Home » Archived » Riena » No authentication service
No authentication service [message #23154] Mon, 23 March 2009 02:58 Go to next message
I
Re: No authentication service [message #23193 is a reply to message #23154] Mon, 23 March 2009 05:57 Go to previous messageGo to next message
Carsten Spieker wrote:
Hi Carsten,
which example are you using? Did you try launcher SWT SCP
ExampleApplication.product (client) and Riena Sample App Server? Which
riena version are you using? Could you please provide a stacktrace?
Regards, Frank
> I´m playing around with the Riena sample applications.
> When I try to learn more about the riena login support I´m reaching my
> limits quite early.
> I always get the message "Log-in failed" which is caused by an
> LoginException "No authentication service".
> I´m quite new to riena and Java Security. Can anyone help me understanding
> or simply using the login support?
> Thanks and greetz
> Carsten
Re: No authentication service [message #23307 is a reply to message #23193] Mon, 23 March 2009 06:24 Go to previous messageGo to next message
Hi Frank,
I use the product "example_product" defined in plugin
"org.eclipse.riena.example.client".
I cannot find the launcher you mentioned. Where can I find it?
Here the stacktrace the Sample App Server gives:
WARNUNG:
org.eclipse.riena.security.common.authentication.Authenticat ionFailure:
AuthenticationService login failed
at
org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:146)
at
at
at
org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:69)
at
org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:38)
at
org.eclipse.riena.internal.communication.publisher.ServiceHo oksProxy.invoke(ServiceHooksProxy.java:70)
at $Proxy13.login(Unknown Source)
at
at
at
com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkel eton.java:155)
at
org.eclipse.riena.communication.publisher.hessian.RienaHessi anDispatcherServlet.service(RienaHessianDispatcherServlet.ja va:147)
at
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:67)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Caused by: javax.security.auth.login.LoginException: F
Re: No authentication service [message #23349 is a reply to message #23307] Mon, 23 March 2009 06:24 Go to previous messageGo to next message
I
Re: No authentication service [message #23394 is a reply to message #23307] Mon, 23 March 2009 10:37 Go to previous messageGo to next message
Hi Carsten,
sorry, the launcher i wanted to mentioned is also in
org.eclipse.riena.example.client and is named SWT
ExampleApplication.product.launch. Please can you check/make sure that
also the following VM argument
-Djava.security.auth.login.config==${workspace_loc}\org.ecli pse.riena.security.simpleservices\config\sample_jaas.config
is present in the launch configuration of Riena Sample App Server (the
exception indicates that information provided by this file is missing)?!
By the way on which OS platform you are on?
regards, Frank
> Hi Frank,
> WARNUNG:
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: javax.security.auth.login.LoginException: Für CentralSecurity
> sind keine Anmeldemodule konfiguriert.
> at javax.security.auth.login.LoginContext.init(LoginContext.jav a:256)
> at javax.security.auth.login.LoginContext.<init>(LoginContext.java:403)
> at
> org.eclipse.equinox.internal.security.auth.SecureContext.get LoginContext(SecureContext.java:98)
> at
> org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:46)
> at
> org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:125)
> ... 32 more
> Greetz
> Carsten
> "Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
> news:gq7n3l$b90$1@build.eclipse.org...
>> Hi Carsten,
>> Regards, Frank
>>> Hi,
>>> limits quite early.
>>> understanding or simply using the login support?
>>> Thanks and greetz
>>> Carsten
Re: No authentication service [message #23561 is a reply to message #23394] Wed, 25 March 2009 02:56 Go to previous messageGo to next message
Hey Frank,
the VM-argument you mentioned was existing in the app server launch
configuration...but the specified plugin
"org.eclipse.riena.security.simpleservice" not. After importing it into
workspace it works fine.
But when I take the login mechanism over to my own little sample application
I still get the following error when ILoginContext.login() is performed:
javax.security.auth.login.LoginException: no authentication service
at
org.eclipse.riena.security.common.authentication.RemoteLogin Proxy.login(RemoteLoginProxy.java:79)
at
com.pa.eai.spieker.client.authentication.RemoteLoginModule.l ogin(RemoteLoginModule.java:96)
at
org.eclipse.equinox.security.auth.module.ExtensionLoginModul e.login(ExtensionLoginModule.java:61)
at javax.security.auth.login.LoginContext.invoke(Unknown Source)
at javax.security.auth.login.LoginContext.access$000(Unknown Source)
at javax.security.auth.login.LoginContext$4.run(Unknown Source)
at javax.security.auth.login.LoginContext.invokePriv(Unknown Source)
at javax.security.auth.login.LoginContext.login(Unknown Source)
at
org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:50)
at
com.pa.eai.spieker.client.views.LoginDialogController.checkL ogin(LoginDialogController.java:142)
at
com.pa.eai.spieker.client.views.LoginDialogController.access $0(LoginDialogController.java:125)
at
com.pa.eai.spieker.client.views.LoginDialogController$1.call back(LoginDialogController.java:78)
at
org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.fir eAction(ActionObserver.java:63)
at
org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.wid getSelected(ActionObserver.java:34)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at
org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.doEventLoop(AbstractLoginSplashHandler.jav a:88)
at
org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.init(AbstractLoginSplashHandler.java:67)
at org.eclipse.ui.internal.Workbench$6.run(Workbench.java:605)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbe nch.java:621)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2238)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 09)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:499)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:492)
at
org.eclipse.riena.navigation.ui.swt.application.SwtApplicati on.createView(SwtApplication.java:62)
at
org.eclipse.riena.navigation.ui.application.AbstractApplicat ion.start(AbstractApplication.java:66)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
Are there any documents or tutorials or something like that which can be
used to understand the whole Login mechanism with all the involved
components?
