Home » Modeling » GMF (Graphical Modeling Framework) » Copy & Paste, CopyPaste, Duplication
Copy & Paste, CopyPaste, Duplication [message #232294] Thu, 04 June 2009 04:08 Go to next message
I know there are lots of threads and bugzillas addressing this issue (and
I guess I've read most of them), but I did not get it to work.
https://bugs.eclipse.org/263226
[CopyPaste] Copy action does not work anymore
https://bugs.eclipse.org/176007
Edit/(Duplication | Copy&PasteDuplication) corrupts notation model
I tried it with Taipan application (split model/diagram files):
- Create new Ship
- Copy/Paste Ship
- Delete new Ship from Model
The model is broken, and when I save it and try to load again, it will
even welcome me with a nice exception:
java.lang.ClassCastException:
org.eclipse.emf.ecore.util.EObjectContainmentEList cannot be cast to
java.lang.String
As far as I can see, UUIDs should be enabled in
...taipan.gmf.editor.rcp/plugin.xml, but that does not seem to have an
effect:
<extension point="org.eclipse.emf.ecore.extension_parser">
<?gmfgen generated="true"?>
<parser
type="taipan_diagram"
class=" org.eclipse.gmf.runtime.emf.core.resources.GMFResourceFactor y ">
</parser>
</extension>
Another strange thing is, that it works as expected when I drag/drop the
node pressing Ctrl. A deep copy of the node is created.
XxxClipboardSupport does not seem to get used for this, except for
notifying (sendCreateNotification).
Can I maybe make use of this behavior?
Has anyone managed to get Copy&Paste working with split model/diagram
files?
Will a custom ClipboardSupport help me at all?
Any help highly appreciated, thanks in advance!
Re: Copy & Paste, CopyPaste, Duplication [message #232396 is a reply to message #232294] Thu, 04 June 2009 10:38 Go to previous messageGo to next message
Hello Peter,
> effect:
> <parser
> </parser>
> </extension>
This means UUID support is switched on for *.taipan_diagram resoruces (diagram
files). To make cut/copy/paste functionality working you have to switch on
this support for *.taipan resources too.
> the node pressing Ctrl. A deep copy of the node is created.
Is it something like "edit/duplicate" action from the popup menu?
Alex Shatalin
Re: Copy & Paste, CopyPaste, Duplication [message #232609 is a reply to message #232396] Fri, 05 June 2009 07:21 Go to previous messageGo to next message
Thanks Alex, see below...
>> effect:
>> <parser
>> </parser>
>> </extension>
> (diagram files). To make cut/copy/paste functionality working you have
> to switch on this support for *.taipan resources too.
You're right, of course!
Enabling UUID support for *.taipan did not solve the problem though (I
checked model file, UUIDs are used now). Same problem as before.
With RCP version (org.eclipse.gmf.examples.taipan.gmf.editor.rcp) it
even raises an exception now when I try to copy a node.
Not sure how to debug this, I paused the application in the error dialog
which provides no stacktrace and looked into the exception, so the
following stacktrace is handwritten :)
at
org.eclipse.gmf.runtime.common.ui.util.StatusLineUtil.getSta tusLineManager(StatusLineUtil.java:90)
at
org.eclipse.gmf.runtime.common.ui.util.StatusLineUtil.output ErrorMessage(StatusLineUtil.java:48)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:357)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator(BusyIndicator.java:70)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager(Actio nManager.java:223)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er(AbstractActionHandler.java
Can you reproduce this?
Simple add UUID-support to the TaiPan RCP example and run, then copy a node.
Yes, duplication seems to be the same Ctrl+DnD. I was not even aware of
that function. This could be sufficient for some requirements, but not
for all...
Am I doing something wrong, or does Copy&Paste simply not work with
split model/diagram files?
If so, is there anything I can do?
Regards, Peter
Re: Copy & Paste, CopyPaste, Duplication [message #232645 is a reply to message #232609] Fri, 05 June 2009 07:28 Go to previous messageGo to next message
Hello Peter,
We do not generate D&D support, so it came from runtime libraries. We have
a request to cover D&D by generation, but it is not done yet. We use generic
runtime D&D support and it was claimed it is working with UUID switched on.
So, you can either implement D&D by your own or wait till it will be covered
by generation process.
Alex Shatalin
Re: Copy & Paste, CopyPaste, Duplication [message #232676 is a reply to message #232645] Fri, 05 June 2009 07:38 Go to previous messageGo to next message
> have a request to cover D&D by generation, but it is not done yet. We
> use generic runtime D&D support and it was claimed it is working with
> UUID switched on. So, you can either implement D&D by your own or wait
> till it will be covered by generation process.
Hi Alex,
I do not need DnD support, I just mentioned that it works almost as I
would expect copy&paste to work (same as Duplicate).
What I would have expected was standard copy&paste support which does
not seem to work.
So the initial questions remain:
Has anyone managed to get Copy&Paste working with split model/diagram files?
Regards, Peter
Re: Copy & Paste, CopyPaste, Duplication [message #232715 is a reply to message #232676] Fri, 05 June 2009 09:08 Go to previous messageGo to next message
Hello Peter,
Sorry, all I wrote was about Cut/Copy/Paste. :-)
Alex Shatalin
Re: Copy & Paste, CopyPaste, Duplication [message #233062 is a reply to message #232715] Tue, 09 June 2009 07:09 Go to previous messageGo to next message
Thanks Alex, at least I know now, that it's not supposed to work :-)
Since bugzilla https://bugs.eclipse.org/263226 seems to describe exactly
the problem I encounter, any idea on when this issue will be addressed?
And any hint, where I would have to start with my own copy/paste
implementation?
Regards, Peter
Re: Copy & Paste, CopyPaste, Duplication [message #233070 is a reply to message #233062] Tue, 09 June 2009 07:39 Go to previous messageGo to next message
Hello Peter,
You can vote for this request. By voting for it you are showing it's important
for you.
> implementation?
Well, AFAIR it's not so easy to modify/correct existing copy/paste implementation,
so i think you can try completely substituting existing implementation by
your own.
See DiagramUIRenderGlobalActionHandlerProvider (this class should be registered
into org.eclipse.gmf.runtime.common.ui.services.action.globalActi onHandlerProviders
extension point inside generated plugin.xml)
Alex Shatalin
Re: Copy & Paste, CopyPaste, Duplication [message #233222 is a reply to message #233062] Wed, 10 June 2009 05:07 Go to previous messageGo to next message
This post :
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg16777.html
will lead you to an EclipseBased application, Moskitt. As it says, it
implements its own copy&paste, and that might be a good point to begin.
I found that really useful.
> implementation?
> Regards, Peter
Re: Copy & Paste, CopyPaste, Duplication [message #234399 is a reply to message #233222] Mon, 22 June 2009 04:09 Go to previous message
Thanks a lot, I will have a look at it, as soon as I have some time...
Javier wrote:
> This post :
>> implementation?
>> Regards, Peter
Previous Topic:Add sub-nodes programmatically after creating node (GMF 2.2)
Next Topic:Problem opening ecore_diagram file/dynamic diagram generation
Current Time: Mon Jul 28 16:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
