| DND from TreeViewer to GMF generated editor [message #240904] |
Wed, 23 January 2008 06:28  |
Originally posted by: amsurana.in.ibm.com
This is a multipart message in MIME format.
--=_alternative 003EA7AF652573D9_=
Content-Type: text/plain; charset="US-ASCII"
I am writing an application using EMF & GMF.
GMF in its generated code creates an editor that extends
DiagramDocumentEditor. The palette has a tool "Person Details". This tool
lets u create a Node with a Person Name.
I have a tree viewer that displays Strings of Text with UserNames.
My Doubt:
When i drag a particular Tree item (User Name) from the TreeViewer on to
the Editor, a diagram Node (person Details Node) must be created with the
Username in the Name field of that node.
Can anyone help me figure out
1. How to provide Drop support to the editor. Or should I provide Drop
support to the Container.
2. What kind of transfer takes place ? TextTransfer, FileTransfer, etc...
2. When drop is performed what statements should be written that help in
creating new Node. ( I mean what are classes to be called to create the
node)
I am using GMF v 2.0.1 on Eclipse Europa 3.3
Amit
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi, </font>
<br><font size=2 face="sans-serif">I am writing an application using EMF
& GMF. </font>
<br><font size=2 face="sans-serif">GMF in its generated code creates an
editor that extends </font><font size=2 face="Courier New">DiagramDocumentEditor</font><font size=2 face="sans-serif">.
The palette has a tool "Person Details". This tool lets
u create a Node with a Person Name.</font>
<br><font size=2 face="sans-serif">I have a tree viewer that displays Strings
of Text with UserNames. </font>
<br>
<br>
<br>
<br><font size=2 face="sans-serif">My Doubt: </font>
<br>
<br><font size=2 face="sans-serif">When i drag a particular Tree item (User
Name) from the TreeViewer on to the Editor, a diagram Node (person Details
Node) must be created with the Username in the Name field of that
node.</font>
<br>
<br><font size=2 face="sans-serif">Can anyone help me figure out</font>
<br><font size=2 face="sans-serif">1. How to provide Drop support to the
editor. Or should I provide Drop support to the Container. </font>
<br><font size=2 face="sans-serif">2. What kind of transfer takes place
? TextTransfer, FileTransfer, etc... </font>
<br><font size=2 face="sans-serif">2. When drop is performed what statements
should be written that help in creating new Node. ( I mean what are classes
to be called to create the node) </font>
<br>
<br><font size=2 face="sans-serif">I am using GMF v 2.0.1 on Eclipse Europa
3.3</font>
<br>
<br><font size=2 face="sans-serif">Regards </font>
<br><font size=2 face="sans-serif">Amit </font>
--=_alternative 003EA7AF652573D9_=--
| Re: DND from TreeViewer to GMF generated editor [message #240910 is a reply to message #240904] |
Wed, 23 January 2008 06:50   |
--------------000201010601060004050209
Amit,
It sounds like you meant to use the GMF newsgroup, which I've added to
the "to" list of this reply.
amsurana@in.ibm.com wrote:
> tool lets u create a Node with a Person Name.
> My Doubt:
> to the Editor, a diagram Node (person Details Node) must be created
> with the Username in the Name field of that node.
> in creating new Node. ( I mean what are classes to be called to create
> the node)
> Regards
> Amit
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Amit,<br>
<br>
the "to" list of this reply.<br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:amsurana@in.ibm.com">amsurana@in.ibm.com</a> wrote:
<blockquote cite="mid:fn78dj$vqp$1@build.eclipse.org" type="cite"><br>
<font face="sans-serif" size="2">Hi, </font>
<br>
<font face="sans-serif" size="2">I am writing an application using
EMF
& GMF. </font>
<br>
<font face="sans-serif" size="2">GMF in its generated code creates an
editor that extends </font><font face="Courier New" size="2">DiagramDocumentEditor</font><font
face="sans-serif" size="2">.
<br>
<font face="sans-serif" size="2">I have a tree viewer that displays
Strings
<br>
<br>
<br>
<br>
<font face="sans-serif" size="2">My Doubt: </font>
<br>
<br>
<font face="sans-serif" size="2">When i drag a particular Tree item
(User
Details
node.</font>
<br>
<br>
<font face="sans-serif" size="2">Can anyone help me figure out</font>
<br>
<font face="sans-serif" size="2">1. How to provide Drop support to
the
<br>
<font face="sans-serif" size="2">2. What kind of transfer takes place
<br>
<font face="sans-serif" size="2">2. When drop is performed what
statements
classes
<br>
<br>
<font face="sans-serif" size="2">I am using GMF v 2.0.1 on Eclipse
Europa
3.3</font>
<br>
<br>
<font face="sans-serif" size="2">Regards </font>
<br>
<font face="sans-serif" size="2">Amit </font>
</blockquote>
<br>
</body>
</html>
--------------000201010601060004050209--
| Re: DND from TreeViewer to GMF generated editor [message #240920 is a reply to message #240904] |
Wed, 23 January 2008 13:33   |
>>1&2: Subclass AbstractTransferDragSourceListener and add it to the
Viewer. You can just use a custom transfer (extend ByteArrayTransfer) to
transfer the object which is about to be dragged (when drag&drop
happens within the same application).
