Home » Archived » Riena » Create Application model depending on login information
Create Application model depending on login information [message #23776] Mon, 30 March 2009 03:44 Go to next message
I want to create my application model depending on the current users
permissions.
The problem is that IApplicationNode.createModel() is called before login
has been performed.
Is there any possibility to manipulate the displayed model nodes after
login? Or is there any out of the box solution for this?
Thanks and greetz,
Carsten
Re: Create Application model depending on login information [message #23906 is a reply to message #23776] Mon, 30 March 2009 11:52 Go to previous messageGo to next message
Hi Carsten,
you are right in case you use the splash login view (its different for
the login dialog view). The splash login view is brought up when the
workbench is created and that is after createModel() was called. I think
you can use the riena ui filters (see
http://wiki.eclipse.org/Riena_UI_filters) to manipulate the displayed
model nodes based on permissions. Override the createView() method of
your application class (subclass of SwtApplication) like this:
public Object createView(IApplicationContext context, IApplicationNode
pNode) {
Collection<IUIFilterRule> rules = new ArrayList<IUIFilterRule>(1);
// hidden marker for all children of application node
IUIFilterRule filterRule = new UIFilterRuleNavigationHiddenMarker("/"
+ pNode.getNodeId().getTypeId() + "/*") {
public boolean matches(Object... args) {
return super.matches(args) && !getPermission(args);
private boolean getPermission(Object... args) {
boolean permission = true;
if (args[0] instanceof INavigationNode<?>) {
permission = // get permission for node (args[0])
return permission;
rules.add(filterRule);
IUIFilter filter = new UIFilter(rules);
pNode.addFilter(filter);
return super.createView(context, pNode);
Also there is an API method setVisible() in INavigationNode to set the
visibility of a node.
Regards, Frank
Carsten Spieker wrote:
> permissions.
> has been performed.
> Thanks and greetz,
> Carsten
Re: Create Application model depending on login information [message #24021 is a reply to message #23906] Wed, 01 April 2009 03:08 Go to previous messageGo to next message
Hi Frank,
thanks for your reply!
I tried the way you explained via the UIFilter. Unfortunately I have two
problems with this solution:
1) The class UIFilterRuleNavigationHiddenMarker seems to be internal.
2) The UI shows a bad looking gray "placeholder" where the now hidden
navigation node was displayed before until I "click" somewhere in the UI
(maybe this is only a refresh problem?)
Greetz,
Carsten
"Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
news:gqqqia$un0$1@build.eclipse.org...
> Hi Carsten,
> you are right in case you use the splash login view (its different for the
> login dialog view). The splash login view is brought up when the workbench
> is created and that is after createModel() was called. I think you can use
> the riena ui filters (see http://wiki.eclipse.org/Riena_UI_filters) to
> manipulate the displayed model nodes based on permissions. Override the
> createView() method of your application class (subclass of SwtApplication)
> like this:
> @Override
> pNode) {
> IUIFilterRule filterRule = new UIFilterRuleNavigationHiddenMarker("/" +
> @Override
> return permission;
> Regards, Frank
>> Hi,
>> permissions.
>> has been performed.
>> Thanks and greetz,
>> Carsten
Re: Create Application model depending on login information [message #24053 is a reply to message #24021] Wed, 01 April 2009 04:57 Go to previous messageGo to next message
Hi Carsten,
you are right class UIFilterRuleNavigationHiddenMarker is internal and
so should be used only with caution, because this code may undergo
changes. May be you file a bugzilla request which describes your problem
and mentions that class UIFilterRuleNavigationHiddenMarker is internal.
The gray "placeholder" seems to be a refresh problem. Can you file
bugzilla request for that? Is it a submodule your are hiding?
Regards, Frank
> Hi Frank,
> Greetz,
> Carsten
>> Hi Carsten,
>> like this:
>> @Override
>> pNode) {
>> @Override
>> return permission;
>> Regards, Frank
>>> Hi,
>>> permissions.
>>> has been performed.
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #24153 is a reply to message #24053] Wed, 01 April 2009 05:46 Go to previous message
Hi Frank,
I opened Bug report 270735 for this.
Greetz,
Carsten
news:gqvavi$9fi$1@build.eclipse.org...
> Hi Carsten,
> you are right class UIFilterRuleNavigationHiddenMarker is internal and so
> should be used only with caution, because this code may undergo changes.
> May be you file a bugzilla request which describes your problem and
> mentions that class UIFilterRuleNavigationHiddenMarker is internal. The
> gray "placeholder" seems to be a refresh problem. Can you file bugzilla
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> @Override
>>> pNode) {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> login has been performed.
>>>> Thanks and greetz,
>>>> Carsten
Re: Create Application model depending on login information [message #581599 is a reply to message #23776] Mon, 30 March 2009 11:52 Go to previous message
Hi Carsten,
pNode) {
return permission;
Regards, Frank
> permissions.
> has been performed.
> Thanks and greetz,
> Carsten
Re: Create Application model depending on login information [message #581645 is a reply to message #23906] Wed, 01 April 2009 03:08 Go to previous message
Hi Frank,
Greetz,
Carsten
> Hi Carsten,
> like this:
> @Override
> pNode) {
> @Override
> return permission;
> Regards, Frank
>> Hi,
>> permissions.
>> has been performed.
>> Thanks and greetz,
>> Carsten
Re: Create Application model depending on login information [message #581655 is a reply to message #24021] Wed, 01 April 2009 04:57 Go to previous message
Hi Carsten,
Regards, Frank
> Hi Frank,
> Greetz,
> Carsten
>> Hi Carsten,
>> like this:
>> @Override
>> pNode) {
>> @Override
>> return permission;
>> Regards, Frank
>>> Hi,
>>> permissions.
>>> has been performed.
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #581668 is a reply to message #24053] Wed, 01 April 2009 05:46 Go to previous message
Hi Frank,
Greetz,
Carsten
> Hi Carsten,
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> @Override
>>> pNode) {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> Thanks and greetz,
>>>> Carsten
Previous Topic:Authorizarion Service on client side causes problems
Next Topic:Authorizarion Service on client side causes problems
Current Time: Sat Jul 19 01:00:23 EDT 2025
Powered by FUDForum. Page generated in 0.04066 seconds