BTW: I
Re: No authentication service [message #23604 is a reply to message #23561] Wed, 25 March 2009 03:06 Go to previous messageGo to next message
BTW: I have switched to Riena 1.1.0M6 now.
"Carsten Spieker" <carsten.spieker@d-velop.de> schrieb im Newsbeitrag
news:gqckib$1sj$1@build.eclipse.org...
> Hey Frank,
> application I still get the following error when ILoginContext.login() is
> performed:
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> components?
> BTW: I
Re: No authentication service [message #23647 is a reply to message #23604] Wed, 25 March 2009 03:39 Go to previous messageGo to next message
Hi Carsten,
The cause of this exception is that the RemoteLoginProxy is missing an
implementation of the IAuthenticationService service. A default
implementation is provided within the plugin
org.eclipse.riena.security.services. Maybe this is missing in your
sample app?
Documentation is available here:
- http://wiki.eclipse.org/Riena_Getting_started_security
- http://wiki.eclipse.org/Riena_Login_support
and of course:
- http://www.eclipse.org/equinox/incubator/security/
HTH
Tschüß,
Stefan
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> BTW: I´m working on Win32.
>> Greetz and Thanks!
>> Carsten
>> news:gq87hj$ps2$1@build.eclipse.org...
>>> Hi Carsten,
>>> argument -Djava.security.auth.login.config==${workspace_loc}\org.ecli pse.riena.security.simpleservices\config\sample_jaas.config
>>> regards, Frank
>>>> Hi Frank,
>>>> WARNUNG:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>>> Hi Carsten,
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> limits quite early.
>>>>>> Thanks and greetz
>>>>>> Carsten
Re: No authentication service [message #23692 is a reply to message #23604] Wed, 25 March 2009 03:46 Go to previous messageGo to next message
Well, after having an additional look at the
org.eclipse.riena.example.client bundle I have found my last error.
I did not register a remote proxy for the IAuthenticationService interface
in my own bundle. This caused the problem that my bundle could not find an
authentication service since no local service was available!
Thank you Fred for your patient help!
Greetz
Carsten
news:gqcl5e$epd$1@build.eclipse.org...
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> BTW: I
Re: No authentication service [message #23735 is a reply to message #23647] Wed, 25 March 2009 03:48 Go to previous message
Hi Stefan,
thanks for your information. I
Re: No authentication service [message #581370 is a reply to message #23154] Mon, 23 March 2009 05:57 Go to previous message
Hi Carsten,
Regards, Frank
> limits quite early.
> Thanks and greetz
> Carsten
Re: No authentication service [message #581389 is a reply to message #23193] Mon, 23 March 2009 06:24 Go to previous message
Hi Frank,
WARNUNG:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: No authentication service [message #581408 is a reply to message #23307] Mon, 23 March 2009 06:24 Go to previous message
I
Re: No authentication service [message #581436 is a reply to message #23307] Mon, 23 March 2009 10:37 Go to previous message
Hi Carsten,
regards, Frank
> Hi Frank,
> WARNUNG:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
> Greetz
> Carsten
>> Hi Carsten,
>> Regards, Frank
>>> Hi,
>>> limits quite early.
>>> Thanks and greetz
>>> Carsten
Re: No authentication service [message #581481 is a reply to message #23394] Wed, 25 March 2009 02:56 Go to previous message
Hey Frank,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
components?
BTW: I
Re: No authentication service [message #581489 is a reply to message #23561] Wed, 25 March 2009 03:06 Go to previous message
> Hey Frank,
> performed:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> components?
> BTW: I
Re: No authentication service [message #581497 is a reply to message #23604] Wed, 25 March 2009 03:39 Go to previous message
Hi Carsten,
sample app?
and of course:
HTH
Tschüß,
Stefan
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> Greetz and Thanks!
>> Carsten
>>> Hi Carsten,
>>> regards, Frank
>>>> Hi Frank,
>>>> WARNUNG:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>>> Hi Carsten,
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> limits quite early.
>>>>>> Thanks and greetz
>>>>>> Carsten
Re: No authentication service [message #581507 is a reply to message #23604] Wed, 25 March 2009 03:46 Go to previous message
Greetz
Carsten
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> BTW: I
Re: No authentication service [message #581525 is a reply to message #23647] Wed, 25 March 2009 03:48 Go to previous message
Hi Stefan,
Previous Topic:One service instance for all clients?
Next Topic:Create Application model depending on login information
Current Time: Sat Jul 19 02:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.07515 seconds
