Home » Newcomers » Newcomers » Incompatible JVM
Incompatible JVM [message #240461] Mon, 12 November 2007 17:24 Go to next message
Originally posted by: flaflashr.yahoo.com
I already searched the FAQ and this topic is not covered. I am well
experienced in Linux, but not in Eclipse nor Java nor development
platforms.
My system is a Dell Latitude notebook running Kubuntu 7.1 Gutsy Gibbon
I installed eclipse-java-europa-fall2-linux-gtk.tar.gz into
/usr/local/eclipse/. I had previously installed
jdk-1_5_0_13-linux-i586.bin.
I have set $JAVA_HOME to /usr/local/jdk1.5.0_13 where I installed it.
When I try to start Eclipse, I get an error "Incompatible JVM - Version
1.4.2-02 of the JVM is not suitable for this product. Version 1.5 or
greater is required".
Where do I set this.
My next question is likely to be "how do I configure Apache-Tomcat so that
Eclipse invokes it?"
Jim
Re: Incompatible JVM [message #240472 is a reply to message #240461] Mon, 12 November 2007 17:48 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
Can you try passing -vm to Eclipse?
../eclipse -vm <location of 1.5 vm>
~ Chris
Re: Incompatible JVM [message #240476 is a reply to message #240461] Mon, 12 November 2007 18:33 Go to previous message
> platforms.
As Chris A. noted, you can specify the JVM in the command that starts
Eclipse.
If you want to make the Sun JVM your default JVM (I did), you might try
sudo update-alternatives --config java
(and pick the Sun JVM). After I did that, I was able to start Eclipse
with just 'eclipse' and get the right JVM. There's a HOWTO at
http://ubuntuforums.org/showthread.php?t=76702.
/Paul
Previous Topic:Java project: linked source vs NTFS junction
Next Topic:cannot deploy with eclipse, auth cancel
Current Time: Thu Jul 24 21:29:37 EDT 2025
Powered by FUDForum. Page generated in 0.27988 seconds
