Home » Modeling » GMF (Graphical Modeling Framework) » Add sub-nodes programmatically after creating node (GMF 2.2)
Add sub-nodes programmatically after creating node (GMF 2.2) [message #233871] Wed, 17 June 2009 05:41 Go to next message
When creating a node using palette, I display a wizard, and depending on
the users selection I add sub-elements to the newly created node
(displayed as border items).
I realized this with a custom CreateCommand, where I add the sub-elements
after the parent node has been created. This worked fine with GMF 2.1.3.
With GMF 2.2 it seems to work too, sub-nodes are displayed properly. But
when I save, close and reopen my diagram, the sub-nodes are not displayed
any more.
I have split diagram/model files. The sub-elements are in the model file
but they seem to be missing in the diagram file.
Is there a better way to create the sub-nodes?
Is this a bug?
Thanks in advance!
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #233891 is a reply to message #233871] Wed, 17 June 2009 06:31 Go to previous messageGo to next message
Hello Peter,
> But when I save, close and reopen my diagram, the sub-nodes are not
> displayed any more.
What if you create such an element (having corresponding sub-nodes), select
it and press F5 (canonical update)?
Will corresponding sub-nodes be deleted from diagram?
Alex Shatalin
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #233899 is a reply to message #233891] Wed, 17 June 2009 07:27 Go to previous messageGo to next message
Hello Alex,
>> displayed any more.
Pressing F5 after creating the element does not seem to help. When I
reopen the diagram, the sub-nodes are still missing.
When I select my parent-node then and press F5, the sub-nodes reappear.
The diagram file does not get "dirty" though (no asterisk before filename).
Moving my node to mark the diagram "dirty" and saving then does not help,
sub-nodes are still missing after restarting the application.
Another strange thing:
When I just close the diagram file and reopen it without restarting the
application, sub-nodes are still displayed. Only when I restart the
application and reopen the file, the sub-nodes are gone. Is there
something cached?
Regards, Peter
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #233914 is a reply to message #233899] Wed, 17 June 2009 07:43 Go to previous messageGo to next message
Hello Peter,
> the
> something cached?
ok. Looks like a problem described in: https://bugs.eclipse.org/bugs/show_bug.cgi?id=261188
To workaround this problem you can remove object/context constraints (xml
tags) from viewProvder declaration generated into plugin.xml
Alex Shatalin
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #233937 is a reply to message #233914] Wed, 17 June 2009 08:28 Go to previous messageGo to next message
Hi Alex,
>> the
>> something cached?
You're definitely right. It works now, thanks a lot ;-)
What are the side-effects of this workaround?
Btw, instead of changing the generated plugin.xml, I copied the extension
point to my custom plugin.xml, raising priority and removing
object/context there. Should have the same effect, right?
When migrating to GMF 2.2, I was really glad I had not changed much within
the generated sources...
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #233997 is a reply to message #233937] Wed, 17 June 2009 13:08 Go to previous messageGo to next message
Hello Peter,
Generated diagram editor plugin will be loaded to instantiate Viewprovider
on first View (diagram element) created on any other GMF-based diagram deployed
to the platform.
> extension
Should be the same.
Alex Shatalin
Re: Add sub-nodes programmatically after creating node (GMF 2.2) [message #234392 is a reply to message #233997] Mon, 22 June 2009 04:07 Go to previous message
deployed
> to the platform.
Should not be a problem for my application.
Thank you very much, Alex!
Previous Topic:Drag and Drop within the diagram editor
Next Topic:Copy & Paste, CopyPaste, Duplication
Current Time: Sun Jul 27 02:25:47 EDT 2025
Powered by FUDForum. Page generated in 0.06461 seconds
