Home » Language IDEs » C / C++ IDE (CDT) » Debugger issues with input functions
Debugger issues with input functions [message #234840] Sat, 13 June 2009 13:03 Go to next message
I'm experiencing issues with the debugger when debugging code that
contains input functions such as scanf() or gets().
Here's a sample of the code that I'm running through the debugger:
#include <stdio.h>
int main() {
char *name;
setvbuf(stdout, NULL, _IONBF, 0);
printf("What's your name? ");
gets(name);
printf("Hello %s!", name);
return 0;
I step through this code snippet and when I reach the gets() line the
following line appears in the Console View:
What's your name?
776*stopped,reason="end-stepping-range",reason="breakpoint-hit ",bkptno="3",thread-id="1",frame={addr="0x0040134e",func= "main",args=[],file="../src/getname.c",fullname="D:/eclipse/workspace/misc-c/Debug/../src/getname.c ",line="17"}
The same result occurs if I use a scanf() call in place of the gets() call.
From here, the debugger just seems to hang. However, I can enter input
into the console view - when I do this - an error dialog appears -->
"Execution is suspended because of error". My only recourse is to kill
the debug session and on the very rare occasion, Eclipse itself goes into
"la la" land and I have to kill Eclipse and restart.
From the research I have done, the output that appears in the console view
is output one would expect when running gdb with the MI protocol.
Has anyone experienced this behaviour with the debugger? Any suggestions
as to what the issue is and how to rectify it would be gratefully accepted.
Cheers
JD
Re: Debugger issues with input functions [message #235153 is a reply to message #234840] Wed, 24 June 2009 07:17 Go to previous messageGo to next message
Well, it's been 11 days since my original post and I've had no response -
seems as though no one has come across my issue.
So, I have completely uninstalled Eclipse (Ganymede) and reinstalled. I
then downloaded the CDT related plugins - that all went well. I imported
my projects into my new workspace and tried the debugger in CDT with the
example code from my original post and I'm still experiencing the issue.
I have also uninstalled MinGW and re-installed - all to no avail.
FYI, I'm also "playing" with BloodShed and CodeBlocks (with MinGW) and the
code snippet from the original post does not present any problems to the
debug environments with these IDEs.
Again, I'd appreciate any assistance with this matter. I really like the
CDT environment and it's just a shame I can't get the debugger to work on
a consistent basis.
JD
Re: Debugger issues with input functions [message #235660 is a reply to message #234840] Sat, 11 July 2009 00:34 Go to previous messageGo to next message
Well it's now been 28 days since my original post and still no response as
to why this issue regarding the debugger and input functions occurs.
Since my last post (response) I have installed Eclipse Galileo and the CDT
(version 6.0) and the problem still exists.
So here's the dinky little code snippet I'm having problems using the
debugger with:
int main(void) {
char name[30];
fgets(name, 30, stdin);
printf("Hello %s", name);
return 0;
As stated in my original post, as soon as the debugger hits the first
printf line, I get the output stipulated in my original post in the
Console view - from there nothing works at all in the debugger and I have
to abort the debug session.
Would someone please mind trying the above code snippet out with the
debugger out to see if they get the same results as me?
JD
Re: Debugger issues with input functions [message #235688 is a reply to message #235660] Sat, 11 July 2009 21:51 Go to previous messageGo to next message
> debugger with:
> int main(void) {
> char name[30];
> return 0;
I was able to run this without any problems in both the Standard debugger
integration and the new DSF-GDB debugger integration.
I'm using gdb 6.8 on Ubuntu.
Marc
Re: Debugger issues with input functions [message #235695 is a reply to message #235688] Sat, 11 July 2009 21:59 Go to previous messageGo to next message
I just figured it out.
In the launch configuration's main tab, you have to select the option at
the bottom that says "Connect process input_output to a terminal"
I can reproduce your problem when I don't have that option checked.
Once you try this, make sure you see the correct console by using the
drop-down arrow in the console view. You want to use the console created
for your application to type your input.
Marc
P.S. You can also try the new DSF-GDB debugger. The 'console' option has
been removed from that debugger integration, and you always get your
processes output to a console.
Re: Debugger issues with input functions [message #235724 is a reply to message #235695] Mon, 13 July 2009 09:25 Go to previous messageGo to next message
> Marc
Marc,
Thank you for your response.
In my Main tab on the Debug Configurations dialog, the "Connect process
input output to a terminal" option is checked by default and grayed out.
I'm using the MinGW tool chain with my setup and I have four options for
choosing the debugger under the Debugger tab:
- gdb Debugger
- gdb/mi
- gdbserver Debugger
- MinGW gdb Debugger
I've now tried all debugger options and the only one I can get to work is
gdb/mi with "GDB command set" set to "Standard". When I debug with this
configuration, a terminal window runs and my console application runs in
this window during the debug session. There is a Console view in Eclipse
for my application but it remains empty during the debug session. Other
configurations produce the same results as stated in my previous posts.
