| NPE in CreateLaunchConfigurationAction#performAction [message #239376] |
Tue, 02 January 2007 01:29 |
I'm trying to port Eclipse 3.2 to HP-UX IA-64. When I run the resulting
eclipse binary, I get the trace as attached below, if I double click on
Eclipse Application or any of the other options. So I'm unable to create a
new configuration for running or debugging.
Any hints for resolving the problem will be most welcome.
Virender.
!SESSION 2007-01-02 11:14:44.107
eclipse.buildId=M20060629-1905
java.version=1.5.0.04
java.vendor=Hewlett-Packard Co.
BootLoader constants: OS=hpux, ARCH=ia64, WS=gtk, NL=en Command-line
arguments: -os hpux -ws gtk -arch ia64
!ENTRY org.eclipse.jface 4 2 2007-01-02 11:16:09.028 !MESSAGE Problems
occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at
org.eclipse.debug.internal.ui.launchConfigurations.CreateLau nchConfigurationAction.performAction(CreateLaunchConfigurati onAction.java:66)
at
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction$1.run(AbstractLaunchConfigurationAc tion.java:103)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction.run(AbstractLaunchConfigurationActi on.java:106)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$2.run(LaunchConfigurationsDialog.java:526)
at
org.eclipse.debug.ui.AbstractDebugView.doubleClick(AbstractD ebugView.java:729)
at
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:796)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:794)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1216)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1158)
at
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:223)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:220)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:281)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3184)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2860)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1086)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:37 5)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:379)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:321)
at
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:99)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
FUDForum. Page generated in 0.05280 seconds
