Home » Archived » XML Schema Definition (XSD) » Local Cache of Schemas
Local Cache of Schemas [message #23546] Sun, 15 June 2003 19:52 Go to next message
I want to use a local cache for my resources/schemas.
I tried to provide my own URIResolver and looked at the example in the docs.
Everything works fine if I pass back the URI I get (an absolute one with
http://) but if I map the URI to a file:// URI it only loads the outermost
schema and doesn't have any element declarations. I checked the inputstream
generated by URIResolver.createInputStream and it has the correct schema
file in it but the URIResolver is never called for the other schemas
referenced by import or include.
What do I do wrong ? I also tried calling schema.setLocation but it didn't
make any difference.
The xsd file I use is: http://www.w3.org/TR/voicexml20/vxml.xsd
thanx
Jens Lukowski
Re: Local Cache of Schemas [message #23631 is a reply to message #23546] Mon, 16 June 2003 07:23 Go to previous message
--------------EDCAA123E00247A90218C9D5
Content-Type: text/plain; charset=us-ascii
Jens,
If I add this code to XSDMainTest:
412a414,423
> resourceSet.getURIConverter().getURIMap().put
> (URI.createURI("http://www.w3.org/TR/voicexml20/vxml.xsd"),
URI.createURI("file://d:/stuff/vxml.xsd"));
Add this code to URIConverterImpl:
380a381
> System.err.println("open:" + uri + " ->" + converted);
And make sure that the vxml.xsd is present at that file system location, then I
get this trace (when running xsd-test.bat -validate
http://www.w3.org/TR/voicexml20/vxml.xsd):
open:http://www.w3.org/TR/voicexml20/vxml.xsd
->file://d:/stuff/vxml.xsd
open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/MagicXMLSchema.xsd
-> platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org/2001 /MagicXMLSchema.xsd
open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/XMLSchema.xsd
-> platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org/2001 /XMLSchema.xsd
open:http://www.w3.org/2001/xml.xsd
-> platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org/2001 /xml.xsd
open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/XMLSchema-instance.xsd
-> platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org/2001 /XMLSchema-instance.xsd
open:http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd
->http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd
open:http://www.w3.org/TR/voicexml20/vxml-attribs.xsd
->http://www.w3.org/TR/voicexml20/vxml-attribs.xsd
open:http://www.w3.org/TR/voicexml20/vxml-grammar-extension. xsd
->http://www.w3.org/TR/voicexml20/vxml-grammar-extension.xsd
open:http://www.w3.org/TR/voicexml20/vxml-grammar-restrictio n.xsd
-> http://www.w3.org/TR/voicexml20/vxml-grammar-restriction.xsd
open:http://www.w3.org/TR/voicexml20/grammar-core.xsd
->http://www.w3.org/TR/voicexml20/grammar-core.xsd
open:http://www.w3.org/2001/xml.xsd ->http://www.w3.org/2001/xml.xsd
open:http://www.w3.org/TR/voicexml20/vxml-synthesis-extensio n.xsd
-> http://www.w3.org/TR/voicexml20/vxml-synthesis-extension.xsd
open:http://www.w3.org/TR/voicexml20/vxml-synthesis-restrict ion.xsd
-> http://www.w3.org/TR/voicexml20/vxml-synthesis-restriction.x sd
open:http://www.w3.org/TR/voicexml20/synthesis-core.xsd
->http://www.w3.org/TR/voicexml20/synthesis-core.xsd
I'm not sure what you've tried that failed...
