| Chart Engine Error on Websphere 6 [message #238842] |
Fri, 18 May 2007 05:25  |
Hi Everybody,
I have an unknow errror about Birt-Viewer
"java.lang.ClassCastException:java.lang.noClassDefFoundError ".
This ploblem happen when I deploy Birt-Viewer on IBM Websphere 6 in
Unix Server.
But on my IBM Websphere in Windows XP Birt-Viewer not show this error and
generate report and chart correctly.
I don't known why this error is happen because in Birt-Viewer 's
log show only process of birt-engine but not show any error.
If anyone have solution or reason for this ploblem such as Unix
config,Birt config,class and jar file or bug of birt (but I'm not sure).
I try to fix this ploblem for many times and I know that this
error occur only for chart report but I still cann't fix this ploblem.Tell
me please if you have a solution.
Thanks you very much,
Sudhlo
| Re: Chart Engine Error on Websphere 6 [message #240047 is a reply to message #238842] |
Mon, 28 May 2007 07:51  |
Hi Everybody,
Now I know the reson for this case. I thinks many birt-user and every
birt-developer must know about this case but not have anyone tell me. Then
I try to use JFreeChart, I think it is very simple, small api, and very
eazy to use with a lot of user to tell you about ploblem and example. I
think JFreeChart is a good way to choose,
Thanks you
FUDForum. Page generated in 0.03826 seconds