I've tried The DSF and unfortunately I observe the same behaviour as
outlined in my original post.
Perhaps someone can test on a Windows machine.
Anyway, thanks again for your help Marc, I'm in a better position than I
was a few days ago.
JD
Re: Debugger issues with input functions [message #235764 is a reply to message #235724] Mon, 13 July 2009 14:28 Go to previous messageGo to next message
>> Marc
> Marc,
It is strange that I can reproduce your error by unchecking this option.
Maybe in your setup the option is being ignored. I don't have your setup
so I cannot try it but this could be a bug. I don't know much about the
Standard debugger so I can't help much more. If we can get DSF to work, I
can help there. See below.
If you can post the output from the console called 'gdb traces' after you
do your DSF launch, I can try to see what is happening.
Marc
Re: Debugger issues with input functions [message #235771 is a reply to message #235764] Tue, 14 July 2009 07:37 Go to previous messageGo to next message
Marc,
Thanks again for your interest in my issue. Here's the output from the
gdb traces console when launching with DSF (towards the end you'll see
that I had to abort the session):
369,500 1source .gdbinit
369,515 &"source .gdbinit\n"
369,515 &".gdbinit: No such file or directory.\n"
369,515 1^error,msg=".gdbinit: No such file or directory."
369,515 (gdb)
369,515 2-file-exec-and-symbols
D:/eclipse/eclipse/workspace/misc-c/Debug/misc.exe
369,546 2^done
369,546 3-environment-cd D:/eclipse/eclipse/workspace/misc-c
369,546 (gdb)
369,562 3^done
369,562 (gdb)
369,562 4-gdb-set auto-solib-add on
369,578 4^done
369,578 (gdb)
369,625 5-environment-directory D:/eclipse/eclipse/workspace/misc-c
D:/eclipse/eclipse/workspace/mis\
c-c/Debug D:/eclipse/eclipse/workspace/misc-c/Debug/src
D:/eclipse/eclipse/workspace/misc-c/src
369,625
5^done,source-path=" D:/eclipse/eclipse/workspace/misc-c;D:/eclipse/eclipse/works pace/misc-c/\
Debug;D:/eclipse/eclipse/workspace/misc-c/Debug/src;D:/eclip se/eclipse/workspace/misc-c/src;$cdir;$c\
wd"
369,640 (gdb)
369,640 6-break-insert getname.c:19
369,640 7-break-insert getname.c:14
369,640 8-break-insert getname.c:16
369,640 9-break-insert getname.c:18
369,640 10-break-insert getname.c:17
369,656
6^done,bkpt={number="1",type="breakpoint",disp="keep",enabled= "y",addr="0x0040137d",func="ma\
in",file="../src/getname.c",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",li\
ne="19",times="0"}
369,671 (gdb)
369,671
7^done,bkpt={number="2",type="breakpoint",disp="keep",enabled= "y",addr="0x0040131a",func="ma\
ne="14",times="0"}
369,687 (gdb)
369,703
8^done,bkpt={number="3",type="breakpoint",disp="keep",enabled= "y",addr="0x00401342",func="ma\
ne="16",times="0"}
369,718 (gdb)
369,765
9^done,bkpt={number="4",type="breakpoint",disp="keep",enabled= "y",addr="0x0040136a",func="ma\
ne="18",times="0"}
369,765 (gdb)
369,781
10^done,bkpt={number="5",type="breakpoint",disp="keep",enabled= "y",addr="0x0040134e",func="m\
ain",file="../src/getname.c",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",l\
ine="17",times="0"}
369,781 (gdb)
369,781 11-break-insert -t main
369,796
11^done,bkpt={number="6",type="breakpoint",disp="del",enabled= "y",addr="0x00401315",func="ma\
ne="10",times="0"}
369,812 (gdb)
369,812 12-exec-run
369,812 12^running
369,812 (gdb)
369,968 ~"[New thread 568.0xb8]\n"
372,234
12*stopped,thread-id="1",frame={addr="0x00401315",func="main ",args=[],file="../src/getname.c\
",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",line="10"}
372,234 (gdb)
372,500 13-thread-list-ids
