Home » Eclipse Projects » GEF » Executing code from a non-UI thread and then UI thread
Executing code from a non-UI thread and then UI thread [message #238599] Fri, 21 September 2007 12:39 Go to next message
Originally posted by: malnatij.lu.unisi.ch
Hi, I have some intensive task that basically computes and fills in a set of data structures.
After setting the data up, I need to show a graphical representation in my plug-in view.
The ModelExtractor extends Job and performs the intensive task.
projectScanner = new ModelExtractor(wantedProject);
			System.out.println("ModelExtractor created");
			projectScanner.setPriority(Job.LONG);
			projectScanner.schedule();
			projectScanner.addJobChangeListener(new JobChangeAdapter() {
				public void done(IJobChangeEvent event) {
					if (event.getResult().isOK()){
						System.out.println("ok got");
						ViewFiller filler = new ViewFiller(projectScanner,
								view,
								systemComplexityHandler);
						Display.getCurrent().asyncExec(filler);
After the ModelExtractor terminates, I need to draw the data, therefore I want to run code in the UI-Thread, using Display.getCurrent().asyncExec().
The problem is that after creating the ViewFiller class (that implements Runnable), its run method is not called by the UI-Thread.
Why?
Re: Executing code from a non-UI thread and then UI thread [message #242052 is a reply to message #238599] Sun, 30 March 2008 14:34 Go to previous message
the problem was that Display.getCurrent() returns a null display if this method is called from a non-UI thread, therefore if you need to call it, pass the Display through the cain of calls, from a UI thread to the non-UI one.
ciao :D
Previous Topic:different model for outline view
Next Topic:draw a frame once user is over a figure
Current Time: Sat Jul 26 02:49:54 EDT 2025
Powered by FUDForum. Page generated in 0.06268 seconds
