Home » Eclipse Projects » DSDP - Target Management » Difference between dstore and ssh connection
Difference between dstore and ssh connection [message #23672] Fri, 30 May 2008 05:15 Go to next message
what is the difference between dstore and ssh connection? What additional
features does the dstore server provide?
Axel
Re: Difference between dstore and ssh connection [message #23760 is a reply to message #23672] Fri, 30 May 2008 09:58 Go to previous messageGo to next message
dstore requires a java-based server to run on the Remote,
whereas ssh requires a (smaller, less resource intensive)
native server, the sshd. This makes ssh an option for
embedded devices as well.
In terms of features, dstore allows
* Remote archive handling (browsing into tar,tgz,zip)
* Remote search (without transferring all files)
* More exact classification of files by type
dstore can be extended by more (Java based) miners to
perform specific advanced remote operations with
minimal network transfer.
ssh is a standards based solution, is available on most
servers out of the box, but provides fewer features.
Does that help?
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Axel Mueller wrote:
> additional features does the dstore server provide?
> Axel
Re: Difference between dstore and ssh connection [message #23844 is a reply to message #23760] Fri, 30 May 2008 10:24 Go to previous message
Thanks for your response.
Axel
> Does that help?
> Cheers,
> Axel Mueller wrote:
>> Hi,
>> Axel
Re: Difference between dstore and ssh connection [message #575109 is a reply to message #23672] Fri, 30 May 2008 09:58 Go to previous message
Does that help?
Axel Mueller wrote:
> Axel
Re: Difference between dstore and ssh connection [message #575145 is a reply to message #23760] Fri, 30 May 2008 10:24 Go to previous message
Axel
> Does that help?
> Cheers,
> Axel Mueller wrote:
>> Hi,
>> Axel
Previous Topic:Extending RSE Shell
Next Topic:Extending RSE Shell
Current Time: Fri Jul 18 20:12:37 EDT 2025
Powered by FUDForum. Page generated in 0.06478 seconds
