Home » Eclipse Projects » GEF » Zest Graph nodes - vertically align Text and Image on node Label
Zest Graph nodes - vertically align Text and Image on node Label [message #240453] Mon, 07 January 2008 06:11 Go to next message
Hi!
I have a graph and i want the name to appear on top to the image for each node. i see that internally you are using cacheLabel and such a flag is possible there but i have no way of reaching these "labels" or "GraphNodes" during their creation. any ideas?
Michelle
Re: Zest Graph nodes - vertically align Text and Image on node Label [message #240572 is a reply to message #240453] Fri, 11 January 2008 00:16 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
I have actually written a CGraphNode (Custom Graph Node) which can be
extended so you can use your own figure.
The code is mostly written, but I want to build a small example before I
submit it (to test the API). I have just opened a bug report so you can
follow this, and I will update the bug when I get the code checked in.
ok I lied, the bug server seems to be down right now. I will add the
bug report tomorrow and put the link here.
cheers,
ian
Michelle Tadmor wrote:
> Hi!
> Cheers,
> Michelle
[zest] Re: Zest Graph nodes - vertically align Text and Image on node Label [message #240632 is a reply to message #240572] Fri, 11 January 2008 20:58 Go to previous message
Here is the bug report:
215040: Add custom graph items
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215040
> cheers,
> ian
>> Hi!
>> Cheers, Michelle
Previous Topic:Forcing graphical events
Next Topic:Zest: How to style connections? Compartments?
Current Time: Sat Jul 26 08:41:11 EDT 2025
Powered by FUDForum. Page generated in 0.04335 seconds
