| [ATL] Multiple Input Models Issue [message #23664] |
Fri, 16 March 2007 11:38   |
Eclipse User  |
My ATL transform takes in a number of input models (WSDL interfaces) and
produces one output model (UML Class Diagram). The problem is that each
time the root transformation(ProcessToRoot) runs (once for every input
model) it creates a new model in the output UML Class diagram. I want
there to be only one output model with a number of classes in it
representing each input interface. My attempt so far is below..
module XMLtoUML; -- Module Template
create OUT : UML from IN : XML, IN2 : XML;
rule ProcessToRoot{
	from
		r: XML!Root
        --merge the two input models
	using{
			a:Set(XML!Root) =
XML!Root.allInstancesFrom('IN')->union(XML!Root.allInstancesFrom('IN2'));
	to
		rt : UML!Model(
			packagedElement <-
a->collect(e|e.children->select(e|e.name='wsdl:portType')- >collect(e|thisModule.PortTypeToInterface(e)))
lazy rule PortTypeToInterface{
	from
		pt: XML!Element(
			pt.name = 'wsdl:portType'
	to
		inf : UML!Interface(
			name <- pt.children->select(e|e.name='name')->first().value,
			ownedOperation <-
pt.children->select(e|e.name='wsdl:operation')->collect(e|thisModule.OperationToOperation(e))
lazy rule OperationToOperation{
	from
		opx: XML!Element
	to
		opu : UML!Operation(
			name <- opx.children->select(e|e.name='name')->first().value
I have successfully got the 2nd and 3rd rules merging correctly but need
the first rule to only fire once in order to create only one output model.
Any ideas?
Also is there any way to merge all input models without having to
explicitly enumerate them as I have done with the allInstancesFrom method
in a using block?
Ronan
| Re: [ATL] Multiple Input Models Issue [message #23911 is a reply to message #23664] |
Fri, 16 March 2007 13:26    |
Eclipse User  |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
We have implemented a couple of helpers that may answer your first question. We used it to
generate a single primitive type (e.g., String or Integer) to merge two KM3 metamodels.
I adapted them to your example. You can try it to verify if it works. :)
rule ProcessToRoot{
     from
       r: XML!Root (r.isUnique)
       -- the rule
---- the helpers  ------------------------------------------------------------ --
helper context XML!Root def: isUnique : Boolean =
   self.uniqueValue = self;
helper context XML!Root def: key : OclAny =
   self.name;
helper def: rootByKey : Map(OclAny, XML!Root) =
   XML!Root.allInstances()->iterate(e; acc : Map(OclAny, XML!Root) = Map {} |
     acc.including(e.key, e)
helper context XML!Root def: uniqueValue : XML!Root =
   thisModule.rootByKey.get(self.key);
Marcos.
Ronan wrote:
> rule ProcessToRoot{
>     from         r: XML!Root
>     using{
>             a:Set(XML!Root) =
>     to
>         rt : UML!Model(
>             packagedElement <-
>     from         pt: XML!Element(
>     to
>             ownedOperation <-
>     from         opx: XML!Element
>     to
> model. Any ideas?
> method in a using block?
> Cheers,
> Ronan
| Re: [ATL] Multiple Input Models Issue [message #25047 is a reply to message #23911] |
Fri, 23 March 2007 07:40   |
Eclipse User  |
Hi Marcos,
Thanks you for those excellent helpers. I tried them out and they work
perfectly. Using a Map to maintain state is a very elegant solution to my
problem. Previously I had tried to use a counter, but this failed as the
do block for executed only after both models had been transformed.
Thanks again,
Ronan
FUDForum. Page generated in 0.03794 seconds
