Home » Archived » OHF » Any patients with documents?
| Any patients with documents? [message #22959] |
Tue, 14 November 2006 17:58  |
I'm working on getting the demo PHP client's document downloading up and
running again. I've made the necessary changes and I'm not getting
errors from the server anymore, which leads me to believe I'm making the
calls correctly.
However, I'm not getting any results back -- no documents found from any
of the 12 RHIOs. Is Joyce Murphy with UUID 'JM19400814' still a valid
test patient? If not, any suggestions?
-Dan
| Re: Any patients with documents? [message #23205 is a reply to message #23127] |
Wed, 15 November 2006 23:05   |
Originally posted by: eishays.us.ibm.com
Got that. I suspect its our bug.
It is strange since in our JUnit we do get the patient IDs and we (and
Practice Partners) had passed the MESA tests using the bridge. We need
to see what the PHP is doing different, I do believe its a bug in the
bridge,
Can you please open a bug with the details?
Eishay
Dan Hale wrote:
> I apologize for the double-post, but I hope this will be useful to you.
> A print_r of the patient search result object appears to show the
> problem. Joyce Murphy is missing the assigning authority data and id
> number in the patientIdentifier object I get back from the RHIO.
> stdClass Object
> [genericAdtValues] =>
> [patientAddress] => stdClass Object
> [city] => Lacrosse
> [country] =>
> [countyParishCode] =>
> [otherDesignation] =>
> [stateOrProvince] => WI
> [streetAddress] => 903 Susan Pl
> [zipOrPostalCode] => 54603
> [patientDateOfBirth] =>
> [patientIdentifier] => stdClass Object
> [assigningAuthorityType] => stdClass Object
> [namespaceId] =>
> [universalId] =>
> [universalIdType] =>
> [universalIdTypeCode] =>
> [useDefaultAssigningAuthority] =>
> [idNumber] =>
> [patientName] => stdClass Object
> [familyName] => Murphy
> [givenName] => Joyce
> [otherName] => Marie
> [prefix] =>
> [suffix] =>
> [patientPhoneBusiness] => stdClass Object
> [unformattedTelephoneNumber] =>
> [patientPhoneHome] => stdClass Object
> [patientSex] =>
> To get that output I added the command below on line 60 of
> OHFPatientSearch.php, right after the check for whether or not the
> patient id is set (which only checks if it was ever set, not if it's
> empty).
> echo "result object: <strong><pre>" . print_r($resultObject, true) .
> "</pre></strong><br/>\n";
> This print happens shortly after $SOAPClient->searchPatients is called,
> which simply passes on the result object from the bridge client, without
> any tampering. So, it doesn't appear anything on the PHP end is failing
> to transcribe the patient id properly and I suspect it's just not being
> set on the server's end.
> Perhaps Joyce's uuid got lost or deleted during database changes to meet
> the new api?
> I hope that's useful.
> -Dan
| Re: Any patients with documents? [message #23231 is a reply to message #23205] |
Thu, 16 November 2006 12:54   |
It was a bug in the PHP which contained some hard coded staff.
See bugzilla for details, committed the code to the CVS.
--eishay
> bridge,
> Eishay
>> stdClass Object
>> [city] => Lacrosse
>> [country] =>
>> [namespaceId] =>
>> [universalId] =>
>> [idNumber] =>
>> [prefix] =>
>> [suffix] =>
>> [patientSex] =>
>> empty).
>> called, which simply passes on the result object from the bridge
>> client, without any tampering. So, it doesn't appear anything on the
>> PHP end is failing to transcribe the patient id properly and I suspect
>> it's just not being set on the server's end.
>> meet the new api?
