Home » Eclipse Projects » GEF » Zest: Open Constraints for TreeLayout and others?
Zest: Open Constraints for TreeLayout and others? [message #240676] Mon, 14 January 2008 00:17 Go to next message
Sorry to newgroup bomb, but I'm also wondering if there is a way to
override these layouts so that they get set to a preferred size equal
to the 'ideal' layout sans Node Resizing. IOTW, I just want to layout
my tree nodes such that they are all one size and the viewer grows to
whatever size fits that ideal. I've tried all of the LayoutStyle
options and have figured out how to give it some arbitrary size by
overriding preLayoutAlgorithm. I suppose I can calculate the expected
max x and y nodes and simply set size by an appropriate multiple but
I'm wondering if there is a more elegant way.
Re: Zest: Open Constraints for TreeLayout and others? [message #240731 is a reply to message #240676] Tue, 15 January 2008 00:16 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Can you please open a bug for this and I will see what I can do.
(open it in GEF under the GEF component)
Just so I understand, you don't mind if your canvas grows, the node
sizes are what's important.
cheers,
ian
> override these layouts so that they get set to a preferred size equal to
> the 'ideal' layout sans Node Resizing. IOTW, I just want to layout my
> whatever size fits that ideal. I've tried all of the LayoutStyle options
> and have figured out how to give it some arbitrary size by overriding
> preLayoutAlgorithm. I suppose I can calculate the expected max x and y
> nodes and simply set size by an appropriate multiple but I'm wondering
Re: Zest: Open Constraints for TreeLayout and others? [message #240980 is a reply to message #240731] Sat, 26 January 2008 21:14 Go to previous messageGo to next message
Exactly, and will do.
> cheers,
> ian
Re: Zest: Open Constraints for TreeLayout and others? [message #241173 is a reply to message #240980] Fri, 01 February 2008 01:18 Go to previous message
Oh, and not just the node sizes, but the relative spacing between nodes
(in the minimal distance case).
>> cheers,
>> ian
Previous Topic:Graph Layouter: Edge.setPoints not visible
Next Topic:In draw2d, how do you align text about a point?
Current Time: Fri Jul 18 09:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.03288 seconds
