Home » Eclipse Projects » GEF » What should a paste action derive from? (triggering calculateEnabled())
What should a paste action derive from? (triggering calculateEnabled()) [message #237609] Mon, 06 August 2007 08:04 Go to next message
Platform: eclipse 3.2.2
I've now successfully created a CopyAction that can be used as an
action handler for the retargetable action ActionFactory.COPY. This
action derives from SelectionAction.
I've then created a PasteAction that derives from WorkbenchAction. In
this class the calculateEnabled() method is called when starting up
(then it returns false), but it is not called when the clipboard
contents changes.
So I wonder:
- Should I derive from a different class than WorkbenchAction?
- Is there a way where I can trigger recalculation of enabled state
of all retarget actions?
- Can I notify my current PasteAction somehow when the clipboard
state changes?
Thanx!
- Steinar
Re: What should a paste action derive from? (triggering calculateEnabled()) [message #237629 is a reply to message #237609] Mon, 06 August 2007 09:16 Go to previous messageGo to next message
>>>>> Steinar Bang <sb@dod.no>:
[snip!]
> So I wonder:
[snip!]
I've tried two things in this direction:
1. Setting the lazyEnablementCalculation to false in the paste
action, but this just caused the calculateEnabled() method never
to be called:
http://help.eclipse.org/help32/topic/org.eclipse.gef.doc.isv /reference/api/org/eclipse/gef/ui/actions/WorkbenchPartActio n.html#setLazyEnablementCalculation(boolean)
method looked hopeful.
2. doing the following in the CopyAction#run() method, after calling
ClipBoard#setContents() :
((IEditorSite)getWorkbenchPart().getSite()).getActionBars(). updateActionBars();
But it had no effect on the paste action and I didn't hit the
breakpoint I'd set in PasteAction#calculateEnabled()
Re: What should a paste action derive from? (triggering calculateEnabled()) [message #237635 is a reply to message #237629] Mon, 06 August 2007 09:33 Go to previous message
> [snip!]
>> So I wonder:
> [snip!]
> to be called:
A variant on version 2, actually works, but feels like a hack: what I
put into the CopyAction#run() method after setting the clipboard
contents was the following:
IAction pasteAction = ((IEditorSite)getWorkbenchPart().getSite()).getActionBars(). getGlobalActionHandler(ActionFactory.PASTE.getId());
pasteAction.isEnabled();
Is this a hack? Is there a better way?
Thanx!
Previous Topic:Get the size of my plugin's view
Next Topic:how to tell an editor to refresh
Current Time: Fri Jul 18 02:52:25 EDT 2025
Powered by FUDForum. Page generated in 1.29742 seconds