>> -Dan
| Re: Any patients with documents? [message #23284 is a reply to message #23231] |
Fri, 17 November 2006 09:21   |
I can't seem to find any documents for any patient:
I am using rhio: "lswin10-xds, ibmod235-pix"
documentQueryPreferencesType documentQueryPreferencesType = new
documentQueryPreferencesType();
documentQueryPreferencesType.storedQuery = true;
documentQueryPreferencesType.returnReferencesOnly = true;
patientIdType patientId = new patientIdType();
patientId.assigningAuthorityType = new assigningAuthorityType();
patientId.idNumber = pit.patientIdentifier.idNumber;
patientId.assigningAuthorityType.useDefaultAssigningAuthorit y = true;
queryDocumentsResponseType qdRT =
ohfservice.QueryDocumentsByPatientId( osc, patientId,
documentQueryPreferencesType );
Note: I am using C#
org.eclipse.ohf.ihe.xds.soap.XDSSoapClientException: SOAP FAULT\n\tat
org.eclipse.ohf.ihe.xds.soap.XDSSoapClientAXIS.send(XDSSoapC lientAXIS.java:257)\n\tat
org.eclipse.ohf.ihe.xds.consumer.Consumer.sendQuery(Consumer .java:632)\n\tat
org.eclipse.ohf.ihe.xds.consumer.Consumer.invokeStoredQuery( Consumer.java:390)\n\tat
org.eclipse.ohf.bridge.ihe.IheXdsBridge.goQueryDocumentsByPa tientId(IheXdsBridge.java:117)\n\tat
org.eclipse.ohf.bridge.xds.AbstractXdsBridge.queryDocumentsB yPatientId(AbstractXdsBridge.java:41)\n\tat
org.eclipse.ohf.bridge.ws.OHFBridge.QueryDocumentsByPatientI d(OHFBridge.java:93)\n\tat
sun.reflect.GeneratedMethodAccessor132.invoke(Unknown Source)\n\tat
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)\n\tat
java.lang.reflect.Method.invoke(Unknown Source)\n\tat
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)\n\tat
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)\n\tat
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)\n\tat
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)\n\tat
org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) \n\tat
org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)\n\ta t
org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453)\n\tat
org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )\n\tat
org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)\n\tat
javax.servlet.http.HttpServlet.service(HttpServlet.java:709) \n\tat
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)\n\tat
javax.servlet.http.HttpServlet.service(HttpServlet.java:802) \n\tat
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:139)\n\tat
org.eclipse.equinox.servlet.bridge.http.internal.ServletRegi stration.handleRequest(ServletRegistration.java:78)\n\tat
org.eclipse.equinox.servlet.bridge.http.internal.ProxyServle t.processAlias(ProxyServlet.java:107)\n\tat
org.eclipse.equinox.servlet.bridge.http.internal.ProxyServle t.service(ProxyServlet.java:65)\n\tat
org.eclipse.equinox.servlet.bridge.launcher.BridgeServlet.se rvice(BridgeServlet.java:95)\n\tat
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)\n\tat
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)\n\tat
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)\n\tat
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)\n\tat
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)\n\tat
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)\n\tat
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)\n\tat
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)\n\tat
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)\n\tat
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)\n\tat
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)\n\tat
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:80)\n\tat
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)\n\tat
java.lang.Thread.run(Unknown Source)\n
"Eishay Smith" <eishays@us.ibm.com> wrote in message
news:eji8k8$b7r$1@utils.eclipse.org...
> --eishay
>> Practice Partners) had passed the MESA tests using the bridge. We need to
>> bridge,
>> Thanks,
>> Eishay
>>> stdClass Object
>>> [city] => Lacrosse
>>> [country] =>
>>> [namespaceId] =>
>>> [universalId] =>
>>> [idNumber] =>
>>> [prefix] =>
>>> [suffix] =>
>>> [patientSex] =>
>>> empty).
>>> the new api?
>>> -Dan
| Re: Any patients with documents? [message #23313 is a reply to message #23284] |
Fri, 17 November 2006 09:28   |
or else it always says: "no documents found"
am I doing something wrong?
"Joey Martin" <jpatches23@hotmail.com> wrote in message
news:ejkgh4$br6$1@utils.eclipse.org...
> Note: I am using C#
>> --eishay
>>> bridge,
>>> Thanks,
>>> Eishay
>>>> stdClass Object
>>>> [city] => Lacrosse
>>>> [country] =>
>>>> [namespaceId] =>
>>>> [universalId] =>
>>>> [idNumber] =>
>>>> [prefix] =>
>>>> [suffix] =>
>>>> [patientSex] =>
>>>> empty).
>>>> without any tampering. So, it doesn't appear anything on the PHP end
>>>> is failing to transcribe the patient id properly and I suspect it's
>>>> meet the new api?
>>>> -Dan
| Re: Any patients with documents? [message #23485 is a reply to message #23284] |
Fri, 17 November 2006 13:10   |
SOAP FAULT is very generic and I don't know why it happened.
Can you place a sniffer on your line and check what is the SOAP message
that went over?
Corey did it and it helped us a lot understanding the problem.
--eishay
> Note: I am using C#
>> --eishay
>>> bridge,
>>> Thanks,
>>> Eishay
>>>> stdClass Object
>>>> [city] => Lacrosse
>>>> [country] =>
>>>> [namespaceId] =>
>>>> [universalId] =>
>>>> [idNumber] =>
>>>> [prefix] =>
>>>> [suffix] =>
>>>> [patientSex] =>
>>>> empty).
>>>> the new api?
>>>> -Dan
| Re: Any patients with documents? [message #23613 is a reply to message #23485] |
Fri, 17 November 2006 14:30   |
This one was probably my fault, I was switching networks. It works now, I
can connect to the wsdl.
news:ejktus$rdh$1@utils.eclipse.org...
> that went over?
> --eishay
>> true;
>> Note: I am using C#
>>> --eishay
>>>> bridge,
>>>> Thanks,
>>>> Eishay
>>>>> you.
>>>>> stdClass Object
>>>>> [city] => Lacrosse
>>>>> [country] =>
>>>>> [namespaceId] =>
>>>>> [universalId] =>
>>>>> [idNumber] =>
>>>>> [prefix] =>
>>>>> [suffix] =>
>>>>> [patientSex] =>
>>>>> empty).
>>>>> meet the new api?
