Home » Language IDEs » C / C++ IDE (CDT) » SWT
SWT [message #23454] Wed, 03 April 2002 17:55 Go to next message
Originally posted by: usingmyillusion.hotmail.com
Hi there all,
please, I apologize if this will sound as a retoric question, but I'm really
seeking a "formal" answer.
Currently, as I saw in the documents, CDT only supports Linux using Motif.
My question is - why only Motif? As I know the eclipse project (and, of
course, I might be wrong), the SWT is the standard UI layer for the eclipse
project & tools, and is platform-dependant, so you need to port it in order
for it to work; but, as far as I've seen (in the regular drops page),
eclipse is available also for GTK. This implies that SWT was ported to GTK;
and if CDT uses SWT for UI - and it *should* use SWT for UI, in order to be
a standard eclipse tool - then CDT shouldn't have any problems running on
GTK.
Am I missing something here?
- Isaac
Re: SWT [message #23497 is a reply to message #23454] Wed, 03 April 2002 18:51 Go to previous messageGo to next message
I can answer for WSAD on Linux which has a similar statement regarding
support for motif/linux versions. The CDT development team may have a
different perspective though, so for the CDT, wait for them to comment :-).
This may give some insight though as to where support statements like
that come from.
If you look at the eclipse 2.0 plan.
http://www.eclipse.org/eclipse/eclipse_project_plan_2_0_rev0 326.html
Scroll down to the Windowing System part.
You'll see that GTK support for eclipse is defined as "early access".
Since GTK is early access and is not "product quality" then "official
support" of it won't be there for eclipse or for tooling built on
eclipse. (i.e supported platforms/windowing systems get first priority
when it comes to defect fixing time etc)
This is not to say it won't work (it may and probably will) or that
problems won't be looked at by the development teams (especially if they
are using it) just that it isn't "supported".
Hope this makes some sense.
Peter
Isaac S. wrote:
> Hi there all,
> GTK.
> - Isaac
Re: SWT [message #23582 is a reply to message #23497] Wed, 03 April 2002 21:53 Go to previous message
Yep, CDT regards GTK support the same way as WSAD does - we don't "officially
support" it because it is not yet at "product quality". That doesn't mean you
can't use GTK, just that the CDT team currently has no plans to test with it.
Dave
> that come from.
> Peter
> Isaac S. wrote:
> > Hi there all,
> > GTK.
> > - Isaac
Previous Topic:Starting CDT
Next Topic:Closing socket on ClientConnection.disconnect
Current Time: Wed Jul 23 12:03:25 EDT 2025
Powered by FUDForum. Page generated in 0.29937 seconds
