Home » Newcomers » Newcomers » Able to create a connection from a new project to an Oracle db
Able to create a connection from a new project to an Oracle db [message #237233] Tue, 09 October 2007 18:52 Go to next message
Originally posted by: subi_peg.yahoo.com
I have the following code in a connect.java file
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
public class Connect {
public static void main(String[] arguments) {
String data = "jdbc:odbc:UUUU04";
try {
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
Connection conn = DriverManager.getConnection(
data, "YYYYYYY", "XXXXXX");
Statement st = conn.createStatement();
ResultSet rec = st.executeQuery(
"SELECT FNM, LNM, MIN, TITLE, MAX_EDU " +
"FROM pep " );
System.out.println("First Name /t Last name/t TITLE /t
User ID " +
"People in PEP file ");
while(rec.next()) {
System.out.println(rec.getString("FNM")+ "\t"
+ rec.getString("LNM")+ "\t"
+ rec.getString("MIN")+ "\t"
+ rec.getString("TITLE")+ "\t"
+ rec.getString("MAX_EDU") );
st.close();
} catch (SQLException s) {
System.out.println("SQL Error: " + s.toString() + " "
+ s.getErrorCode() + " " + s.getSQLState());
} catch (Exception e) {
System.out.println("Error: " + e.toString()
+ e.getMessage());
What I am hoping to do is make this a common connect class
which could them be included in all source files.
Here is what I had in mind
after the changes I had in mind it would look like
String data = "jdbc:odbc:RASID04";
try {
data, "VGI_DEV10S", "vgidev123m");
+ e.getMessage());
SO if I created a test first for an class Pep
the testPep junit test file should look like the below however I am not
able to get it work
package vgio4d10s;
import junit.framework.TestCase;
import vgio4d10s.Connect;
public class testPep extends TestCase {
public void testGetPep(){
/** this would look for the record with the max pep_id then the assert
equals would test
* the value with the value that has been converted to a string only
because it is too long for long
* integer. also a nother assertEquals would test the first name */
Connect();
ResultSet rec = rs.executeQuery("Select * from PEP where pep_id =
(select Max(pep_id)from pep)");
String mPid = rec.getNString("PEP_ID");
String mFnm = rec.getString("FNM");
assertEquals("10000000000000001026", mPid);
*the Connect () <- throws error the method connect is undefined for type
testPep */
If you know of any small example that was created using the TDD
methodology then I could learn from it and not keep bothering you folks
Either way the fact that you are trying to help some one is appreciated
Re: Able to create a connection from a new project to an Oracle db [message #237245 is a reply to message #237233] Tue, 09 October 2007 20:20 Go to previous message
Originally posted by: wegener.cboenospam.com
Subi wrote:
> I have the following code in a connect.java file import
> try {
> "FROM pep " );
> User ID " +
> while(rec.next()) {
> st.close();
> + e.getMessage());
> What I am hoping to do is make this a common connect class which could
> after the changes I had in mind it would look like import
> try {
> + e.getMessage());
> able to get it work
> package vgio4d10s;
> assert equals would test * the value with the value that has
> been converted to a string only because it is too long for long
> Connect();
> = (select Max(pep_id)from pep)");
> testPep */
There are numerous problems with this code. It really looks like you
are struggling with basic Java concepts. You should probably spend some
time learning the Java language first. I would suggest you get some
introductory Java programming books to start with.
These types of questions really aren't appropriate for this news group.
The group is for questions regarding Eclipse and not Java.
Previous Topic:Error on Aptana Plug-in Install
Next Topic:[PDE] disabled activity to remove views
Current Time: Mon Sep 15 10:53:32 EDT 2025
Powered by FUDForum. Page generated in 0.09521 seconds
