Home » Language IDEs » ServerTools (WTP) » JSTL 1.1 sql query tag problem
JSTL 1.1 sql query tag problem [message #23279] Sat, 15 May 2004 09:07 Go to next message
Originally posted by: bbozek.email.hinet.hr
JSTL 1.1 sql query tag doesn't work with
"com.microsoft.jdbc.sqlserver.SQLServerDriver" driver.
Does somebody have code that works with that driver and jstl sql query tag?
code example:
<sql:setDataSource
var="ds"
driver="com.microsoft.jdbc.sqlserver.SQLServerDriver"
url="jdbc:microsoft:sqlserver://localhost:1433;DatabaseName=EppCM"
user="test"
password="test" />
<sql:query var="books" dataSource="${ds}">
SELECT * FROM EPP_CM
</sql:query>
exception: "java.sql.SQLException: No suitable driver"
My other applications and JSP pages work with same driver just fine on my
Tomcat 5.0 server.
I found on web that some other people have same problem.
Thanks!
Re: JSTL 1.1 sql query tag problem [message #23470 is a reply to message #23279] Sun, 16 May 2004 05:18 Go to previous messageGo to next message
Originally posted by: annix.sina.com
No suitable driver
Re: JSTL 1.1 sql query tag problem [message #23641 is a reply to message #23279] Mon, 17 May 2004 13:42 Go to previous messageGo to next message
This typically means that the jar file that contains the driver is not
on your classpath. First double check that you haven't mistype the
driver name in your driver string. Even better, remove this information
from your JSP and place into a JNDI lookup using the Tomcat
Adminstrator. Then you the JNDI lookup to get your datasource.
The remember that the Microsoft JDBC driver does NOT support any
database, before SQL 2000. If you are trying to connect to an earlier
database, you will get an error. I did not think that this was the error
it would report, but I might be wrong. You might want to try the jTDS
JDBC driver, see http://jtds.sf.net
HTH,
Jeff Duska
> code example:
> <sql:setDataSource
> var="ds"
> user="test"
> password="test" />
> </sql:query>
> Tomcat 5.0 server.
> Thanks!
Re: JSTL 1.1 sql query tag problem [message #23728 is a reply to message #23641] Tue, 18 May 2004 01:51 Go to previous message
I have remove var from setDataSource and dataSource from query tag.
Now everything works fine.
I have spend few hours to found that problem this morning.
Examples I have found on the web obviously wasn't correct.
Thanks for help anyway.
I will test JNDI lookup also.
FIXED CODE
<sql:setDataSource
user="test"
password="test" />
<sql:query var="books" >
</sql:query>
Branko
"Jeff Duska" <Jeff.Duska@noaa.gov> wrote in message
news:c8at3b$mkv$1@eclipse.org...
> HTH,
> Jeff Duska
tag?
> > code example:
> > <sql:setDataSource
> > var="ds"
> > user="test"
> > password="test" />
> > </sql:query>
my
> > Tomcat 5.0 server.
> > Thanks!
Previous Topic:May 15 Summary of Web Tools Project Proposal
Next Topic:Problem with FTP client
Current Time: Wed Nov 05 04:07:24 EST 2025
Powered by FUDForum. Page generated in 0.04745 seconds
