Home » Modeling » GMF (Graphical Modeling Framework) » GMF 2.2 - IllegalArgumentException: can't find ID print
GMF 2.2 - IllegalArgumentException: can't find ID print [message #232085] Wed, 03 June 2009 04:03 Go to next message
When I enable printing in .gmfgen, the following lines are generated in
XxxDiagramActionBarContributor.init:
public void init(IActionBars bars, IWorkbenchPage page) {
super.init(bars, page);
// print preview
IMenuManager fileMenu = bars.getMenuManager().findMenuUsingPath(
IWorkbenchActionConstants.M_FILE);
assert fileMenu != null;
IAction printPreviewAction = new RenderedPrintPreviewAction(
new EnhancedPrintActionHelper());
fileMenu.insertBefore("print", printPreviewAction); //$NON-NLS-1$
There does not seem to be a menu-item "print", so the last line results in
an
java.lang.IllegalArgumentException: can't find ID print
Can anyone reproduce this with GMF 2.2?
Is it a known bug, or if not, which Component do I have to choose when I
file a bugzilla?
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232193 is a reply to message #232085] Wed, 03 June 2009 08:16 Go to previous messageGo to next message
Hello Peter,
I cannot reptoduce this problem with current state of GMF 2.2:
was executed without any exceptions.
Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232211 is a reply to message #232193] Wed, 03 June 2009 08:49 Go to previous messageGo to next message
Thanks Alex.
Do you have a print and a printPreview menu-item then?
I'm using Eclipse Galileo RC2 with GMF 2.2.0 RC2 (Build 200905272029).
Regards, Peter
Alex Shatalin schrieb:
> Hello Peter,
> Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232228 is a reply to message #232211] Wed, 03 June 2009 09:04 Go to previous messageGo to next message
Ah, I guess it's because I'm using RCP with required plug-ins only.
Could you try this please?
Thanks!
Peter Lang schrieb:
> Thanks Alex.
> Regards, Peter
>> Hello Peter,
>> Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232244 is a reply to message #232228] Wed, 03 June 2009 10:23 Go to previous messageGo to next message
Hello Peter,
Yes, this can be a reason. I do not have RCP platform set up on my computer,
but I think some plugins are missing in your configuration - it looks natural
to have File/Print action available if you are going to use GMF-generated
printing functionality...
BTW, do you have org.eclipse.gmf.runtime.diagram.ui.providers plugin in RCP
plugins set?
Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232355 is a reply to message #232244] Thu, 04 June 2009 07:57 Go to previous messageGo to next message
Yes, plugin
is under Require-Bundle in my MANIFEST.MF
Even if choose "all workspace and enabled target plug-ins" in my Run
Configuration, the "print"-item is not there.
I'm quite new to eclipse, any hints on how to proceed?
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232445 is a reply to message #232355] Thu, 04 June 2009 11:59 Go to previous messageGo to next message
Hello Peter,
Strange - in this case you should have exactly the same configuration as
I have here and I cannot reproduce this problem...
M.b. you have some problems with the installation of eclipse? Can you see
"print" action enabled in File menu then generated diagram editor is open?
Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232453 is a reply to message #232445] Thu, 04 June 2009 12:14 Go to previous messageGo to next message
Hi Alex,
I did not encounter any other problems with my eclipse installation, its
Galileo Modeling RC2.
In non-RCP it works fine, the "Print..." item is shown. As I said, the
problem is with RCP application, where the "Print..." item seems to be
missing for some reason.
Regards, Peter
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232706 is a reply to message #232453] Fri, 05 June 2009 09:06 Go to previous messageGo to next message
Hello Peter,
Ok. To correct this problem open generated DiagramEditorActionBarAdvisor
and modify fillMenuBar(IMenuManager menu) method:
in first block (File menu creation) add following code:
menuX.add(getAction(ActionFactory.SAVE_ALL.getId()));
/*++ added*/
menuX.add(new Separator());
menuX.add(getAction(ActionFactory.PRINT.getId()));
/*-- added*/
Can you pleaase file a bugzilla request for me describing this problem -
I'll correct it in next bugfix release.
Alex Shatalin
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #232917 is a reply to message #232706] Mon, 08 June 2009 07:42 Go to previous messageGo to next message
Thanks Alex, suggested workaround does the trick.
Filed as
https://bugs.eclipse.org/279445
Hope I got it right, not that experienced in bugzilla-Component-guessing ;)
Re: GMF 2.2 - IllegalArgumentException: can't find ID print [message #713334 is a reply to message #232917] Mon, 08 August 2011 07:09 Go to previous message
When I try to open GMF Editor from menu for the 1st time, I see this error
"llegalArgumentException: can't find ID print"
When I open it for 2nd time, I could open.
Can you please tell why I am not able to open it for 1st time.
Vinay
Previous Topic:PNML & EzPetri
Next Topic:diagram cannot be created inside a project.
Current Time: Fri Jul 25 06:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.14601 seconds
