Home » Modeling » GMF (Graphical Modeling Framework) » method creation/deletion inside model
method creation/deletion inside model [message #235579] Tue, 07 July 2009 13:03 Go to next message
Originally posted by: watertext.hotmail.it
Greetings, i have a diagram editor (extends ecorediagrameditor) that
programmatically needs to add/remove/change the methods inside the classes
on the diagram.
I noticed that inside the EObject (
IGraphicalEditPart.getModel().getElement() ) i could get the methods using
eobject.getEOperations() but i dont know how to replace them inside the
model with a new EList
Its possible to do that and refresh my diagram if needed?
getEOperations() is the right method to do it?
thanks for your time, bye.
Re: method creation/deletion inside model [message #235611 is a reply to message #235579] Wed, 08 July 2009 05:59 Go to previous messageGo to next message
Hello Max,
You are probably talking about EClass.eOperations() method..
Then you can modify returned collection and corresponding modifications will
be propagated to the model/diagram should be updated in accordance.
Alex Shatalin
Re: method creation/deletion inside model [message #235802 is a reply to message #235611] Thu, 09 July 2009 09:15 Go to previous message
Hi Alex, yes you were right, it's a method from EClass, i forgot to notice
the cast.
I was interested to modify the name of the Operation, i was able to do so
using the right command:
Object newname = new String("myNewMethodName");
EditingDomain editingDomain =
((EcoreDiagramEditor)editor).getDiagramEditPart().getEditing Domain();
EOperation eop = eclass.getEOperations().get(0);
editingDomain.getCommandStack().execute(SetCommand.create(ed itingDomain,
eop, EcorePackage.Literals.ENAMED_ELEMENT__NAME , newname));
Thanks for your help, bye.
"Alex Shatalin" <vano@borland.com> ha scritto nel messaggio
news:3c3172e62e8e48cbcddaa01ca550@news.eclipse.org...
> Hello Max,
> will be propagated to the model/diagram should be updated in accordance.
> Alex Shatalin
Previous Topic:Connections disappear between shortcut elements on refresh/reload
Next Topic:Open diagram impractical with new WrappingLabel
Current Time: Wed Jul 23 20:35:09 EDT 2025
Powered by FUDForum. Page generated in 0.05164 seconds
