Retargetable copy and paste action [message #233892] |
Fri, 04 May 2007 04:43  |
I have a functioning GEF Editor, and I wanted to add copy and paste
functionality (cloning, to be specific). But I have a couple questions.
I've implemented the copy and paste actions, I have added them to the
context menu and they work fine.
However, the enablement of the copy/paste actions in the menu behave
strangely and do not match the enablement of the actions in my context
menu. Here's how I add them to the context menu:
menu.appendToGroup(GEFActionConstants.GROUP_COPY,
getAction(ActionFactory.COPY.getId()));
getAction(ActionFactory.PASTE.getId()));
I have registered the actions in the editor, and I am using the
ActionFactory.COPY.getId() and the ActionFactory.PASTE.getId().
addSelectionAction(registry, new CopyProcessesAction(this));
addSelectionAction(registry, new PasteProcessesAction(this));
private void addSelectionAction(ActionRegistry registry, IAction action)
registry.registerAction(action);
getSelectionActions().add(action.getId());
Is there something else I need to do in order to get the copy and paste
items in the menu (as well as the Ctrl+C, Ctrl+V commands) to enable
properly? Currently, when they are enabled, they work properly, so I know
that I have it set up at least partly in the right way. About half the
time, though, the copy command is disabled in the main menu, even when the
copy command in the context menu is enabled.
Re: Retargetable copy and paste action [message #233932 is a reply to message #233892] |
Fri, 04 May 2007 10:37   |
Hi Dan,
You need to register these actions with the GlobalActionHandler. Look for
setGlobalActionHandler() for examples.
Cheers...
Anthony
"Dan Phifer" <dan.phifer@gmail.com> wrote in message
news:514188cbf1bad49e2b9eaf8897b0a455$1@www.eclipse.org...
Re: Retargetable copy and paste action [message #233939 is a reply to message #233932] |
Fri, 04 May 2007 11:59  |
Great thanks. It works fine now. However, I have been working from the
Logic example, and now I am wondering about what the
handleActivationChange method does:
protected void handleActivationChanged(Event event)
IAction copy = null;
if (event.type == SWT.Deactivate)
copy = getActionRegistry().getAction(ActionFactory.COPY.getId());
if
(getEditorSite().getActionBars().getGlobalActionHandler(Acti onFactory.COPY.getId())
!= copy)
getEditorSite().getActionBars().setGlobalActionHandler(Actio nFactory.COPY.getId(),
copy);
getEditorSite().getActionBars().updateActionBars();
This seems to say, if the event is not SWT.Deativate, then set the global
handler to null and if it IS Deactivate, then set the handler to our copy
action. It seems like it should be the other way around... what am I
missing?
FUDForum. Page generated in 0.05193 seconds
