Home » Eclipse Projects » GEF » moving an extended draw2d-figure with mouse
moving an extended draw2d-figure with mouse [message #235190] |
Wed, 06 June 2007 10:25  |
Originally posted by: Markus.Voss.post.rwth-aachen.de
I created my own figure by extending the draw2d-figure-class and put an
instance of that on a FigureCanvas.
Now I want to move the figure on the canvas when the mouse is pressed on the
figure and moved. Therefore I added a MouseMotionListener to my extended
figure instance, calling the setLocation(...)-method of my figure instance
from within the mouseDragged(...)-method of the implementation of the
MouseMotionListener.
This works so far, but the movements are very jerky and slow! Does anyone
now how to make it behave more fluent? Is my approach bad, or is there
something I can do to improve it???
Markus
Re: moving an extended draw2d-figure with mouse [message #235400 is a reply to message #235292] |
Mon, 11 June 2007 16:14   |
Thanks, but...
.... with the tolerance window its not jerky for an unknown reason, but jerky
due to the implementation... then the figure jumps in steps of the tolerance
window...
Therefore, not really what I was looking for. Another thing that I observed
is that the first few, say 5, seconds it is quite ok, but after that it
starts getting more and more jerky... the code is not very much... I do not
really see a reason for that behaviour...
Any more suggestions?
"Alex Boyko" <aboyko@ca.ibm.com> schrieb im Newsbeitrag
news:4030ac88120772a00fcf8edd711f643a$1@www.eclipse.org...
> If you move your figure on each mouse drag and the movement looks jerky
> try to introduce a tolerance value for mouse drag, i.e. if you drag over
> 5-10 pixels along x or y axis then move the figure.
> Cheers,
> Alex
Re: moving an extended draw2d-figure with mouse [message #235428 is a reply to message #235400] |
Tue, 12 June 2007 10:43   |
Originally posted by: none.ibm.com
There is a draw2d.examples project in CVS. See the FAQ for how to load it.
"Markus Voss" <Markus.Voss@post.rwth-aachen.de> wrote in message
news:f4kaee$734$1@build.eclipse.org...
> Thanks, but...
> jerky
> tolerance
> window...
> observed
> not
>> Hi,
>> Cheers,
>> Alex
Re: moving an extended draw2d-figure with mouse [message #235492 is a reply to message #235428] |
Tue, 12 June 2007 12:12   |
I know the draw2d.examples and draw2d.tests...
Unfortunately none is covering my problem...
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:f4mbf6$e8g$1@build.eclipse.org...
> > Thanks, but...
> > jerky
> > tolerance
> > window...
> > observed
> > not
> >> Hi,
over
> >> Cheers,
> >> Alex
Re: moving an extended draw2d-figure with mouse [message #235622 is a reply to message #235492] |
Wed, 13 June 2007 12:25   |
Ok, I found a solution, although I am not convinced by this solution. For my
Figure I do not use the paint(graphics g)-method and therefore did not
override it.
Now, when I override the paint(graphics g)-method with an empty
implementation, my figure still moves jerky. But when I add something
calling a method on "g", then my figure moves fluently. E.g. I set the
backgroundColor to blue, calling
g.setBackgroundColor(new Color(...));
This does not appear on the screen, as my figure is created as child
consisting of more children to the parent figure, all children of type
IFigure. Therefore the painting on "g" does not appear.
Very strange...
Markus
"Markus Voss" <Markus.Voss@post.rwth-aachen.de> schrieb im Newsbeitrag
news:f4mgl6$8g1$1@build.eclipse.org...
it.
> > > Thanks, but...
> > > jerky
> > > tolerance
> > > window...
> > > observed
it
do
> > > not
> > >> Hi,
jerky
> over
> > >> Cheers,
> > >> Alex
Re: moving an extended draw2d-figure with mouse [message #235937 is a reply to message #235622] |
Mon, 18 June 2007 20:12  |
Please attach a snippet or some code.
news:f4p5q0$hm9$1@build.eclipse.org...
> my
> override it.
> Very strange...
> Best regards,
> Markus
Current Time: Wed Jul 23 20:20:47 EDT 2025
Powered by FUDForum. Page generated in 1.09045 seconds