372,515 13^done,thread-ids={thread-id="1"},number-of-threads="1"
372,515 (gdb)
372,531 14-thread-select 1
372,531 15-stack-info-depth 11
372,546
14^done,new-thread-id="1",frame={level="0",addr="0x00401315 ",func="main",args=[],file="../sr\
c/getname.c",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",line="10"}
372,546 (gdb)
372,546 15^done,depth="1"
372,546 (gdb)
372,890 16info threads
372,890 &"info threads\n"
372,906 ~"* 1 thread 568.0xb8 main () at ../src/getname.c:10\n"
372,906 16^done
372,906 (gdb)
372,906 17-stack-select-frame 0
372,906 18-stack-list-locals 1
372,906 17^done
372,906 (gdb)
372,906
18^done,locals=[{name="name",value="\"\\224\\\\\\303wP(\\301w\\377\\377\\377\\377)N\\303wBN\\
\303w\\220\\023@\\000x\\377\\\"\\000\\366\\023\""}]
372,906 (gdb)
372,921 19-var-create - * name
372,937 19^done,name="var1",numchild="30",value="[30]",type="char [30]"
372,937 (gdb)
372,937 20-var-create - * &(name)
372,953 20^done,name="var2",numchild="1",value="0x22ff50",type= "char
(*)[30]"
372,953 (gdb)
377,015 21-exec-next 1
377,031 21^running
377,031 (gdb)
377,125
21*stopped,reason="end-stepping-range",reason="breakpoint-hit ",bkptno="2",thread-id="1",fram\
e={addr="0x0040131a",func="main",args=[],file="../src/getname.c ",fullname="D:/eclipse/eclipse/worksp\
ace/misc-c/Debug/../src/getname.c",line="14"}
377,125 (gdb)
377,125 22-thread-select 1
377,125 23-stack-select-frame 0
377,125 24-stack-list-locals 1
377,156
22^done,new-thread-id="1",frame={level="0",addr="0x0040131a ",func="main",args=[],file="../sr\
c/getname.c",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",line="14"}
377,156 25-stack-info-depth 11
377,156 (gdb)
377,156 23^done
377,156 (gdb)
377,156
24^done,locals=[{name="name",value="\"\\224\\\\\\303wP(\\301w\\377\\377\\377\\377)N\\303wBN\\
377,156 (gdb)
377,171 25^done,depth="1"
377,171 (gdb)
377,171 26-stack-info-depth
377,171 26^done,depth="1"
377,171 (gdb)
377,171 27-var-update 1 var1
377,187 27^done,changelist=[]
377,187 (gdb)
377,187 28-var-update 1 var2
377,203 28^done,changelist=[]
377,203 (gdb)
380,000 29-exec-next 1
380,015 29^running
380,015 (gdb)
380,093
29*stopped,reason="end-stepping-range",reason="breakpoint-hit ",bkptno="3",thread-id="1",fram\
e={addr="0x00401342",func="main",args=[],file="../src/getname.c ",fullname="D:/eclipse/eclipse/worksp\
ace/misc-c/Debug/../src/getname.c",line="16"}
380,093 (gdb)
380,125 30-thread-select 1
380,125 31-stack-select-frame 0
380,125 32-stack-list-locals 1
380,140
30^done,new-thread-id="1",frame={level="0",addr="0x00401342 ",func="main",args=[],file="../sr\
c/getname.c",fullname="D:/eclipse/eclipse/workspace/misc-c/Debug/../src/getname.c ",line="16"}
380,140 (gdb)
380,156 33-stack-info-depth 11
380,156 31^done
380,156 (gdb)
380,156
32^done,locals=[{name="name",value="\"\\224\\\\\\303wP(\\301w\\377\\377\\377\\377)N\\303wBN\\
380,156 (gdb)
380,156 33^done,depth="1"
380,156 (gdb)
380,156 34-stack-info-depth
380,187 34^done,depth="1"
380,187 (gdb)
380,187 35-var-update 1 var1
380,203 35^done,changelist=[]
380,203 (gdb)
380,203 36-var-update 1 var2
380,203 36^done,changelist=[]
380,203 (gdb)
381,625 37-exec-next 1
381,640 37^running
381,640 (gdb)
381,718 What's your name?
37*stopped,reason="end-stepping-range",reason="breakpoint-hit ",bkptno="5",\
thread-id="1",frame={addr="0x0040134e",func="main",args=[],file= "../src/getname.c",fullname="D:/ecli\
pse/eclipse/workspace/misc-c/Debug/../src/getname.c",line="17 "}
381,718 (gdb)
384,953 &"John\n"
384,953 &"Undefined command: \"John\". Try \"help\".\n"
384,953 ^error,msg="Undefined command: \"John\". Try \"help\"."