Example for a custom transfer:
public class CustomTransfer extends ByteArrayTransfer {
// The only instance of CustomTransfer
private static Map<Class<?>, CustomTransfer> INSTANCES = new
HashMap<Class<?>, CustomTransfer>();
private int id;
private String type;
private CustomTransfer(Class<?> clazz) {
type = clazz.toString() + System.currentTimeMillis();
id = registerType(type);
* Returns the only CustomTransfer for given class.
* @param The
* class for which the Transfer object should be returned.
* @return The only instance for given class.
public static CustomTransfer getInstance(Class<?> clazz) {
CustomTransfer transfer = INSTANCES.get(clazz);
// if there is no transfer type yet, create one
if (transfer == null) {
transfer = new CustomTransfer(clazz);
INSTANCES.put(clazz, transfer);
return transfer;
protected int[] getTypeIds() {
return new int[] { id };
protected String[] getTypeNames() {
return new String[] { type };
protected void javaToNative(Object object, TransferData transferData) {
try {
// convert object to byte array
ByteArrayOutputStream bytes = new ByteArrayOutputStream(1000);
ObjectOutputStream out = new ObjectOutputStream(bytes);
out.writeObject(object);
super.javaToNative(bytes.toByteArray(), transferData);
} catch (Exception e) {
e.printStackTrace();
@SuppressWarnings("unchecked")//$NON-NLS-1$
protected Object nativeToJava(TransferData transferData) {
byte[] bytes = (byte[]) super.nativeToJava(transferData);
if (bytes == null)
return null;
try {
// convert byte array back to object
ObjectInputStream in = new ObjectInputStream(
new ByteArrayInputStream(bytes));
return in.readObject();
return null;
amsurana@in.ibm.com schrieb:
> My Doubt:
> node)
> Regards
> Amit
| Re: DND from TreeViewer to GMF generated editor [message #240954 is a reply to message #240937] |
Fri, 25 January 2008 02:40  |
--=_alternative 0029C71A652573DB_=
From your explanation i understand that :
--- I should create my own Sub-class, say, DropTargetListener of
AbstractTransferDropTargetListener and attach this listener to Editor's
viewer using following lines
GraphicalViewer viewer = getGraphicalViewer();
viewer.addDropTargetListener(new DropTargetListener(viewer,xfer));
-- Next I shall create a DropEditPolicy sub-classing ContainerEditPolicy
and install it to my Container that will react to the drop being
performed.
Am I right ???
Later on I 'll probably figure out what should i do to create node...
Thanks for the help... :)
<br><font size=2 face="sans-serif">From your explanation i understand that
: </font>
<br>
<br><font size=2 face="sans-serif">--- I should create my own Sub-class,
say, DropTargetListener of </font><tt><font size=2>AbstractTransferDropTargetListener
</font></tt><font size=2 face="sans-serif">and attach this listener to
Editor's viewer using following lines</font><tt><font size=2> </font></tt>
<br><tt><font size=2> </font></tt><font size=2 face="Courier New">GraphicalViewer
viewer = getGraphicalViewer();</font>
<br><font size=2 face="Courier New"> viewer.addDropTargetListener(</font><font size=2 color=#820040 face="Courier New"><b>new</b></font><font size=2 face="Courier New">
DropTargetListener(viewer,xfer));</font>
<br>
<br><font size=2 face="Courier New">-- </font><font size=2 face="sans-serif">Next
I shall create a </font><font size=2 face="Courier New">DropEditPolicy</font><font size=2 face="sans-serif">
sub-classing</font><font size=2 face="Courier New"> ContainerEditPolicy
</font><font size=2 face="sans-serif">and install it to my</font><font size=2 face="Courier New">
Container</font><font size=2 face="sans-serif"> that will react to the
drop being performed. </font>
<br>
<br><font size=2 face="sans-serif">Am I right ??? </font>
<br>
<br><font size=2 face="sans-serif">Later on I 'll probably figure out what
should i do to create node... </font>
<br>
<br><font size=2 face="sans-serif">Thanks for the help... :)</font>
--=_alternative 0029C71A652573DB_=--
FUDForum. Page generated in 0.05202 seconds
