to do this?
Can it be set up to automatically collect the references?
Is there a way to get a stack trace associated with the references (like
what hat can do?).
Francis
Francis Upton wrote:
> instances).
> Francis
Re: finding a memory leak [message #24335 is a reply to message #24144] Tue, 02 August 2005 11:43 Go to previous messageGo to next message
Hi Francis,
Yes, Object reference information can be collected while your application
under profile is live running, via 'Collect Object Reference' action in
Profile Monitor View action toolbar or under context menu of Process in the
Monitor View. These are the only way to collect object reference
information, and there is no automatic object reference collection support
in TPTP.
After you perform a collect object reference action, please refresh the
Object Reference view to show the most updated information. Please note that
Object Reference view can shown either 'Reference To' or 'Reference By'
orientation, via the drop down button of the view toolbar.
Hope this help.
Eugene
"Francis Upton" <francisu@ieee.org> wrote in message
news:dcn41c$n8m$1@news.eclipse.org...
> what hat can do?).
> Francis
> > Hi,
> > instances).
> > Thanks,
> > Francis
Re: finding a memory leak [message #26211 is a reply to message #24335] Thu, 11 August 2005 17:10 Go to previous messageGo to next message
Originally posted by: dawood.us.ibm.com
So, this seems to imply that you only get a snapshot of the references
sometime around the time you push the button. Is this correct, or does
this button somehow cause reference reporting to continue from that
point on?
Eugene Chan wrote:
> Hi Francis,
> in TPTP.
> Hope this help.
> Eugene
>> what hat can do?).
>>Thanks,
>>Francis
>>>Hi,
>>>instances).
>>>Thanks,
>>>Francis
Re: finding a memory leak [message #26333 is a reply to message #26211] Fri, 12 August 2005 11:24 Go to previous message
Hi.
Yes. It is a snapshot of the object reference at the moment you ask to
collect the information. It does not do continuous collection of object
reference information.
"David Wood" <dawood@us.ibm.com> wrote in message
news:ddget2$ga8$1@news.eclipse.org...
> point on?
> Eugene Chan wrote:
> > Hi Francis,
application
the
support
> > in TPTP.
that
> > Hope this help.
> > Eugene
> >> what hat can do?).
> >>Thanks,
> >>Francis
> >>>Hi,
after
> >>>instances).
> >>>Thanks,
> >>>Francis
Previous Topic:Sample HyadesLoggingLog4JSample
Next Topic:Hyades URL Test option missing
Current Time: Wed Sep 03 05:32:12 EDT 2025
Powered by FUDForum. Page generated in 0.07111 seconds
