Home » Eclipse Projects » GEF » EditPart selection feedback
EditPart selection feedback [message #233127] Tue, 17 April 2007 12:22 Go to next message
Originally posted by: michele.l.evinco.it
I want to change the backgroud color of the an editpart when i click on
it so i've written this code in createEditPolicies of my editpart:
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE,
new SelectionEditPolicy(){
protected void hideSelection() {
((AntennaFigure)getFigure()).setOpaque(true);
((AntennaFigure)getFigure()).setBackgroundColor(org.eclipse. draw2d.ColorConstants.black);
protected void showSelection() {
((AntennaFigure)getFigure()).setOpaque(false);
((AntennaFigure)getFigure()).setBackgroundColor(org.eclipse. draw2d.ColorConstants.white);
When i click on the figure that rappresent my editpart notthing appends
and the code of showSelection is never executed.
My way is correct?
What 's the best way to do this?
When an editPart is Selected? on mouse click?
Thank's
Michele
Re: EditPart selection feedback [message #233135 is a reply to message #233127] Tue, 17 April 2007 20:24 Go to previous messageGo to next message
hi
My way to do it would be to create a resizableEditPolicy
and override the method
protected IFigure createDragSourceFeedbackFigure()
where you create the feedback figure (that would be the same figure with
a different background)
> My way is correct?
> Thank's
> Michele
Re: EditPart selection feedback [message #233151 is a reply to message #233135] Wed, 18 April 2007 04:37 Go to previous messageGo to next message
Thank you for your reply David,
i've try with your way but when i click or double click on the figure
the code of createDragSourceFeedbackFigure() is never executed.
I've register it as EditPolicy.SELECTION_FEEDBACK_ROLE.
How do you register it?
Sun Seng David TAN wrote:
> hi
>> on it so i've written this code in createEditPolicies of my editpart:
>> appends and the code of showSelection is never executed.
>> My way is correct?
>> Thank's
>> Michele
Re: EditPart selection feedback [message #233191 is a reply to message #233151] Wed, 18 April 2007 21:28 Go to previous messageGo to next message
mh ... :S
that's the way im registering it ....
but that works when you try to drag the figure, im not sure if it is
really what you want to do
>> hi
>> with a different background)
>>> My way is correct?
>>> Thank's
>>> Michele
Re: EditPart selection feedback [message #233199 is a reply to message #233151] Wed, 18 April 2007 22:07 Go to previous messageGo to next message
So ....
i'm registering it from the parent layoutEditPolicy from the method
createChildEditPolicy.. if you have a look to the Logic diagram example
you will find in the class
org.eclipse.gef.examples.logicdesigner.edit.LogicXYLayoutEdi tPolicy the
way to do it :
protected EditPolicy createChildEditPolicy(EditPart child) {
if (child instanceof LEDEditPart
|| child instanceof OutputEditPart) {
ResizableEditPolicy policy = new LogicResizableEditPolicy();
policy.setResizeDirections(0);
return policy;
} else if (child instanceof LogicLabelEditPart) {
policy.setResizeDirections(PositionConstants.EAST |
PositionConstants.WEST);
return policy;
return new LogicResizableEditPolicy();
>> hi
>>> My way is correct?
>>> Thank's
>>> Michele
Re: EditPart selection feedback [message #233229 is a reply to message #233199] Thu, 19 April 2007 04:15 Go to previous messageGo to next message
thank's David for your replay,
I've find this solution :
i've register my SelectionEditPolicy as EditPolicy.SELECTION_FEEDBACK_ROLE.
then in the edit part i've add a EditPartListener and implement his
selectedStateChanged method where i change the background of figure.
I don't know if this is the right way to do that but it work.
Bye
Michele
> So ....
> way to do it :
> return policy;
> return policy;
>>> hi
>>>> My way is correct?
>>>> Thank's
>>>> Michele
Re: EditPart selection feedback [message #233237 is a reply to message #233229] Thu, 19 April 2007 04:27 Go to previous message
correction:
It works without register the policy.
In the deactivate method of editpart i must remove the listener
otherwise an errror will be generated.
> Bye
> Michele
>> So ....
>> example you will find in the class
>> the way to do it :
>> return policy;
>> return policy;
>>>> hi
>>>>> click on it so i've written this code in createEditPolicies of my
>>>>> editpart:
>>>>> My way is correct?
>>>>> Thank's
>>>>> Michele
Previous Topic:Add decoration to EditPart?
Next Topic:change the color of the editor background
Current Time: Tue Jul 29 00:08:53 EDT 2025
Powered by FUDForum. Page generated in 0.10268 seconds