384,953 (gdb)
388,593 38kill
388,625 &"Quit (expect signal SIGINT when the program is resumed)\n"
388,625 &"kill\n"
388,625 ~"Kill the program being debugged? (y or n) [answered Y; input not
from terminal]\n"
388,625 38^done
388,625 (gdb)
388,625 39-gdb-exit
388,625 40-data-evaluate-expression $_exitcode
388,640 39^exit
JD
Re: Debugger issues with input functions [message #236073 is a reply to message #235771] Fri, 17 July 2009 10:49 Go to previous messageGo to next message
> Marc,
This must a bug when running on Windows. Although we are focusing on
Linux, we would like to have DSF-GDB working on Windows too. You can
write a bugzilla about that.
Thanks.
Re: Debugger issues with input functions [message #236229 is a reply to message #236073] Tue, 21 July 2009 18:25 Go to previous messageGo to next message
This may seem simple, but John, are you sure you are switching console
windows to enter the input? Two console windows are created when you are
enabling the debug output.
The first is a debug output log. This is being displayed by default. This
is because the gdb log sent I/O last. The console will always display
which ever recieved I/O last.
The second should only contain your application I/O. Once you get to
scanf, you need to input your name into the second console. You are
getting an end of range error because you are trying to step through the
scanf. This is impossible because scanf is blocking, it has not accepted
input yet.
To switch to the second console window, the second from the right icon
"Display selected console" will toggle through the different console
windows. I hope this address' your issue!
Forrest Stanley
Project Engineer
NetBurner, Inc
NBEclipse - Build a network enabled embedded device in one day with an
Eclipse interface!
Re: Debugger issues with input functions [message #236296 is a reply to message #236229] Wed, 22 July 2009 12:08 Go to previous messageGo to next message
> input yet.
> Forrest Stanley
> Project Engineer
> NetBurner, Inc
> Eclipse interface!
Yes, I am in looking in the correct console - the one associated with the
application and the output is as I stated in my very original post.
At the moment the only debugger option that works for me is gdb/mi and
that opens a standalone console (i.e. DOS box) - all I/O is directed via
this console during the debug session.
All other debugger selections (including DSF) exhibit the behaviour I have
outlined in my previous postings.
Thank you for your interest.
JD
Re: Debugger issues with input functions [message #236326 is a reply to message #236296] Wed, 22 July 2009 14:25 Go to previous messageGo to next message
Looking at your gdb output below:
381,640 (gdb) 381,718 What's your name?
381,718 (gdb) 384,953 &"John\n"
384,953 (gdb) 388,593 38kill
388,625 &"kill\n"
from terminal]\n"
388,625 38^done
388,625 (gdb) 388,625 39-gdb-exit
GDB is accepting your input "John" as a GDB mi command. This is the root
of your error. This should not be going to the GDB console window, it
should be going to stdin. I can only think that this would happen if you
are typing into the GDB console.
Forrest Stanley
Project Engineer
NetBurner - Build a network enabled embedded device in one day with an
Eclipse interface!
http://www.netburner.com
Re: Debugger issues with input functions [message #236381 is a reply to message #236326] Thu, 23 July 2009 12:38 Go to previous messageGo to next message
> 381,718 (gdb) 384,953 &"Johnn"
> 384,953 &"Undefined command: "John". Try "help".n"
> 384,953 ^error,msg="Undefined command: "John". Try "help"."
> 388,625 &"Quit (expect signal SIGINT when the program is resumed)n"
> 388,625 &"killn"
> from terminal]n"
> 388,625 38^done
These traces are from DSF-GDB and I just remembered this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231883
which basically says we are not handling process output/input properly on
Windows. So, that explains why DSF-GDB won't work in this case. The bug
also mentions that the CDI debugger opens up a new DOS window to deal with
the input/output. Seems to be the case that works for you. So, my guess
is that there is way on Windows to use the Eclipse console for
input/output, you have to use the extra DOS window.
Marc
Re: Debugger issues with input functions [message #1023429 is a reply to message #236381] Sun, 24 March 2013 03:10 Go to previous messageGo to next message
Eclipse was hanging for me when pressing CNTL + D when running a program that used EOF.
Go to Run-> Run configurations uncheck Connect process input & output to a terminal.
After posting this I found that if there is a print statement it won't print any of them till you press CNTRL + D...?
This sort of helps though not entirely.
Yours Sincerely,
Gerard Grundy
[Updated on: Sun, 24 March 2013 03:22] by Moderator
Re: Debugger issues with input functions [message #1023809 is a reply to message #1023429] Mon, 25 March 2013 03:59 Go to previous message
Gerard Grundy wrote on Sun, 24 March 2013 08:10
Yours Sincerely,
Gerard Grundy
There are some open bugs with respect to EOF and debug console.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=159803
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290215
Previous Topic:inedentation line
Next Topic:external tool configuration
Current Time: Thu Nov 06 14:41:37 EST 2025
Powered by FUDForum. Page generated in 0.06158 seconds
