Home » Eclipse Projects » GEF » Looking for a simple example
Looking for a simple example [message #234781] Wed, 30 May 2007 08:13 Go to next message
i am quite new to eclipse, but even more to gef.
i googled and found some examples for creating a "diagram schema editor"
etc.
but these examples are too overloaded to start with (at least for me)
now i am looking for a simple editor that only displays squares with
labels and some connections between them.
best regards,
Ben
Re: Looking for a simple example [message #234790 is a reply to message #234781] Wed, 30 May 2007 08:59 Go to previous messageGo to next message
Originally posted by: mlevison.gmail.com
Ben Herfurth wrote:
> Hello,
> etc.
> best regards,
> Ben
When you downloaded the gef plugins you probably also downloaded an
examples plugin that includes src. Look for a plug-in named:
org.eclipse.gef.examples.source - it contains 4 examples my two
favorites are Shapes and Logic diagram. Shapes is simple enough to
digest with a days worth of playing. Logic is drawing kit for Circuit
logic will take a few more days to digest.
Hope that helps
Mark - who finally spots a question he can answer - Levison
Blog: http://www.notesfromatooluser.com/
Most Popular posts:
Aperture vs. Lightroom - best comparisons
http://www.notesfromatooluser.com/2007/02/aperture_vs_lig.ht ml
Scrum in a Nutshell or 5 minutes to learn Scrum
http://www.notesfromatooluser.com/2006/11/scrum_in_a_nuts.ht ml
Getting Things Done!!! Can't Keep Track of all the tasks you have to do?
Need a better Tool to Implement GTD?
http://www.notesfromatooluser.com/2006/12/getting_things_.ht ml
Re: Looking for a simple example [message #234797 is a reply to message #234790] Wed, 30 May 2007 09:15 Go to previous messageGo to next message
I'll have a look at it,
Thank you :)
Re: Looking for a simple example [message #234890 is a reply to message #234781] Thu, 31 May 2007 13:47 Go to previous messageGo to next message
Hi Ben,
If you search the archives or Google HelloGef1 you will find the HelloGEF
example series that does just that, a simple GEF editor with squares.
I am looking at getting these examples up to date for GEF 3.3 over the
summer, as they have not been updated since GEF 2.1.3.
Cheers...
Anthony
"Ben Herfurth" <b.herfurth@gmx.de> wrote in message
news:ba97da2c194c9f9211e835a57e606b45$1@www.eclipse.org...
> Hello,
> etc.
> best regards,
> Ben
Re: Looking for a simple example [message #235072 is a reply to message #234890] Tue, 05 June 2007 03:49 Go to previous messageGo to next message
ah great, thank you for this.
I'll take a closer look at the example :)
Re: Looking for a simple example [message #235340 is a reply to message #234890] Mon, 11 June 2007 04:43 Go to previous messageGo to next message
so as i see, there is no possibility to get it run under eclipse 3.2?
i imported hellogef1 into a project, and i get some errors, which i cannot
resolve.
Severity and Description Path Resource Location Creation Time Id
Project org.eclipse.gef.examples.hellogef is missing required Java
project: 'org.eclipse.core.boot' org.eclipse.gef.examples.hellogef Build
path 1181551339955 43
project:
'org.eclipse.core.runtime' org.eclipse.gef.examples.hellogef Build
path 1181551339955 42
project: 'org.eclipse.gef' org.eclipse.gef.examples.hellogef Build
path 1181551339955 41
Project org.eclipse.gef.examples.hellogef is missing required library:
'\org.eclipse.draw2d\runtime\draw2d.jar' org.eclipse.gef.examples.hellogef Build
path 1181551339955 44
'\org.eclipse.gef\runtime\gef.jar' org.eclipse.gef.examples.hellogef Build
path 1181551339955 45
The project cannot be built until build path errors are
resolved org.eclipse.gef.examples.hellogef Unknown 1181551339971 46
but they are actually in there ... *shrug*
Re: Looking for a simple example [message #235414 is a reply to message #235340] Tue, 12 June 2007 07:06 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Ben,
Yesterday I tried to run examples from the IBM Redbook about using EMF
with GEF and I had the same problem.
What I did was to go to the properties of the project -> Java Build Path
-> Libraries tab -> Add Library... button (on the right) -> choose
Plug-in Dependencies from the list -> click Next -> click Finish -> go
to the Projects tab -> remove all projects from the list -> click OK
This should make these problems disappear, but I suppose other will
appear ;)
Hope this helps,
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
> cannot resolve.
> Time Id
> org.eclipse.gef.examples.hellogef Build path 1181551339955 43
> project: 'org.eclipse.core.runtime'
> org.eclipse.gef.examples.hellogef Build path 1181551339955 42
> Build path 1181551339955 41
> org.eclipse.gef.examples.hellogef Build path 1181551339955 44
> org.eclipse.gef.examples.hellogef Build path 1181551339955 45
> The project cannot be built until build path errors are resolved
Re: Looking for a simple example [message #235477 is a reply to message #234890] Tue, 12 June 2007 11:04 Go to previous message
Hi Again,
I have posted a new example to
http://www.eclipse.org/gef/reference/digraph1.php .
This first directed graph example is as simple as it gets.
Cheers...
Anthony
"Anthony Hunter" <anthonyh@ca.ibm.com> wrote in message
news:f3n1nl$kcf$1@build.eclipse.org...
> Hi Ben,
> Cheers...
> Anthony
>> Hello,
>> etc.
>> best regards,
>> Ben
Previous Topic:Standalone GEF
Next Topic:Border offset in a Rectangle
Current Time: Mon Jul 28 19:20:56 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
