Home » Eclipse Projects » GEF » Selection bounds !
Selection bounds ! [message #232900] Thu, 12 April 2007 19:55 Go to next message
Originally posted by: kathir.atc.tcs.com
Is it possible to get the rectangle's coordinates when we do a
selection drag on the graphical viewer. What is the best way to get
this. I am trying to use ScalableRootEditPart.getDragTracker(Request req).
BR,
Kathir.
Re: Selection bounds ! [message #232907 is a reply to message #232900] Fri, 13 April 2007 03:32 Go to previous message
Originally posted by: michele.l.evinco.it
You can try with install NonResizableEditPolicy in the editpart of the
figure you want to drag i've installed it as EditPolicy.PRIMARY_DRAG_ROLE.
Then in the getCommand(Request arg0) method of the
NonResizableEditPolicy you can get the location during the drag
operation because the arg0 can be cast to ChangeBoundsRequest.
this is the code that i use in the getCommand method :
public Command getCommand(Request arg0) {
if (arg0 instanceof ChangeBoundsRequest){
AntennaEditPart aep =
((AntennaEditPart)((ChangeBoundsRequest)arg0).getEditParts() .get(0));
((AntennaMapModel)aep.getModel()).setLocation(((ChangeBounds Request)arg0).getLocation());
return super.getCommand(arg0);
I hope that's this can be usefull for you.
Bye
Michele
kathir wrote:
> Is it possible to get the rectangle's coordinates when we do a selection
> drag on the graphical viewer. What is the best way to get this. I am
> BR,
> Kathir.
Previous Topic:Copy, Cut and Paste
Next Topic:Tabbed Properties with multiple tab sets
Current Time: Sat Jul 26 11:38:50 EDT 2025
Powered by FUDForum. Page generated in 0.04977 seconds
