Home » Modeling » GMF (Graphical Modeling Framework) » generate code from .gmfgen
generate code from .gmfgen [message #232027] Tue, 02 June 2009 09:53 Go to next message
As Achilleas a few months ago :
"I have an .ecore model from which I am able to automatically
(programmatically) create the .genmodel and generate the java code for the
model,edit,editor projects. This is performed by running an ant script
that makes use of the EcoreGeneratorTask to generate the .genmodel and the
java code. Not by using the Eclipse EMF capabilities, e.g. right click on
genmodel and choose "Generate Model Code". Using this automatic task I can
generate the code and run an instance of the EMF tree-based editor to
define my models.
Now I want to do the same for the diagram GMF-based editor. I have the
gmfmap model and I don't want to right-click on it and choose "Create
generator model" and the right click on .gmfgen to choose "Generate
diagram code"; via the eclipse GMF capabilities. What I want is to
automate this task programmatically or via an ant script as in the first
case.
And yes I have read most of the tutorials. I hope my clarification is
precise so that anyone can provide me with some guidelines how to start
doing that?"
For me I only want to generate code from the .gmfgen (doesn't want to
generate it).
At the end of the thread :
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg16579.html
So is it possible now? What is the outcome of that? Any suggestions?
(The thread is archived so I don't find how to respond to it... is there
possible to uprise a thread?)
Re: generate code from .gmfgen [message #235251 is a reply to message #232027] Fri, 03 July 2009 09:56 Go to previous messageGo to next message
Returning to this issue after a lot of months of other related work I am
trying to use the TransformToGenModelOperation and
TransformToGenModelWizard as advised by Alex.
I am getting the following exception:
org.eclipse.core.runtime.CoreException: Errors while loading Mapping model
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lOperation.loadMappingModel(TransformToGenModelOperation.jav a:164)
at
bt.com.ccm.generation.plugin.actions.GenerateDiagram.<init>(GenerateDiagram.java:85)
at
bt.com.ccm.generation.plugin.actions.GenerateAction.run(Gene rateAction.java:91)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lOperation.loadMappingModel(TransformToGenModelOperation.jav a:149)
... 32 more
Which occurs at the following code - specifically at the statement String
msg = Messages.Tra.......
if (!(root instanceof Mapping)) {
String msg =
MessageFormat.format(Messages.TransformToGenModelOperation_e _wrong_root_element,
root.getClass().getName());
status = Plugin.createError(msg, null);
throw new CoreException(status);
I don't seem to understand what is the problem and why the loading of the
gmfmap file fails. I have validated the gmfmap file I am using and it is
just fine. The code I have implemented is the following:
@SuppressWarnings("restriction")
public GenerateDiagram(){
resourceSet = new ResourceSetImpl();
Resource genmodel = new ResourceImpl();
genmodel =
resourceSet.createResource(URI.createPlatformResourceURI("/bt.com.ccm.generation.plugin/model/product.genmodel ",
true));
System.out.println("print genmodel: "+genmodel.toString());
Resource gmfgraph = new ResourceImpl();
gmfgraph =
resourceSet.createResource(URI.createPlatformResourceURI("/bt.com.ccm.generation.plugin/model/product.gmfgraph ",
true));
System.out.println("print gmfgraph: "+gmfgraph.toString());
Resource gmftool = new ResourceImpl();
gmftool =
resourceSet.createResource(URI.createPlatformResourceURI("/bt.com.ccm.generation.plugin/model/product.gmftool ",
true));
System.out.println("print gmftool: "+gmftool.toString());
Resource gmfmap = new ResourceImpl();
gmfmap =
resourceSet.createResource(URI.createPlatformResourceURI("/bt.com.ccm.generation.plugin/model/product.gmfmap ",
true));
System.out.println("print gmfmap: "+gmfmap.toString());
resourceSet.getResources().add(genmodel);
resourceSet.getResources().add(gmfgraph);
resourceSet.getResources().add(gmftool);
resourceSet.getResources().add(gmfmap);
TransformToGenModelOperation tgmfgen = new
TransformToGenModelOperation(resourceSet);
try {
NullProgressMonitor np = new NullProgressMonitor();
tgmfgen.loadMappingModel(gmfmap.getURI(),np);
tgmfgen.loadGenModel(genmodel.getURI(), np);
GenModel genmmodel = tgmfgen.findGenmodel();
IFile target = (IFile)new File("product.gmfgen");
tgmfgen.setGenURI(URI.createPlatformResourceURI(target.getFu llPath().toString(),
true));
} catch (CoreException e) {
e.printStackTrace();
//IProgressMonitor monitor =
(IProgressMonitor)getProject().getReferences().get(AntCorePl ugin.ECLIPSE_PROGRESS_MONITOR);
System.out.println("created IProgressMOnitor: ");
tgmfgen.setGenURI(URI.createPlatformResourceURI("/bt.com.ccm.generation.plugin/model/product.gmfgen ",
true));
tgmfgen.executeTransformation(np);
Any ideas?
