Home » Language IDEs » ServerTools (WTP) » Eclipse competibility
Eclipse competibility [message #232490] Mon, 15 June 2009 10:23 Go to next message
Hello!
How to make Eclipse web application competible with NetBeans and
WebSpheres IDEs?
Is there any type of conversion program?
I need to work for another department, and they don't use Eclipse IDE.
For me it's a crucial problem, because I use a screen reader, and Eclipse
is the only IDE that is fully accessible.
Thanks a lot for any type of help.
Anna
Re: Eclipse competibility [message #232499 is a reply to message #232490] Mon, 15 June 2009 10:40 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
You probably want to go the WAR route and import and export the WAR or
EAR files. More information here:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg10 656.html
Dave
Anna wrote:
> Hello!
> WebSpheres IDEs?
> Eclipse is the only IDE that is fully accessible.
> Anna
Re: Eclipse competibility [message #232572 is a reply to message #232499] Mon, 15 June 2009 22:21 Go to previous messageGo to next message
Hi David!
It's too good to be true.
Eclipse web project has its own file structure, and a specific deployment
descriptor.
Can I expect Netbeans having the same file structure and the same format
of deployment descriptor?
While WAR is on the server, it should be no problem.
But what if someone needs to do a maintenance on my web application, and
he is using Netbeans?
I really appreciate your help.
Anna
Re: Eclipse competibility [message #232587 is a reply to message #232572] Tue, 16 June 2009 05:09 Go to previous message
Anna wrote:
> Hi David!
> deployment descriptor.
Why would Eclipse need a deployment descriptor?
Then use Maven, follow the Maven convention for project layout and use
it to generate the projects for each IDE or use direct Maven IDE support.
Cheers
Philippe
Previous Topic:Setting up JavaScript development environment
Next Topic:How to conrol the stages of the web service in the eclipse web service wizard?
Current Time: Wed Jul 23 14:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.04052 seconds
