Home » Modeling » GMF (Graphical Modeling Framework) » Use same ECORE class with different creation tools
Use same ECORE class with different creation tools [message #236230] Wed, 15 July 2009 09:53 Go to next message
Originally posted by: ML1984.gmx.de
--------------040401020908030905080801
I have a problem using the same ECORE class with different creation
tools. Let's assume there is a (diagram) class A, referencing class B
twice: via EReference b1 and b2. Let's further assume there is one node
in graphical model and two creation tools (B1 and B2) in tooling model.
In mapping model I created the following:
Top Node Reference
Containment Feature: A.b1
Element: B
Diagram Node: Node B
Tool: Creation Tool B1
Top Node Reference
Containment Feature: A.b2
Element: B
Tool: Creation Tool B2
Code generation succeeds, but: If you use the B2 creation tool (in an
newly started eclipse application), an exception is thrown (see below)
and no B element is created.
Caused by: org.eclipse.core.runtime.AssertionFailedException: null
argument:failed to create a view
at
org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at
org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
at
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:247)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:150)
at
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
at
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:135)
at
Using debugger, I could find the origin of the above mentioned
AssertionFailedException. In class
org.eclipse.gmf.runtime.common.core.service.ExecutionStrateg y
there is a static final attribute 'FIRST' of type ExecutionStrategy,
implementing method
public List execute(Service service, IOperation operation)
This method returns Collections.EMPTY_LIST, causing its caller to return
null.
I don't know how to proceed further. Anyway, do you have any suggestions
how to make the example work? BTW, used models are attached to this message.
Mark
PS. I am using Eclipse Galileo pre packaged as Eclipse Modeling Tools.
Content-Type: text/xml;
name="My.gmfgraph"
Content-Disposition: inline;
filename="My.gmfgraph"
<gmfgraph:Canvas xmi:version="2.0"
xmlns:gmfgraph="http://www.eclipse.org/gmf/2006/GraphicalDefinition" name="my">
<figures
name="Default">
<descriptors
name="BFigure">
<actualFigure
xsi:type="gmfgraph:Rectangle"
name="BFigure"/>
</descriptors>
</figures>
<nodes
name="B"
figure="BFigure"/>
</gmfgraph:Canvas>
name="My.gmfmap"
filename="My.gmfmap"
<gmfmap:Mapping xmi:version="2.0"
xmlns:gmfmap="http://www.eclipse.org/gmf/2008/mappings"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<nodes>
<containmentFeature
href="My.ecore#//A/b1"/>
<ownedChild>
<domainMetaElement
href="My.ecore#//B"/>
<tool
xsi:type="gmftool:CreationTool"
href="My.gmftool#//@palette/@tools.0/@tools.0"/>
<diagramNode
href="My.gmfgraph#B"/>
</ownedChild>
</nodes>
<nodes>
<containmentFeature
href="My.ecore#//A/b2"/>
<ownedChild>
<domainMetaElement
<tool
href="My.gmftool#//@palette/@tools.0/@tools.1"/>
<diagramNode
</ownedChild>
</nodes>
<diagram>
<diagramCanvas
href="My.gmfgraph#my"/>
<domainModel
href="My.ecore#/"/>
<domainMetaElement
href="My.ecore#//A"/>
<palette
href="My.gmftool#//@palette"/>
</diagram>
</gmfmap:Mapping>
name="My.gmftool"
filename="My.gmftool"
<gmftool:ToolRegistry xmi:version="2.0"
<palette
title="myPalette">
<tools
xsi:type="gmftool:ToolGroup"
title="my">
<tools
title="B1"
description="Create new B1">
<smallIcon
xsi:type="gmftool:DefaultImage"/>
<largeIcon