Achilleas
Re: generate code from .gmfgen [message #235350 is a reply to message #235251] Mon, 06 July 2009 05:51 Go to previous messageGo to next message
Originally posted by: aurelien.pupier.esial.net
great to hear news about this subject.
Perhaps you can inspire from the opened bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=282331
(and vote for it)
Achilleas a écrit :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
> String msg = Messages.Tra.......
> String msg =
> the gmfmap file fails. I have validated the gmfmap file I am using and
> it is just fine. The code I have implemented is the following:
> genmodel =
> true)); System.out.println("print genmodel: "+genmodel.toString());
> gmfgraph =
> true)); System.out.println("print gmfgraph: "+gmfgraph.toString());
> gmftool =
> true)); System.out.println("print gmftool: "+gmftool.toString());
> gmfmap =
> true)); System.out.println("print gmfmap: "+gmfmap.toString());
> try {
> true));
> //IProgressMonitor monitor = //
> true));
> Any ideas?
> Achilleas
Re: generate code from .gmfgen [message #235755 is a reply to message #235350] Thu, 09 July 2009 07:03 Go to previous messageGo to next message
Hi again,
Does anyone has any idea why I get this exception when I am loading the
mapping model?
at
at
bt.com.ccm.generation.plugin.actions.GenerateDiagram.<init>(GenerateDiagram.java:90)
at
bt.com.ccm.generation.plugin.actions.GenerateAction.run(Gene rateAction.java:87)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 32 more
The exception is generated from the following code line in the
TransformToGenModelOperation class:
String msg =
Achilleas
Re: generate code from .gmfgen [message #235795 is a reply to message #235755] Thu, 09 July 2009 09:08 Go to previous messageGo to next message
Anyone knows how to use the TransformToGenModelOperation class for
creating the gmfgen model?
I don't seem to be able to find out what is the process? Any ideas since I
am kind of lost here?
Achilleas
Re: generate code from .gmfgen [message #235848 is a reply to message #235795] Thu, 09 July 2009 12:04 Go to previous messageGo to next message
I have managed to create the gmfgen from the gmfmap eventually after some
struggle. Is there anyone who has a tip of how to start to generate the
diagram code from the gmfgen?
Achilleas
Re: generate code from .gmfgen [message #236202 is a reply to message #235848] Wed, 15 July 2009 06:50 Go to previous message
Hi Achilleas,
You said that had managed to create the .gmfgen from the .gmfmap.
Please, could you post how did you do it? Because I have the same problem.
Tanhks!
> some struggle. Is there anyone who has a tip of how to start to generate
> the diagram code from the gmfgen?
> Achilleas
Previous Topic:Confirm delete shape
Next Topic:Drag&Drop into Diagram issue
Current Time: Sun Jul 27 08:11:37 EDT 2025
Powered by FUDForum. Page generated in 0.08148 seconds
