Home » Archived » DSDP - Mobile Tools for Java (MTJ) » External JAR File
External JAR File [message #23600] Mon, 01 December 2008 21:45 Go to next message
first of all thanks for investing so much time and doing such a great
job with MTJ.
I can write some "HelloWorld" code and deploy it to the mobile without
a problem.
I start having problems when I include an external JAR file. I have added
it
correctly in "Libraries" and checked it in "Order and Export". When I
don't use the external JAR in my code, everything works fine. When I
start using it, I get an the following error message:
ALERT: java/lang/ClassFormatError: Bad version information.
The external jar file I am trying to use is
qrcode(http://qrcode.sourceforge.jp).
I have set the "Compile Compliance Level" to 1.4, but that doesn't change a
thing.
I have a hunch that says, that the external jar is in an incompatible
format, but
how can I turn it into a compatible one?
I am using the following software versions:
Eclipse: 3.4.1
MJT: 0.9.0
Java: 1.5.0_16
best regards,
sigi
Re: External JAR File [message #23643 is a reply to message #23600] Tue, 02 December 2008 11:29 Go to previous messageGo to next message
Hello sigi,
The problem really seems to be the fact that your external library is
compiled with an unsupported class version. The library must be compiled
in a 1.3 class version so it can be used in a Java ME application. So you
should compile the sources into a 1.3 compatible class version to be able
to use it.
Best Regards,
David Marques
Re: External JAR File [message #23686 is a reply to message #23643] Tue, 02 December 2008 12:35 Go to previous message
Yes, that was the problem and recompiling the library fixed it.
best regards,
Christoph
Re: External JAR File [message #568872 is a reply to message #23600] Tue, 02 December 2008 11:29 Go to previous message
Hello sigi,
to use it.
Best Regards,
David Marques
Re: External JAR File [message #568893 is a reply to message #23643] Tue, 02 December 2008 12:35 Go to previous message
best regards,
Christoph
Previous Topic:External JAR File
Next Topic:Question about itemStateChanged handler
Current Time: Sat Jul 19 01:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.04330 seconds