</tools>
<tools
title="B2"
description="Create new B2">
<smallIcon
<largeIcon
</tools>
</tools>
</palette>
</gmftool:ToolRegistry>
name="My.ecore"
filename="My.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="my"
nsURI="file://My.ecore" nsPrefix="my">
<eClassifiers xsi:type="ecore:EClass" name="A">
<eStructuralFeatures xsi:type="ecore:EReference" name="b1" eType="#//B" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="b2" eType="#//B" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B"/>
</ecore:EPackage>
name="My.genmodel"
filename="My.genmodel"
<genmodel:GenModel xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel" modelDirectory="/de.hpi.sam.mark.test/src"
modelPluginID="de.hpi.sam.mark.test" modelName="My" importerID="org.eclipse.emf.importer.ecore"
complianceLevel="6.0" copyrightFields="false">
<foreignModel>My.ecore</foreignModel>
<genPackages prefix="My" disposableProviderFactory="true" ecorePackage="My.ecore#/">
<genClasses ecoreClass="My.ecore#//A">
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference My.ecore#//A/b1"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference My.ecore#//A/c"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference My.ecore#//A/b2"/>
</genClasses>
<genClasses ecoreClass="My.ecore#//B"/>
<genClasses ecoreClass="My.ecore#//C"/>
</genPackages>
</genmodel:GenModel>
name="My.gmfgen"
filename="My.gmfgen"
<gmfgen:GenEditorGenerator xmi:version="2.0"
xmlns:gmfgen="http://www.eclipse.org/gmf/2009/GenModel">
<diagram
visualID="1000"
editPartClassName="AEditPart"
itemSemanticEditPolicyClassName="AItemSemanticEditPolicy"
canonicalEditPolicyClassName="ACanonicalEditPolicy"
iconProviderPriority="Low"
validationProviderPriority="Low">
<diagramRunTimeClass
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Diagram "/>
<elementType
xsi:type="gmfgen:MetamodelType"
editHelperClassName="AEditHelper"/>
<viewmap
xsi:type="gmfgen:FigureViewmap"
figureQualifiedClassName="org.eclipse.draw2d.FreeformLayer"/ >
<domainDiagramElement
href="My.genmodel#//my/A"/>
<topLevelNodes
visualID="2001"
editPartClassName="BEditPart"
itemSemanticEditPolicyClassName="BItemSemanticEditPolicy"
canonicalEditPolicyClassName="BCanonicalEditPolicy"
graphicalNodeEditPolicyClassName="BGraphicalNodeEditPolicy"
createCommandClassName="BCreateCommand">
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Node "/>
<elementType
editHelperClassName="BEditHelper"/>
<viewmap
figureQualifiedClassName="org.eclipse.draw2d.RectangleFigure "/>
<modelFacet>
<metaClass
href="My.genmodel#//my/B"/>
<containmentMetaFeature
href="My.genmodel#//my/A/b1"/>
<childMetaFeature
</modelFacet>
</topLevelNodes>
<topLevelNodes
visualID="2002"
editPartClassName="B2EditPart"
itemSemanticEditPolicyClassName="B2ItemSemanticEditPolicy"
canonicalEditPolicyClassName="B2CanonicalEditPolicy"
graphicalNodeEditPolicyClassName="B2GraphicalNodeEditPolicy "
createCommandClassName="B2CreateCommand">
<elementType
xsi:type="gmfgen:SpecializationType"
metamodelType="//@diagram/@topLevelNodes.0/@elementType"/>
<viewmap
<modelFacet>
<metaClass
href="My.genmodel#//my/A/b2"/>
<childMetaFeature
</modelFacet>
</topLevelNodes>
<palette>
<groups
title="my">
<entries
xsi:type="gmfgen:ToolEntry"
title="B1"
genNodes="//@diagram/@topLevelNodes.0"/>
<entries
title="B2"
genNodes="//@diagram/@topLevelNodes.1"/>
</groups>
</palette>
<preferencePages
xsi:type="gmfgen:GenStandardPreferencePage"
iD="de.hpi.sam.mark.test.diagram.general"
name="My Diagram">
<children
