Home » Eclipse Projects » GEF » Thumbnail problem in RC1
Thumbnail problem in RC1 [message #234307] Mon, 21 May 2007 18:09 Go to next message
I am having a problem with my thumbnail in RC1 and wanted to see if
anyone else has it. Basically, the thumbnail image isn't showing. The
selector figure shows up and works, but not the outline. This also
happened in M7, but would show up if you closed/reopened the diagram.
thanks,
adam
Re: Thumbnail problem in RC1 [message #234342 is a reply to message #234307] Tue, 22 May 2007 11:00 Go to previous messageGo to next message
Hi Adam,
What build do you mean? GEF has not published an RC1 build, you must means
Eclipse RC1?
Cheers...
Anthony
"AdamC" <acabler@hotmail.com> wrote in message
news:f2t5ac$dbt$1@build.eclipse.org...
> Hello,
> thanks,
> adam
Re: Thumbnail problem in RC1 [message #234368 is a reply to message #234342] Tue, 22 May 2007 11:37 Go to previous messageGo to next message
Yes, sorry for the confusion. I have tried both eclipse/gef M7 and
eclipse rc1/gef m7.
thanks for the clarification Anthony.
Anthony Hunter wrote:
> Hi Adam,
> Eclipse RC1?
> Cheers...
> Anthony
>> Hello,
>> thanks,
>> adam
Re: Thumbnail problem in RC1 [message #234749 is a reply to message #234342] Tue, 29 May 2007 19:06 Go to previous messageGo to next message
Hi Anthony,
This seems like a serious problem and I'm worried that it could get
out in 3.3 final. Can you confirm that you don't see this in RC2 (I
still do) and if not, do you have any suggestions? Any code in this
area that has changed since M6? One more detail - if I change the
thumbnail to use printable layers (right now, I normally use only the
primary layer), then my connection parts show up, but I still can't see
my diagram.
thanks,
adam
> Hi Adam,
> Eclipse RC1?
> Cheers...
> Anthony
>> Hello,
>> thanks,
>> adam
Re: Thumbnail problem in RC1 [message #234865 is a reply to message #234749] Thu, 31 May 2007 13:22 Go to previous messageGo to next message
Hi Adam
Can you raise a Bugzilla so we can check it out?
Cheers...
Anthony
news:f3ibl2$1g4$1@build.eclipse.org...
> Hi Anthony,
> This seems like a serious problem and I'm worried that it could get out
> in 3.3 final. Can you confirm that you don't see this in RC2 (I still do)
> and if not, do you have any suggestions? Any code in this area that has
> changed since M6? One more detail - if I change the thumbnail to use
> printable layers (right now, I normally use only the primary layer), then
> my connection parts show up, but I still can't see my diagram.
> thanks,
> adam
>> Hi Adam,
>> means Eclipse RC1?
>> Cheers...
>> Anthony
>>> Hello,
>>> thanks,
>>> adam
Re: Thumbnail problem in RC1 [message #234954 is a reply to message #234865] Fri, 01 June 2007 13:07 Go to previous message
--------------010408020103060306030400
Sure - I actually already have one here
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=187158>. I filed this
against the platform since nothing much has changed in GEF, but the
problem got progressively worse in SDK builds starting with M7.
Currently in RC1/2, the diagram never shows up, but in M7, it would show
up if I closed/reopened my editor.
I really wanted to know if anyone else was seeing this. It is a show
stopper for me, but either nobody else is seeing it, or few ppl are
using GEF with 3.3. Also, if it really is in the Platform, I would
think it would effect other uses of the outline.
Anyway, thanks for checking.
adam
> Hi Adam
> Cheers...
> Anthony
>> Hi Anthony,
>> thanks,
>> adam
>>> Hi Adam,
>>> means Eclipse RC1?
>>> Cheers...
>>> Anthony
>>>> Hello,
>>>> thanks,
>>>> adam
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Sure - I actually already have one <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=187158">here</a>.&nbsp;
I filed this against the platform since nothing much has changed in
GEF, but the problem got progressively worse in SDK builds starting
with M7.&nbsp; Currently in RC1/2, the diagram never shows up, but in M7, it
would show up if I closed/reopened my editor.<br>
I really wanted to know if anyone else was seeing this.&nbsp; It is a show
using GEF with 3.3.&nbsp; Also, if it really is in the Platform, I would
think it would effect other uses of the outline.<br>
<br>
Anyway, thanks for checking.<br>
<br>
adam<br>
<br>
<blockquote cite="mid:f3n090$72q$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Adam
Cheers...
Anthony
"AdamC" <a class="moz-txt-link-rfc2396E" href="mailto:acabler@hotmail.com">&lt;acabler@hotmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:f3ibl2$1g4$1@build.eclipse.org">news:f3ibl2$1g4$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Anthony,
thanks,
adam
</pre>
<pre wrap="">Hi Adam,
means Eclipse RC1?
Cheers...
Anthony
<a class="moz-txt-link-freetext" href="news:f2t5ac$dbt$1@build.eclipse.org">news:f2t5ac$dbt$1@build.eclipse.org</a>...
</pre>
<pre wrap="">Hello,
thanks,
adam
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010408020103060306030400--
Previous Topic:SelectionAction.dispose()
Next Topic:KeyHandler for Cut, Copy, Paste
Current Time: Sat Jul 26 10:51:40 EDT 2025
Powered by FUDForum. Page generated in 0.08730 seconds
