Home » Eclipse Projects » Eclipse Platform » How do I wipe the registry
How do I wipe the registry [message #240215] Tue, 11 May 2004 06:01 Go to next message
Is there a way to tell Eclipse to wipe the "./configuration/.registry"
file clean ? Eclipse damages this file during the update process and I
would like to wipe it to be able to restart the workbench smoothly.
Henning Rogge
Re: How do I wipe the registry [message #240243 is a reply to message #240215] Tue, 11 May 2004 07:42 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
This is surprising. It has probably been fixed in the later version of
eclipse. Anyway you probably want to start with -clean.
PaScaL
> Henning Rogge
Re: How do I wipe the registry [message #240355 is a reply to message #240243] Tue, 11 May 2004 09:53 Go to previous message
> PaScaL
I'm working with Eclipse 3M8... and I was searching an API to wipe the
registry ( because the error in the registry prevents a smooth web
update of my RCP ). I "solved" the problem by adding a cleanup routine
in the "Startup.jar" loader, but this doesn't seem to be a clean sollution.
Henning Rogge.
Previous Topic:Feature Export: integration build
Next Topic:How to access action object from API?
Current Time: Fri Sep 26 15:39:39 EDT 2025
Powered by FUDForum. Page generated in 0.24242 seconds
