XML Schema Editor says the type from an XML-Catalog-Referenced schema is invalid [message #233137] |
Tue, 30 June 2009 11:20  |
Hello!
I have an XSD (called Test) in a jar somewhere on my disk. Targetnamespace
of the XSD is "test".
I add it to XML Catalog with this key:
"specialprefix:testjar/test/test.xsd". Key type is schemalocation.
I also have an XSD (called Importer) in my eclipse workspace and I import to
it the xsd mentioned before.
Schemalocation of the import is "specialprefix:testjar/test/test.xsd", as it
is set in the Catalog.
xmlns prefix is set to "test" in the xsd:schema tag.
After doing this, when I create a new element in Importer and press CTRL +
Space in the type attribute of it, I can see the types defined by Test (in a
"test: ..." form). This is OK.
But when I save Importer it says that the type is invalid.
So it seems the content assist mechanism resolves XML Catalog entries but
the element/type validation mechanism does not.
Is it a bug? Is it may be reported to bugzilla?
Istvan
Re: XML Schema Editor says the type from an XML-Catalog-Referenced schema is invalid [message #233161 is a reply to message #233153] |
Wed, 01 July 2009 06:12   |
------=_NextPart_000_00C7_01C9FA45.34A907B0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Sorry if my description was not so clear.
The concrete problem was solved, but a strange "thing" still exists.
I attached a zip file, the comments in testimport.xsd describe the
situation.
thanks,
Istvan
"Valentin" <valentinbaciu@hotmail.com> wrote in message
news:h2f2h5$ppm$1@build.eclipse.org...
> Hi Istvan, perhaps you can attach a simple example project with your
> schema and the jar? If they are proprietary attach some mocked up sample
> schemas instead. If you are contributing to the user catalog, export it
> and attach it here. If you are contributing to the sytem catalog using the
> catalog extension point please attach that extension. We'll try to help
> once we understand your scenario better.
> Regards, Valentin
> "Istvan" <acereg@citromail.hu> wrote in message
> news:h2dagn$uku$1@build.eclipse.org...
>> Hello!
>> Targetnamespace of the XSD is "test".
>> to it the xsd mentioned before.
>> it is set in the Catalog.
>> + Space in the type attribute of it, I can see the types defined by Test
>> (in a "test: ..." form). This is OK.
>> Thanks,
>> Istvan
Content-Type: application/x-zip-compressed;
name="xsd_xmlcatalog_test.zip"
filename="xsd_xmlcatalog_test.zip"
UEsDBAoAAAAAAAVX4Tor0Cce4gIAAOICAAAIAAAAdGVzdC5qYXJQSwMEFAAC AAAAo1PhOgAAAAAA
AAAAAAAAAAkAAABNRVRBLUlORi9QSwMEFAACAAgA9FbhOhIpELUsAAAANgAA ABQAAABNRVRBLUlO
Ri9NQU5JRkVTVC5NRvNNzMtMSy0u0Q1LLSrOzM+zUjDUM+DlcsxDEnEsSEzO SFUAigElzfRMebkA
UEsDBBQAAgAAAIpT4ToAAAAAAAAAAAAAAAAFAAAAdGVzdC9QSwMEFAACAAgA W1ThOopkBqwSAQAA
GQIAAA0AAAB0ZXN0L3Rlc3QueHNkdZFdS8MwFIavFfwPIfc2nXohY9luVBho EazgbdYds0CT1OT0
w39v2mR0U4Te9OU8z3kPWW0GXZMOnFfWcLrIckrAVHavjOT0vXy6vqeb9dXl avD7pa8OoAVB4SRg
ITT4RlTAKYJHSoLI+LOfZYA4PSA2S8b6vs/628w6yW7yfME+Xp7fJh8N+ovw TSugBg0GiQl2Tsvg
eozJNBVnKqubGobyu4EpjKmHrzY0T9G5zcEnp6/bomj1DhxlCWN/uBj9WhDD 5Pq/7OwnGEhOzcm2
I+LVqB7NiUpD83Uu3OxUheE9yE74MDKmxpoCpEDVwdYgyCMSGbQo6gclFXrS iboN0F26MpY/kc4X
zV1iw5ROj7L+AVBLAQIUABQAAgAAAKNT4ToAAAAAAAAAAAAAAAAJAAAAAAAA AAAAMAAAAAAAAABN
RVRBLUlORi9QSwECFAAUAAIACAD0VuE6EikQtSwAAAA2AAAAFAAAAAAAAAAA ACAAAAAnAAAATUVU
QS1JTkYvTUFOSUZFU1QuTUZQSwECFAAUAAIAAACKU+E6AAAAAAAAAAAAAAAA BQAAAAAAAAAAADAA
AACFAAAAdGVzdC9QSwECFAAUAAIACABbVOE6imQGrBIBAAAZAgAADQAAAAAA AAAAACAAAACoAAAA
dGVzdC90ZXN0LnhzZFBLBQYAAAAABAAEAOcAAADlAQAAAABQSwMEFAAAAAgA KmDhOlffm6hKAgAA
TQQAAA4AAAB0ZXN0aW1wb3J0LnhzZIWUTU/cMBCGz0HiPww+gbpJoL1UFgtq QZVWhR5gUXvg4nVm
s6aJnXqcDfn3jB0+26qVstnEM/PMOzN2jk/v2wa26Mk4OxdHxaEAtNpVxtZz cbP8kn8Upye7O8f3
VEnSG2wVBOVrDN9Ui9QpjXMRkIJpO+eDAMZZ+suSZMBcbELoZFkOw1AMHwrn 6/L94eFR+ePy4jqx
BezuZJN/JEwcwfl5OUmYmGDfJhcwSbtwWoVUCHWojWoSpbhTvowP6VYwRpQn EbiX5/y33CD8zx8M
AWEAY4G1wpkKqnE1BA5du6ZxA7cLBjVK5vH1pENmkXD7hInhzIa1aRDOJa+3 3e2LB5s49uZqIQEg
y/hVRk95Lsvo+UoSm/beKuTArzjCcuxQZs+jgfg0mWSW/btGdoM8f2z11Jnv G7SwgM4jEZwtry7g
HVwnLhcSaw+cjrdDPYM0Bmn7doU+dUttlWnUqsFiasknW4F1A+MIcZaisTLB eagcEpsCkBrpN5BW
NlpWCKzBNVusCthfhJggEpSlAT0EB+0Iv/q457jpYAIMzv+kWXwyE1zBqq8P HsV87tMoXe+5OHeH
OiSeZyL/yLXImYllDWnxldikMb57XLPJaqymLvypdMaJhk0ctQ6+4dZNIxFJ Gm8b/9xCAfuJwVLd
OmLTTtHOBrQhV0SGQt7w7aCA5Ya9BkVQocYumC0mVPvU50s1rqJi9uJLq56Y thrBxfpAG6/7loJi
4RQj0sSno4UNtpwvna25WKSDhn6papFEzt9Mpkwb5bh8+SzwwgNQSwECFAAK AAAAAAAFV+E6K9An
HuICAADiAgAACAAAAAAAAAAAACAAAAAAAAAAdGVzdC5qYXJQSwECFAAUAAAA CAAqYOE6V9+bqEoC
AABNBAAADgAAAAAAAAABACAAAAAIAwAAdGVzdGltcG9ydC54c2RQSwUGAAAA AAIAAgByAAAAfgUA
AAAA
------=_NextPart_000_00C7_01C9FA45.34A907B0--
FUDForum. Page generated in 0.10149 seconds
