changing "Problems" path [message #235280] |
Mon, 29 June 2009 09:58  |
Originally posted by: marco.binz.annax.ch
I'm using Eclipse / CDT on Windows, my source files however are on a
linux server. We access the files with a network drive connecting to the
server using samba. Compilation is done on the server, using plink (a
"command line PuTTY".
Paths to files with errors or warnings are of corse returned by the
compiler in linux style, e.g. /home/Projects/Projectx/main.cpp
Since these paths are not known to Windows, I can't doubelick on a error
/ warning in the "Problems" view to jump to the problem.
Is there a way to tell Eclipse (or the error parser, or make, or...) to
change the path from /home/Projects/... to Q:\Projects\...?
Marco
Re: changing "Problems" path [message #235313 is a reply to message #235299] |
Tue, 30 June 2009 09:03  |
Marco Binz wrote:
> Unfortunately, we're still working with Eclipse 3.4.1 / CDT 5.0.1 here,
> so I tried to do it in the Project itself, not in a special "LinuxFiles"
> project. But eclipse doesn't allow this, it says "Cannot create a link
> to 'Q:Projects' because it overlaps the location of the project that
> contains the linked resource."
So you already got the files in your workspace. But it is not going to
work in CDT 5.0.X with absolute paths in output. It may find relative ones
with some luck.
> So guess I'm out of luck until we update to the new eclipse / cdt,
> unless anyone has another idea?
You can try to imitate directory structure on Windows filesystem starting
from root, i.e. place your files like Q:\home\Projects\Projectx\main.cpp.
This may allow to use "Open external location" from Problems View
(right-click on error/warning) - if you can see the full file name in the
description of the error. I think it has to be current drive, i.e. start
eclipse in a folder on Q: drive. But don't expect double-click to work.
I'd really advise to update to CDT 6.0. It's well worth it.
Andrew
FUDForum. Page generated in 0.04526 seconds
