Home » Eclipse Projects » GEF » How to create a new
How to create a new [message #235629] Wed, 13 June 2007 12:46 Go to next message
Originally posted by: neliacatarina.portugalmail.pt
I have this code to get the graphs that compose a diagram:
IEditorPart input = window.getActivePage().getActiveEditor();
FlowEditor editor = (FlowEditor)input;
RootEditPart rootEdit = editor.getRootEditPart();
EditPart contents = rootEdit.getContents();
List children = contents.getChildren();
From this "children" list, I create a xml file to save it's elements.
Now I want to open this file in the application and daw that diagram. I save the values of the xml file in a list but I don't know how to draw it's elements. Can anyone help me?
Re: How to create a new diagram [message #235882 is a reply to message #235629] Mon, 18 June 2007 10:56 Go to previous messageGo to next message
Originally posted by: apexgroup07.gmail.com
You should store model class of your diagram into XML file. and while reading you have to create the model object again and set into the editor.
Reading operaion can be done protected void setInput(IEditorInput input) method of the editor. Or can be done before opening an edior.
Re: How to create a new diagram [message #235903 is a reply to message #235882] Mon, 18 June 2007 12:31 Go to previous messageGo to next message
I have this code to set figures in the editor.
actD is an instance of the class that extends EditPart and have all the children that were saved in XML file.
RootEditPart root = editor.getRootEditPart();
EditPart x = root.getContents();
Activity a = actD.getActivity();
ActivityDiagram ad = new ActivityDiagram();
ad.setName(a.getName());
ad.setRole(a.getRole());
x.setModel(ad);
root.setContents(x);
editor.setRootEditPart(root);
With this code I only get the ActivityDiagram ok, with it's correct properties but with no figures in it. I think I have to do something that really draws the figures but I don't know what it is...
Re: How to create a new diagram [message #235951 is a reply to message #235903] Tue, 19 June 2007 04:25 Go to previous message
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Nelia,
I guess that if you have edit parts for the element you want to draw,
then the figures for these elements should be drawn by the GEF internal
mechanism.
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
> x.setModel(ad);
Previous Topic:change Icon in Label
Next Topic:How can I configure an Plugin.xml file
Current Time: Tue Jul 29 00:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.06252 seconds
