Home » Archived » Maven Integration (M2E) » M2Eclipse & Multiple JVMs
M2Eclipse & Multiple JVMs [message #23856] Wed, 25 March 2009 10:17 Go to next message
I 'm currently working with multi-module Maven managed application
intended to be compiled and operate with Java 1.4. However, some modules
generate Java code from application model and require Java 1.5 (at least)
to build the artefacts, mainly additional Java source. All modules can be
successfully build by Maven from the command line assuning that required
JVMs are installed.
The problems started when I tried to perform the same tasks within Eclipse
using m2eclipse plugin. The configuration I'm using consists of:
- Windows XP operating system
- Eclipse 3.4.0.v20080522
- Subclipse plugin 1.4.8 from tigris.org
- Maven integration for Eclipse 0.9.7.200902090947
- Maven2 version 2.0.7
- Java JDK 1.6.0_12 for Eclipse
- Java JDK 1.4.2_16 for application - this is configured as default for
Eclipse instance used by the application.
- Subversion 1.5.4 for code repository
What I would like to achieve is a complete clean build of the modules
within Eclipse during initial checkout of the projects from the code
repository. Unfortunately, the modules that require the JDK alternative to
default JDK fail during "Check out as Maven Project" operation from
Subversion Repository Exploring perspective. The failed project can be
successfully re-built after initial import by additional run of the Maven
build configuration where proper settings for JVM are set.
My understanding is that all Maven builds are controlled through
M2Eclipse. At the moment I can select maven profiles that wil be made
active during project checkout. So, the questions are:
1. Is it possible to specify required JVM for build in the module' pom,
e.g. specific profile or properies that can be used for maven execution?
2. If answer to Q1 is negative, then is there a maven2 plugin that will
execute another maven plugin in a separate process and will allow to
select JVM for the execution and specify the relevant parameters?
Thanks in advance - your help and suggestions will be very appreciated
Nick Sorokin
Re: M2Eclipse & Multiple JVMs [message #23898 is a reply to message #23856] Wed, 25 March 2009 11:40 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
To make sure I understand the problem correctly.
1. All your code, both handwritten and generated, compiles and
presumably runs with java 1.4.
2. Most of your projects can be built with java 1.4.
3. Some of your projects require java 1.5 to run the build.
If this is correct, then you need to run Eclipse with 1.5 JVM, but add
1.4 JVM in "Installed JREs" Eclipse Java preferences. During import, m2e
will set project java compliance level based on maven-compiler-plugin
configuration (which I assume is 1.4). This way m2e will use 1.5 JVM to
run the build but the code will compile and run with Java 1.4.
Igor
Nick Sorokin wrote:
> least) to build the artefacts, mainly additional Java source. All
> modules can be successfully build by Maven from the command line
> assuning that required JVMs are installed.
> Eclipse using m2eclipse plugin. The configuration I'm using consists of:
> to default JDK fail during "Check out as Maven Project" operation from
> Maven build configuration where proper settings for JVM are set.
> Nick Sorokin
Re: M2Eclipse & Multiple JVMs [message #23940 is a reply to message #23898] Wed, 25 March 2009 12:20 Go to previous messageGo to next message
Thanks for quick reply.
Your assumptions are correct, but there is a requirement to use the
alternative JVM to compile the code - it is not only compliance level.
This alternative JVM may come not from Sun but e.g. from IBM. What I would
like to do is to specify at project/module level the required JVM to
run/compile the relevant parts. There also may be additional requirements
for JVM settings that need to be specified on the same basis, e.g.
different values for PermSize, etc
Re: M2Eclipse & Multiple JVMs [message #23977 is a reply to message #23940] Wed, 25 March 2009 12:40 Go to previous messageGo to next message
Several issues here.
First, eclipse will always use built-in java compiler and will always
run this compiler in eclipse jvm. m2e does not have control over this.
Likewise, m2e will always use eclipse jvm when running maven during
eclipse build. Forking separate JVM is not practically feasible.
Each java project has JRE associated with it. Eclipse java compiler will
use libraries from that JRE during compilation. It is not currently
possible to tell m2e which JVM it should use. In fact, m2e configures
project classpath in such a way that you won't be able to use IBM (or
SUN) specific classes. Please submit enhancement request to m2e JIRA [1]
or add your comments to related MNGECLIPSE-1218, if you would like to
see this configurable.
You can select different JRE when running java applications or tests
from Eclipse. You can also specify JVM arguments for each launch
configuration.
[1] https://issues.sonatype.org/browse/MNGECLIPSE
Igor
> would like to do is to specify at project/module level the required JVM
> to run/compile the relevant parts. There also may be additional
> requirements for JVM settings that need to be specified on the same
> basis, e.g. different values for PermSize, etc
> Regards
Re: M2Eclipse & Multiple JVMs [message #24014 is a reply to message #23977] Wed, 25 March 2009 13:03 Go to previous messageGo to next message
Thanks again.
With your reply in mind, how m2e will process the following definition in
the pom:
<project>
<build>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<verbose>true</verbose>
<fork>true</fork>
<executable><!-- path-to-javac --></executable>
<compilerVersion>1.3</compilerVersion>
</configuration>
</plugin>
</plugins>
</build>
</project>
where required compiler can be specified? Will it fork to call the
compiler and what JVM will be used for that call?
My regards
Re: M2Eclipse & Multiple JVMs [message #24046 is a reply to message #24014] Wed, 25 March 2009 13:25 Go to previous messageGo to next message
m2e does not (and cannot) use external java compiler, so it will just
ignore these configuration parameters. m2 only considers source/target
maven-compiler-plugin parameters.
Igor
Nick Sorokin wrote:
> Thanks again.
> in the pom:
> <project>
> <build>
> <plugins>
> <plugin>
> <configuration>
> <fork>true</fork>
> </configuration>
> </plugin>
> </plugins>
> </build>
> </project>
> My regards
Re: M2Eclipse & Multiple JVMs [message #24075 is a reply to message #24046] Wed, 25 March 2009 23:49 Go to previous message
One thing worth to mention that this only applies to "the development
mode" when m2eclipse is configuring Eclipse tools such as JDT, AJDT and
WTP according to the configuration from pom.xml. This is how you
normally code and debug your application, run unit tests (with Run as...
/ JUnit test) or run on web app server (Run as... / Server app).
However if you use Run as... / Maven build..., or create corresponding
launch config from the Run/Debug menu, then you can select JVM that is
used to launch Maven and all your compiler configuration will be
respected in the same way it is respected in the command line.
regards,
Eugene
> Regards,
> Igor
> Nick Sorokin wrote:
>> Thanks again.
>> definition in the pom:
>> <project>
>> <build>
>> <plugins>
>> <plugin>
>> <configuration>
>> <fork>true</fork>
>> </configuration>
>> </plugin>
>> </plugins>
>> </build>
>> </project>
>> My regards
Previous Topic:Installing M2E Source & Development Environment
Next Topic:Add Dependecy?
Current Time: Sun Oct 26 06:29:43 EDT 2025
Powered by FUDForum. Page generated in 0.36642 seconds
