Home » Eclipse Projects » GEF » how to launch a wizard when drag and drop an item from palette ?
how to launch a wizard when drag and drop an item from palette ? [message #240589] Fri, 11 January 2008 03:27 Go to next message
Originally posted by: alexjaquet.gmail.com
I would like to know how can I do to launch a wizard when a user drag
and drop an item from palette to the edit part.
Alexandre
Re: how to launch a wizard when drag and drop an item from palette ? [message #240607 is a reply to message #240589] Fri, 11 January 2008 04:54 Go to previous messageGo to next message
I've tryed to create a class who extends
TemplateTransferDragSourceListener and registered it using
* Creates the PaletteViewerProvider.
* @return PaletteViewerProvider The PaletteViewerProvider
protected PaletteViewerProvider createPaletteViewerProvider() {
return new PaletteViewerProvider(getEditDomain()) {
protected void configurePaletteViewer(PaletteViewer viewer) {
super.configurePaletteViewer(viewer);
// Create a DragSourceListener for this Palette Viewer
// The DropSourceListener is added to the Palette in
// initializeGraphicalViewer()
viewer
.addDragSourceListener(new PaletteTransferDragAndDrop(
viewer));
but dragStart is never called.
What do I've missed ?
Alexandre
Re: how to launch a wizard when drag and drop an item from palette ? [message #240612 is a reply to message #240607] Fri, 11 January 2008 08:50 Go to previous messageGo to next message
I also tryed to initialize the palette viewer like the following
protected final void initializePaletteViewer() {
super.initializePaletteViewer();
getPaletteViewer().addDropTargetListener(new
PaletteTransferDragAndDropListener(getPaletteViewer()));
but doesn't work to
Any idea ?
Re: how to launch a wizard when drag and drop an item from palette ? [message #240768 is a reply to message #240589] Tue, 15 January 2008 10:10 Go to previous messageGo to next message
nobody could help ? I could not find any solution to this problem
Re: how to launch a wizard when drag and drop an item from palette ? [message #240867 is a reply to message #240768] Mon, 21 January 2008 17:13 Go to previous message
Originally posted by: tom.seidel.spiritlink.de
A time ago I've implemented something similar. You could adapt the code
to your requirements, see
http://www.richclient2.eu/2006_10_04/drag-and-drop-from-jfac e-viewer-to-gef-editor/
Tom
Previous Topic:ZoomManager bug?!
Next Topic:Use HTML tag in draw2d tooltip
Current Time: Sun Jul 27 10:07:41 EDT 2025
Powered by FUDForum. Page generated in 0.05025 seconds
