Home » Archived » BIRT » BIRT designer stuck when trying to produce a scripted data source with JNDI context
BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #232634] |
Fri, 06 April 2007 06:42  |
Originally posted by: ruby.boyarski.verix.com
hi,
Scripted data sources are great and worked for me when trying to use simple
scenarios (POJOs).
Now I am trying to call an EJB from a scripted data source.
Here's part of the code in the "open" method:
p = new Packages.java.util.Properties();
p.put("java.naming.factory.initial",
"org.jnp.interfaces.NamingContextFactory");
p.put("java.naming.provider.url", "localhost:51099");
initContext = new Packages.javax.naming.InitialContext(p);
In the last line the BIRT studio just gets "stuck" with no response when
clicking the "preview" tab.
When putting these lines in a class file and running it from a "Main" it
works just fine.
When calling the class from the script code the same phenomenon happens -
stuck.
Anyone has an idea how to solve this problem?
Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234097 is a reply to message #234076] |
Thu, 12 April 2007 11:18   |
Here is the text in the "open" method of the scripted data set:
invoker = "";
p.put("java.naming.provider.url", "ami-pc:21099");
objref = initContext.lookup("ejb/GeneralServices"); // Here the
exception happens (the first exception)
data = "11";//invoker.makeCall();
totalRows=1;
currentRow=0;
The exception occurs in the lookup line.
The same code works when in a java Main.
I attached the log file (look at the first exception - connection issue. The
second one is a result of the first).
thanks,
Ruby
"news://news.eclipse.org/eclipse.birt" <ruby.boyarski@verix.com> wrote in
message news:evlgi5$5ov$1@build.eclipse.org...
> Sure.
> What is the easiest way to log text? (I tried using System.out but
> couldn't)
> "Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
> news:evlfeb$tj5$1@build.eclipse.org...
>> Can you try a couple to things.
>> In your oda specifically log the URL before it gets used.
>> Run the script version again and attach the log and report.
>> Thanks
>> Jason
>> news://news.eclipse.org/eclipse.birt wrote:
>>> Same happens when using an ODA data source (with the same code -
>>> invoking
>>> an EJB).
>>> I attached the log.
>>> I have a similiar thread in the "eclipse.dtp" named "ODA driver for EJB
>>> access". Linda Chan answered me there saying that you may be able to
>>> provide help for the same problem (same problem happens in ODA driver
>>> and
>>> scripted data source).
>>> For some reason the designer "thinks" that the lookup URL is
>>> " Files/Actuate9/BRDPro/eclipse/plugins/org.eclipse.birt.repor t.viewer_2.1.2.v20061218-0710/birt/WEB-INF/classes/] "
>>> although I haven't specified it anywhere... (the real lookup is my own
>>> string "ejb/GeneralServices")
>>> Thanks for the help,
>>> Ruby
>>> news:evg9h5$8jp$1@build.eclipse.org...
>>>> Can you turn on logging in the Viewer plugin web.xml?
>>>> Post the log when the error happens.
>>>> Also can you preview the data set?
>>>> Jason
>>>>> It happens when previewing the report.
>>>>> The screen is just stuck and no output is shown.
>>>>> Thanks,
>>>>> Ruby
>>>>> news:evdtp6$nam$2@build.eclipse.org...
>>>>>> Does the error happen when you preview the report or the dataset?
>>>>>> Jason
>>>>>>> hi,
>>>>>>> simple scenarios (POJOs).
>>>>>>> when
>>>>>>> "Main"
>>>>>>> it
>>>>>>> works just fine.
>>>>>>> happens -
>>>>>>> stuck.
>>>>>>> Cheers,
>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234203 is a reply to message #234097] |
Thu, 12 April 2007 12:30   |
Originally posted by: jasonweathersby.alltel.net
Ruby,
Can you try installing BRDPro or OS BIRT in a path that has no spaces.
I assume this
should be c:\Program Files?
Run the same example and let us know what happens.
Jason
> invoker = "";
> totalRows=1;
> currentRow=0;
> thanks,
> Ruby
>> Sure.
>> couldn't)
>>> Thanks
>>> Jason
>>>> invoking
>>>> an EJB).
>>>> I attached the log.
>>>> and
>>>> Ruby
>>>>> Jason
>>>>>> Thanks,
>>>>>> Ruby
>>>>>>> Jason
>>>>>>>> hi,
>>>>>>>> when
>>>>>>>> "Main"
>>>>>>>> it
>>>>>>>> works just fine.
>>>>>>>> happens -
>>>>>>>> stuck.
>>>>>>>> Cheers,
>>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234525 is a reply to message #234203] |
Fri, 13 April 2007 13:42   |
I have done what you suggested and it worked like a charm! :-)
Now I have a problem deploying it to the iServer (actually, the problem is
in accessing the data source using the iPortal). I guess I should turn to
Actuate's support for that...
Thanks a lot for your support.
Ruby
news:evlmp5$tiv$1@build.eclipse.org...
> Ruby,
> I assume this
> Jason
>> invoker = "";
>> totalRows=1;
>> currentRow=0;
>> The second one is a result of the first).
>> thanks,
>> Ruby
>>> Sure.
>>> couldn't)
>>>> Thanks
>>>> Jason
>>>>> invoking
>>>>> an EJB).
>>>>> I attached the log.
>>>>> EJB
>>>>> and
>>>>> Ruby
>>>>>> Jason
>>>>>>> Thanks,
>>>>>>> Ruby
>>>>>>>> Jason
>>>>>>>>> hi,
>>>>>>>>> use
>>>>>>>>> response
>>>>>>>>> when
>>>>>>>>> "Main"
>>>>>>>>> it
>>>>>>>>> works just fine.
>>>>>>>>> happens -
>>>>>>>>> stuck.
>>>>>>>>> Cheers,
>>>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234816 is a reply to message #234525] |
Mon, 16 April 2007 11:36  |
Ruby,
Glad to hear this worked. The iPortal question is probably better
posted on Actuate's support site.
Jason
> Ruby
>> Ruby,
>> I assume this
>> Jason
>>> invoker = "";
>>> totalRows=1;
>>> currentRow=0;
>>> thanks,
>>> Ruby
>>>> Sure.
>>>> couldn't)
>>>>> Thanks
>>>>> Jason
>>>>>> invoking
>>>>>> an EJB).
>>>>>> I attached the log.
>>>>>> EJB
>>>>>> and
>>>>>> Ruby
>>>>>>> Jason
>>>>>>>> Thanks,
>>>>>>>> Ruby
>>>>>>>>> Jason
>>>>>>>>>> hi,
>>>>>>>>>> use
>>>>>>>>>> response
>>>>>>>>>> when
>>>>>>>>>> "Main"
>>>>>>>>>> it
>>>>>>>>>> works just fine.
>>>>>>>>>> happens -
>>>>>>>>>> stuck.
>>>>>>>>>> Cheers,
>>>>>>>>>> Ruby
Current Time: Tue Jul 22 01:58:06 EDT 2025
Powered by FUDForum. Page generated in 1.47751 seconds