>>>>> -Dan
| Re: Any patients with documents? [message #23742 is a reply to message #23699] |
Fri, 17 November 2006 15:03  |
As you wrote, looks like the server got flushed.
Our tests with NIST are fine since we upload and download the same
documents so occasional flushing are not an issue.
We'll upload some documents for testings.
--eishay
| Re: Any patients with documents? [message #572675 is a reply to message #22959] |
Tue, 14 November 2006 19:07  |
Joyce is valid at the "lswin10-xds, ibmod235-pix" RHIO. She has *lots*
of files.
Peter from our group is working on our demo PHP app. You can see some
changes in the PHP code which he starts to modify. If you have
contributions we'll be happy :-)
--eishay
> calls correctly.
> -Dan
| Re: Any patients with documents? [message #572749 is a reply to message #23003] |
Wed, 15 November 2006 14:29  |
> of files.
> --eishay
I was going to submit my code when finished, but it looks like Peter has
already caught up with me. :D
I did notice that in the FindDocumentQueryType class, the member
variable eventCodeList needed to be renamed to eventCodes to properly
follow the spec (and not crash). However, even after that change I get
"No documents found" both in my application and in the demo.
One interesting thing I noticed is Joyce Murphy does not appear to have
an id (or it is not being returned properly, or the wrong value is being
extracted from the response):
The following are your search results.
Murphy, Joyce Marie (ID: ) [all documents]
903 Susan Pl
Lacrosse, WI
Perhaps that's related? I will continue to pick at it to see what I can
do from my end.
-Dan
| Re: Any patients with documents? [message #572772 is a reply to message #23086] |
Wed, 15 November 2006 15:00  |
stdClass Object
[city] => Lacrosse
[country] =>
[namespaceId] =>
[universalId] =>
[idNumber] =>
[prefix] =>
[suffix] =>
[patientSex] =>
patient id is set (which only checks if it was ever set, not if it's empty).
the new api?
-Dan
| Re: Any patients with documents? [message #572833 is a reply to message #23127] |
bridge,
Eishay
> stdClass Object
> [city] => Lacrosse
> [country] =>
> [namespaceId] =>
> [universalId] =>
> [idNumber] =>
> [prefix] =>
> [suffix] =>
> [patientSex] =>
> empty).
> the new api?
> -Dan
| Re: Any patients with documents? [message #572865 is a reply to message #23205] |
--eishay
> bridge,
> Eishay
>> stdClass Object
>> [city] => Lacrosse
>> [country] =>
>> [namespaceId] =>
>> [universalId] =>
>> [idNumber] =>
>> [prefix] =>
>> [suffix] =>
>> [patientSex] =>
>> empty).
>> meet the new api?
>> -Dan
| Re: Any patients with documents? [message #572926 is a reply to message #23231] |
Note: I am using C#
> --eishay
>> bridge,
>> Thanks,
>> Eishay
>>> stdClass Object
>>> [city] => Lacrosse
>>> [country] =>
>>> [namespaceId] =>
>>> [universalId] =>
>>> [idNumber] =>
>>> [prefix] =>
>>> [suffix] =>
>>> [patientSex] =>
>>> empty).
>>> the new api?
>>> -Dan
| Re: Any patients with documents? [message #572957 is a reply to message #23284] |
> Note: I am using C#
>> --eishay
>>> bridge,
>>> Thanks,
>>> Eishay
>>>> stdClass Object
>>>> [city] => Lacrosse
>>>> [country] =>
>>>> [namespaceId] =>
>>>> [universalId] =>
>>>> [idNumber] =>
>>>> [prefix] =>
>>>> [suffix] =>
>>>> [patientSex] =>
>>>> empty).
>>>> meet the new api?
>>>> -Dan
| Re: Any patients with documents? [message #573100 is a reply to message #23284] |
that went over?
--eishay
> Note: I am using C#
>> --eishay
>>> bridge,
>>> Thanks,
>>> Eishay
>>>> stdClass Object
>>>> [city] => Lacrosse
>>>> [country] =>
>>>> [namespaceId] =>
>>>> [universalId] =>
>>>> [idNumber] =>
>>>> [prefix] =>
>>>> [suffix] =>
>>>> [patientSex] =>
>>>> empty).
>>>> the new api?
>>>> -Dan
| Re: Any patients with documents? [message #573205 is a reply to message #23485] |
> that went over?
> --eishay
>> true;
>> Note: I am using C#
>>> --eishay
>>>> bridge,
>>>> Thanks,
>>>> Eishay
>>>>> you.
>>>>> stdClass Object
>>>>> [city] => Lacrosse
>>>>> [country] =>
>>>>> [namespaceId] =>
>>>>> [universalId] =>
>>>>> [idNumber] =>
>>>>> [prefix] =>
>>>>> [suffix] =>
>>>>> [patientSex] =>
>>>>> empty).
>>>>> meet the new api?
>>>>> -Dan
| Re: Any patients with documents? [message #573326 is a reply to message #23699] |
--eishay
Current Time: Sun Nov 16 10:53:01 EST 2025
Powered by FUDForum. Page generated in 0.31545 seconds
