Home » Eclipse Projects » GEF » PrintAction with graphicalEditor: Can I manually add page breaks?
PrintAction with graphicalEditor: Can I manually add page breaks? [message #237681] Tue, 07 August 2007 04:04 Go to next message
Hi there,
I've got a graphical editor showing some nodes and connections using
Polygon figures and I have put my own layout to the editor for the nodes
and connections.
I use the retargetable print-Action provided by eclipse
(org.eclipse.ui.actions.ActionFactory.PRINT) to print my diagram.
By now all works fine, except that the page breaks are set as soon as
the page is full without respect to my layout or the nodes themselfs
(they are sometimes cut in half; upper half on page 1, lower half on
page 2).
What I need is that the page beaks are set WITH respect to my layout or
at least that the nodes are not devided into pieces.
1) Is there a way for me to tell the print-process where to set a page
break?
2) Or is ot possible for the print-process to look out for good page
break sites?
I would not mind if the printed diagram would be zoomed a little bit to
fit the pages (as zooming does allready work with my graphical editor)
or to achieve a good layout for page breaks.
3) Or should the layout itself define some possible page breaks so that
the printer can use them?
I'm really stuck here, please help me!
Any help, code snippets or hints on this matter are highly appreciated
Many Thanks in advance,
Alex Haag
Re: PrintAction with graphicalEditor: Can I manually add page breaks? [message #237687 is a reply to message #237681] Tue, 07 August 2007 06:47 Go to previous message
Originally posted by: prasenjit.d.tcs.com
The simplest thing will definitly be applying a zoom to the page. For that
you can create your own print action or extends
org.eclipse.gef.ui.actions.PrintAction. Then extend
org.eclipse.gef.print.PrintGraphicalViewerOperation and overload
getFreshPrinterGraphics() method. You need to calculate the correct zoom
beforehand and inside this method apply this zoom using setScale method of
PrinterGraphics. If you just go through these classes you may find out
other ways to meet your goal.
Previous Topic:Selection handles can not appear
Next Topic:Palette title
Current Time: Fri Jul 18 03:16:56 EDT 2025
Powered by FUDForum. Page generated in 0.06214 seconds