iD="de.hpi.sam.mark.test.diagram.appearance"
name="Appearance"
kind="Appearance"/>
<children
iD="de.hpi.sam.mark.test.diagram.connections"
name="Connections"
kind="Connections"/>
<children
iD="de.hpi.sam.mark.test.diagram.printing"
name="Printing"
kind="Printing"/>
<children
iD="de.hpi.sam.mark.test.diagram.rulersAndGrid"
name="Rulers And Grid"
kind="RulersAndGrid"/>
</preferencePages>
</diagram>
<plugin>
<requiredPlugins>org.eclipse.draw2d</requiredPlugins>
</plugin>
<editor/>
<navigator>
<childReferences
child="//@diagram"/>
<childReferences
parent="//@diagram"
child="//@diagram/@topLevelNodes.0"/>
<childReferences
parent="//@diagram"
child="//@diagram/@topLevelNodes.1"/>
</navigator>
<diagramUpdater/>
<propertySheet>
<tabs
xsi:type="gmfgen:GenStandardPropertyTab"
iD="appearance"/>
<tabs
iD="diagram"/>
<tabs
xsi:type="gmfgen:GenCustomPropertyTab"
iD="domain"
label="Core">
<filter
xsi:type="gmfgen:TypeTabFilter">
<types>org.eclipse.gmf.runtime.notation.View</types>
<types>org.eclipse.gef.EditPart</types>
<generatedTypes>abstractNavigatorItem</generatedTypes>
</filter>
</tabs>
</propertySheet>
<domainGenModel
href="My.genmodel#/"/>
<contextMenus
context="//@diagram">
<items
xsi:type="gmfgen:LoadResourceAction"/>
</contextMenus>
</gmfgen:GenEditorGenerator>
--------------040401020908030905080801--
Re: Use same ECORE class with different creation tools [message #236253 is a reply to message #236230] Wed, 15 July 2009 19:19 Go to previous messageGo to next message
Hi Mark,
I think that you need to set constraint on the different node, on
containment feature for instance.
Aurelien Pupier
Mark L. wrote:
> Top Node Reference
> Element: B
> Top Node Reference
> Element: B
> at
> at
> at
> at
> at
> at
> at
> implementing method
> null.
> Cheers,
> Mark
Re: Use same ECORE class with different creation tools [message #468371 is a reply to message #236253] Wed, 05 August 2009 06:11 Go to previous messageGo to next message
Hi Aurelien,
I have the same problem and I wasn't understand you very well.
Can you please be a little more specific?
I have one ECORE element and several graphical presentation of that
element on diagram.
Sinisa
Re: Use same ECORE class with different creation tools [message #468479 is a reply to message #468371] Wed, 05 August 2009 11:51 Go to previous messageGo to next message
Hi Sinisa.
At
http://wiki.eclipse.org/GMF_Tutorial_Part_2#Mapping_Definiti on_3
is a description, that should help you.
To you the most important is probably:
"In fact, whenever you create multiple mappings to a single domain
element, you will need to add constraints such that each can be uniquely
identified."
Mark
PS. Of course, you could alter your meta model to have distinguishable
elements (like I did to solve the problem).
> Hi Aurelien,
> I have the same problem and I wasn't understand you very well. Can you
> element on diagram.
> Thanks, Sinisa
Re: Use same ECORE class with different creation tools [message #468486 is a reply to message #468479] Wed, 05 August 2009 12:11 Go to previous message
Hi Mark
Thanks for response.
This link is exactly what I need.
I also need to alter meta model because my ECORE element doesn't have
appropriate attribute.
Also, I am not familiar with OCL syntax,
so I will try to create a Constraint with the Java syntax.
Again, thank you very much.
Sinisa
Previous Topic:EMF-GMF tabbed.propertySections
Next Topic:unexpected behavior of cut/paste in GMF
Current Time: Mon Nov 03 10:27:30 EST 2025
Powered by FUDForum. Page generated in 0.26696 seconds
