Home » Language IDEs » ServerTools (WTP) » Xml SourceViewer
Xml SourceViewer [message #232798] Mon, 22 June 2009 09:48 Go to next message
Hi all,
I'm trying to create a Dialog containing a TreeView and an XML - Soruce
Viewer. Requirements for the viewer are:
- XML editable
- syntax highlighting
- validation against a XSD-schema
- auto completion (intelli sense) with the same schema
- the schema will be provided in a jar and will always be the same (not
defined in the xml itself)
Re: Xml SourceViewer [message #232805 is a reply to message #232798] Mon, 22 June 2009 09:52 Go to previous messageGo to next message
Franziska Haeger wrote:
> Hi all,
> - XML editable
Sorry wasn't done yet. I already tried to create a SourceViewer providing
my own tag rules, content assist processor and so on. But now my schema is
gettin a lot more complicated and i would like to use already existing
stuff.
It seems that the WTP/ WST XML Editor can do all i need. The only problem
is i don't need a complete editor but only a viewer, since it has to
integrate into a SashForm dialog. Is ther any way to get / use /configure
the StructuedTextViewer to do all I need? Or can I use some ohter classes?
Thanks for your help
Franzi
Re: Xml SourceViewer [message #232813 is a reply to message #232805] Mon, 22 June 2009 11:54 Go to previous messageGo to next message
>> Soruce Viewer. Requirements for the viewer are:
>> - XML editable
>> (not defined in the xml itself)
> providing my own tag rules, content assist processor and so on. But now
> my schema is gettin a lot more complicated and i would like to use
> already existing stuff.
> problem is i don't need a complete editor but only a viewer, since it
> has to integrate into a SashForm dialog. Is ther any way to get / use
> /configure the StructuedTextViewer to do all I need? Or can I use some
> ohter classes?
The
org.eclipse.wst.xml.ui.internal.preferences.XMLTemplatePrefe rencePage
class has to do the same thing, and makes for a fair example. The
only difference in your case would be that IStructuredModel being
shown should come from a real file and be properly managed,
otherwise your Schema may not be found. Keybindings might be an
issue for you, though, as the editor's actions normally connect them
to the operations that need to be run. And then there's the issue
of not having the schema reference within the source itself, but
that's not particular to your usage.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Xml SourceViewer [message #232817 is a reply to message #232813] Mon, 22 June 2009 16:33 Go to previous message
Originally posted by: dcarver.starstandard.org
If the XML has a namespace, you can have your schemas contribute to the
XML Catalog through the extension point. Then when your xml is loaded
into the model, the necessary grammar will be loaded for the namespace
as well.
This should help provide the content assistance you want.
Dave
>>> - XML editable
>> now my schema is gettin a lot more complicated and i would like to use
>> ohter classes?
> The
> class has to do the same thing, and makes for a fair example. The only
> difference in your case would be that IStructuredModel being shown
> should come from a real file and be properly managed, otherwise your
> Schema may not be found. Keybindings might be an issue for you, though,
> as the editor's actions normally connect them to the operations that
> need to be run. And then there's the issue of not having the schema
> reference within the source itself, but that's not particular to your
> usage.
Previous Topic:Reloading context hangs with tomcat
Next Topic:displaying an image on JSP
Current Time: Sat Jul 26 07:58:43 EDT 2025
Powered by FUDForum. Page generated in 0.05032 seconds
