eclipse 3.3.1 out of memory [message #239832] |
Tue, 06 November 2007 05:48  |
Originally posted by: hicham.dev.menara.ma
hello
using eclipse 3.3.1 updated with europa discovery site, and running
for now small java class, it crashes
using 1 gig of ram, do i need more ?
..log says :
!ENTRY org.eclipse.core.jobs 4 2 2007-11-06 10:18:16.253
!MESSAGE An internal error occurred during: "Periodic workspace save.".
!STACK 0
java.lang.OutOfMemoryError: PermGen space
!SESSION 2007-11-06 10:32:35.202
eclipse.buildId=M20070921-1145
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.core.resources 2 10035 2007-11-06 10:32:40.018
!MESSAGE The workspace exited with unsaved changes in the previous
session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jst.jsp.core 4 4 2007-11-06 10:32:52.189
!MESSAGE A workspace crash was detected. The previous session did not
exit normally. Not using saved taglib indexes
!ENTRY org.eclipse.core.jobs 4 2 2007-11-06 10:37:42.821
!STACK 0
at
org.eclipse.jdt.internal.core.JavaModelManager.saveVariables AndContainers(JavaModelManager.java:3237)
at
org.eclipse.jdt.internal.core.JavaModelManager.saving(JavaMo delManager.java:3549)
at
org.eclipse.core.internal.resources.SaveManager.executeLifec ycle(SaveManager.java:343)
at
org.eclipse.core.internal.resources.SaveManager$1.run(SaveMa nager.java:160)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.core.internal.resources.SaveManager.broadcastLif ecycle(SaveManager.java:163)
at
org.eclipse.core.internal.resources.SaveManager.save(SaveMan ager.java:982)
at
org.eclipse.core.internal.resources.DelayedSnapshotJob.run(D elayedSnapshotJob.java:44)
thanks for taking time to reply
hicham
Re: eclipse 3.3.1 out of memory [message #239925 is a reply to message #239919] |
Tue, 06 November 2007 11:45  |
Originally posted by: wharley.bea.com
"hicham" <hicham.dev@menara.ma> wrote in message
news:fgq46c$qvq$1@build.eclipse.org...
> Ed Merks wrote:
>> I've seen a few posts about crashes with the Sun 6.0 JDK. Is this crash
>> you mention an actual JVM crash or more permgen issues. If the latter,
>> have you tried to increase the amount allocated to the permgen space?
> the log talks about PermGen space, how do i increase permgen space ?
> eclispe runs with -vmargs -Xmx512M
The bug report that Ed pointed you to says how to set the permgen space. It
is a very long bug report, but nonetheless, if you are still running into
permgen problems with Eclipse 3.3.1.1 (notice that last .1 - this is
different than 3.3.1) it is worth taking the time to read it closely and
perhaps add a comment in the bug report.
FUDForum. Page generated in 0.09201 seconds
