Home » Eclipse Projects » DSDP - Target Management » Extending RSE Shell
Extending RSE Shell [message #23715] Fri, 30 May 2008 08:50 Go to next message
Hi everyone,
I am implementing a new RSE Shell. I have looked the way it has been
done for the SSH Shell.
It is working great, but I am confronted to a problem. I need to send
specific command (through the shell) when the user hit Ctrl-Z, or Esc.
I have looked deeper in the code and found in the CommandsViewPage.java,
that a Listener is added, and is responsible of handling case like mine
(Ctrl-C, etc ...).
Is it planned to handle case like mine in the future ?
Temporarly, I am planning to modify the RSE code (maybe adding an
extension point).
Sebastien Moran
ANYWARE TECHNOLOGIES
Tel : +33 (0)5 61 00 06 63
Fax : +33 (0)5 61 00 51 46
http://www.anyware-tech.com
Re: Extending RSE Shell [message #23801 is a reply to message #23715] Fri, 30 May 2008 10:06 Go to previous messageGo to next message
Hello Sebastien,
have you looked at the new RSE Terminal integration?
It provides ANSI terminal emulation, whereas the classic
RSE Command View is always line-based. Also, the Terminal
always sends character codes directly to the remote, so
if you contribute a Terminal Stream Handler you can
interpret these character codes in any way you need.
The commands view is different in that it is always
line-based. It provides a line editor, in which special
keyboard shortcuts (left,right,home,ctrl+c,ctrl+v) are
LOCALLY used to edit the commandline rather than sending
directly to the remote.
Pick what you need, but in my opinion the RSE Commands
View is not what you need. It's not designed for handling
special keystrokes.
For the Terminal, and special contributed Stream Handlers,
we are still working on an API for such extensions. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224989
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Sébastien Moran wrote:
> Hi everyone,
> (Ctrl-C, etc ...).
> extension point).
> Thanks
> Sebastien Moran
Re: Extending RSE Shell [message #23885 is a reply to message #23801] Mon, 02 June 2008 04:07 Go to previous message
Hello Martin,
Thanks, I'll take a look at it.
Sebastien Moran
Martin Oberhuber a écrit :
> Hello Sebastien,
> special keystrokes.
> Cheers,
>> Hi everyone,
>> CommandsViewPage.java, that a Listener is added, and is responsible of
>> handling case like mine (Ctrl-C, etc ...).
>> extension point).
>> Thanks
>> Sebastien Moran
Re: Extending RSE Shell [message #575126 is a reply to message #23715] Fri, 30 May 2008 10:06 Go to previous message
Hello Sebastien,
special keystrokes.
> Hi everyone,
> (Ctrl-C, etc ...).
> extension point).
> Thanks
> Sebastien Moran
Re: Extending RSE Shell [message #575194 is a reply to message #23801] Mon, 02 June 2008 04:07 Go to previous message
Originally posted by: sebastien.moran.anyware-tech.com
Hello Martin,
Sebastien Moran
> Hello Sebastien,
> special keystrokes.
> Cheers,
>> Hi everyone,
>> extension point).
>> Thanks
>> Sebastien Moran
Previous Topic:Difference between dstore and ssh connection
Next Topic:RXTX terminal connection on solaris
Current Time: Sun Nov 09 08:39:53 EST 2025
Powered by FUDForum. Page generated in 0.03086 seconds
