Home » Archived » BIRT » SEVERE: Message:The extension point [org.eclipse.birt.report.model.reportItemMod
SEVERE: Message:The extension point [org.eclipse.birt.report.model.reportItemMod [message #238281] |
Wed, 16 May 2007 08:56  |
I am running BIRT 2.0.1. All the classes, report design files and property
files are in a jar. When I try to generate a PDF document, I get the
following exception:
org.eclipse.birt.report.model.metadata.ExtensionLoader
logExtenstionException
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
org.eclipse.birt.report.model.parser.ModuleReader readModule
SEVERE: Parsed file was not found.
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file <stream>
I've tried to add the design files with property files in the same package
as the class that invokes the
IReportRunnable design = null;
InputStream is = getClass().getResourceAsStream(reportDesign + "." +
REPORT_DESIGN_EXTENSION);
design = engine.openReportDesign(is);
but I'm getting the same error. Any ideas?
Thank you,
Cristian
Re: Can anyone please help me? [message #238448 is a reply to message #238374] |
Wed, 16 May 2007 16:39  |
I forgot to add this logs to the message:
May 16, 2007 4:17:37 PM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 375 Milliseconds.
May 16, 2007 4:17:38 PM
org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
FINE: return internal name for choice eq
FINE: return internal name for choice asc
FINE: return internal name for choice all
FINE: return internal name for choice hide
FINE: return internal name for choice any
FINE: return internal name for choice if-realized
FINE: return internal name for choice auto
FINE: return internal name for choice hyperlink
FINE: return internal name for choice string
FINE: return internal name for choice static
FINE: return internal name for choice normal
FINE: return internal name for choice none
FINE: return internal name for choice scroll
org.eclipse.birt.report.model.metadata.DimensionPropertyType validateXml
FINE: return dimension value with user defined unit 0%
FINE: return internal name for choice repeat
FINE: return internal name for choice left
FINE: return dimension value with user defined unit 0em
FINE: return internal name for choice block
FINE: return dimension value with user defined unit 0pt
FINE: return dimension value with user defined unit 1in
FINE: return dimension value with user defined unit 1.25in
FINE: return dimension value with user defined unit 0.5pt
FINE: return internal name for choice size-to-image
FINE: return internal name for choice horizontal
FINE: return internal name for choice in
FINE: return internal name for choice html
FINE: return internal name for choice plain
Current Time: Wed Sep 03 15:31:27 EDT 2025
Powered by FUDForum. Page generated in 0.04388 seconds