Jens Lukowski wrote:
> Hi
> thanx
> Jens Lukowski
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Jens,
<p>If I add this code to XSDMainTest:
<blockquote>412a414,423
<br>>
<br>>
<br>> resourceSet.getURIConverter().getURIMap().put
<br>>&nbsp;&nbsp; (URI.createURI("<A HREF="http://www.w3.org/TR/voicexml20/vxml.xsd">http://www.w3.org/TR/voicexml20/vxml.xsd</A>"),
URI.createURI("<A HREF="file://d:/stuff/vxml.xsd">file://d:/stuff/vxml.xsd</A>"));</blockquote>
<blockquote>380a381
<br>> System.err.println("open:" + uri + " ->" + converted);</blockquote>
then I get this trace (when running xsd-test.bat -validate&nbsp; http://www.w3.org/TR/voicexml20/vxml.xsd):
<blockquote>open:<A HREF="http://www.w3.org/TR/voicexml20/vxml.xsd">http://www.w3.org/TR/voicexml20/vxml.xsd</A> -><A HREF="file://d:/stuff/vxml.xsd">file://d:/stuff/vxml.xsd</A>
<br> open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/MagicXMLSchema.xsd
<br> open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/XMLSchema.xsd
<br>open:<A HREF="http://www.w3.org/2001/xml.xsd">http://www.w3.org/2001/xml.xsd</A> -> platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org/2001 /xml.xsd
<br> open:platform:/plugin/org.eclipse.xsd_1.1.0/cache/www.w3.org /2001/XMLSchema-instance.xsd
<br>open:<A HREF="http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd">http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd</A> -><A HREF="http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd">http://www.w3.org/TR/voicexml20/vxml-datatypes.xsd</A>
<br>open:<A HREF="http://www.w3.org/TR/voicexml20/vxml-attribs.xsd">http://www.w3.org/TR/voicexml20/vxml-attribs.xsd</A> -><A HREF="http://www.w3.org/TR/voicexml20/vxml-attribs.xsd">http://www.w3.org/TR/voicexml20/vxml-attribs.xsd</A>
<br>open:<A HREF="http://www.w3.org/TR/voicexml20/vxml-grammar-extension.xsd">http://www.w3.org/TR/voicexml20/vxml-grammar-extension.xsd</A> -><A HREF="http://www.w3.org/TR/voicexml20/vxml-grammar-extension.xsd">http://www.w3.org/TR/voicexml20/vxml-grammar-extension.xsd</A>
<br>open:<A HREF=" http://www.w3.org/TR/voicexml20/vxml-grammar-restriction.xsd"> http://www.w3.org/TR/voicexml20/vxml-grammar-restriction.xsd</A> -><A HREF=" http://www.w3.org/TR/voicexml20/vxml-grammar-restriction.xsd"> http://www.w3.org/TR/voicexml20/vxml-grammar-restriction.xsd</A>
<br>open:<A HREF="http://www.w3.org/TR/voicexml20/grammar-core.xsd">http://www.w3.org/TR/voicexml20/grammar-core.xsd</A> -><A HREF="http://www.w3.org/TR/voicexml20/grammar-core.xsd">http://www.w3.org/TR/voicexml20/grammar-core.xsd</A>
<br>open:<A HREF="http://www.w3.org/2001/xml.xsd">http://www.w3.org/2001/xml.xsd</A> -><A HREF="http://www.w3.org/2001/xml.xsd">http://www.w3.org/2001/xml.xsd</A>
<br>open:<A HREF=" http://www.w3.org/TR/voicexml20/vxml-synthesis-extension.xsd"> http://www.w3.org/TR/voicexml20/vxml-synthesis-extension.xsd</A> -><A HREF=" http://www.w3.org/TR/voicexml20/vxml-synthesis-extension.xsd"> http://www.w3.org/TR/voicexml20/vxml-synthesis-extension.xsd</A>
<br>open:<A HREF=" http://www.w3.org/TR/voicexml20/vxml-synthesis-restriction.x sd"> http://www.w3.org/TR/voicexml20/vxml-synthesis-restriction.x sd</A>
-><A HREF=" http://www.w3.org/TR/voicexml20/vxml-synthesis-restriction.x sd"> http://www.w3.org/TR/voicexml20/vxml-synthesis-restriction.x sd</A>
<br>open:<A HREF="http://www.w3.org/TR/voicexml20/synthesis-core.xsd">http://www.w3.org/TR/voicexml20/synthesis-core.xsd</A> -><A HREF="http://www.w3.org/TR/voicexml20/synthesis-core.xsd">http://www.w3.org/TR/voicexml20/synthesis-core.xsd</A></blockquote>
<br>&nbsp;
<p>Jens Lukowski wrote:
<blockquote TYPE=CITE>Hi
<p>I want to use a local cache for my resources/schemas.
<br>I tried to provide my own URIResolver and looked at the example in
the docs.
<br>Everything works fine if I pass back the URI I get (an absolute one
with
<br><a href="http://">http://</a>) but if I map the URI to a <a href="file://">file://</a>
<br>schema and doesn't have any element declarations. I checked the inputstream
<br>generated by URIResolver.createInputStream and it has the correct schema
<br>file in it but the URIResolver is never called for the other schemas
<br>referenced by import or include.
<br>What do I do wrong ? I also tried calling schema.setLocation but it
didn't
<br>make any difference.
<br>The xsd file I use is: <a href="http://www.w3.org/TR/voicexml20/vxml.xsd">http://www.w3.org/TR/voicexml20/vxml.xsd</a>
<p>thanx
<br>&nbsp; Jens Lukowski</blockquote>
</html>
--------------EDCAA123E00247A90218C9D5--
Re: Local Cache of Schemas [message #572999 is a reply to message #23546] Mon, 16 June 2003 07:23 Go to previous message
Jens,
412a414,423
380a381
> Hi
> thanx
> Jens Lukowski
<html>
Jens,
<br>>
<br>>
<blockquote>380a381
<br>&nbsp;
the docs.
with
didn't
<p>thanx
</html>
Previous Topic:Problems with: xsdSchema.setSchemaForSchemaQNamePrefix("xsd:")
Next Topic:XML Schema Equivalence
Current Time: Sun Jun 08 02:51:11 EDT 2025
Powered by FUDForum. Page generated in 0.29236 seconds
