Home » Eclipse Projects » GEF » MultiPageEditorPart and Actions
MultiPageEditorPart and Actions [message #231972] |
Wed, 21 March 2007 11:09  |
Originally posted by: johan.piculell.ericsson.com
Hello. I have really tried to get my actions to work in my
MultiPageEditorPart for several hours and it drives me crazy. Could
someone give me a hint or point to some decent examples ion this?
My design seems quite common to me, a MultiPageEditorPart consisting of
two editors, one TextEditor and one subclassed GraphicalEditor. I want, as
one example, to have a delete button that deletes text in the TextEditor
(this works) and graphical objects in the GraphicalEditor. But I cannot
even get deletion of graphical objects to work at all. My problem seems to
boil down to that I have no idea about how to get the actions to work in
the GraphicalEditor once it is embedded in the MultiPageEditorPart.
Re: MultiPageEditorPart and Actions [message #232026 is a reply to message #232018] |
Thu, 22 March 2007 07:03   |
Originally posted by: prashanto.chatterjee.softwareag.com
Hi Johan,
I have struggled a lot with Multi-page editors and I guess, since I have a
working application, I can share a few points with you.
1. Specify the following in your multi-page editor's ActionBarContributor:
/* (non-JavaDoc)
* Method declared in AbstractMultiPageEditorActionBarContributor.
public void setActivePage(IEditorPart part) {
IActionBars actionBars = getActionBars();
if (actionBars != null) {
actionBars.clearGlobalActionHandlers();
if(part instanceof GraphicalEditor){
ActionRegistry registry = (ActionRegistry)
part.getAdapter(ActionRegistry.class);
for (int i = 0; i < globalActionKeys.size(); i++) {
String id = (String) globalActionKeys.get(i);
actionBars.setGlobalActionHandler(id, registry.getAction(id));
}else if(part instanceof ITextEditor){
ITextEditor editor = (part instanceof ITextEditor) ? (ITextEditor) part
: null;
ActionFactory.DELETE.getId(),
getTextAction(editor, ITextEditorActionConstants.DELETE));
ActionFactory.UNDO.getId(),
getTextAction(editor, ITextEditorActionConstants.UNDO));
ActionFactory.REDO.getId(),
getTextAction(editor, ITextEditorActionConstants.REDO));
ActionFactory.CUT.getId(),
getTextAction(editor, ITextEditorActionConstants.CUT));
ActionFactory.COPY.getId(),
getTextAction(editor, ITextEditorActionConstants.COPY));
ActionFactory.PASTE.getId(),
getTextAction(editor, ITextEditorActionConstants.PASTE));
ActionFactory.SELECT_ALL.getId(),
getTextAction(editor, ITextEditorActionConstants.SELECT_ALL));
ActionFactory.FIND.getId(),
getTextAction(editor, ITextEditorActionConstants.FIND));
IDEActionFactory.BOOKMARK.getId(),
getTextAction(editor, IDEActionFactory.BOOKMARK.getId()));
//update the action bars
actionBars.updateActionBars();
What you have above is basically standard code; only difference being that
you update actions based on the currently active editor?
If Undo-Redo works for you then you probably have this in your code.
2. Update your selection in the graphical editor as:
/* (non-Javadoc)
* @see
org.eclipse.gef.ui.parts.GraphicalEditor#selectionChanged(or g.eclipse.ui.IWorkbenchPart,
org.eclipse.jface.viewers.ISelection)
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
// If not the active editor, ignore selection changed.
if(getSite().getPage().getActiveEditor() == myMPE &&
myMPE.getActiveEditor() == this){
updateActions(getSelectionActions());
I found the above code while searching the newsgroup. This solved my
problem.
Hope this helps.
Prashanto
"Johan" <johan.piculell@ericsson.com> wrote in message
news:4725aee8a782ccb042e07a115ec1a7dc$1@www.eclipse.org...
>I could also put my question like this:
> For some reason, undo/redo works just as I want it to from a contextmenu
> that I made. Functionality 100% correct in both text editor and graphical
> editor and they don't interfere with each other. But delete does not work
> at all apart from being able to delete from the text with the "del" button
> no matter which editor I'm looking at. How come redo/undo automagically
> works, but I cannot get delete to work at all (it is disabled in my
> graphical editor contextmenu)?
> regards
> /Johan
> Pratik Shah wrote:
>> There are known issues with getting actions to work in a MPEP. Search
>> this newsgroup.
>> news:41dc9efee689ae47c50c7ca5a3b3b3fc$1@www.eclipse.org...
>>> as one example, to have a delete button that deletes text in the
>>> TextEditor (this works) and graphical objects in the GraphicalEditor.
>>> But I cannot even get deletion of graphical objects to work at all. My
>>> problem seems to boil down to that I have no idea about how to get the
>>> actions to work in the GraphicalEditor once it is embedded in the
Re: MultiPageEditorPart and Actions [message #232033 is a reply to message #232026] |
Thu, 22 March 2007 09:04   |
Thanks a ton Prashanto! Now I'm getting at least some progress.
A few more questions then,
I assume "myMPE" is an MultiPageEditorPart, but how can you call
myMPE.getActiveEditor()? This method is protected, what eclipse version
are you running?
Apart from this I have managed to get delete working, but the "del" key
only works in the graphical editor until I display the text editor, then
text editor overrides the key and all "del" key events goes to the text
editor. Guess I need to reset this somewhere when changing back to
graphical editor?
And I still cannot get copy/paste/cut to work in the graphical part, but
this might be out of the scope for this discussion since I probably miss
some fundamental stuff here.
thanks and regards
/Johan
Prashanto Chatterjee wrote:
> Hi Johan,
> /* (non-JavaDoc)
> : null;
> /* (non-Javadoc)
> * @see
> problem.
> Hope this helps.
> Regards,
> Prashanto
>> regards
>> /Johan
>>> this newsgroup.
Re: MultiPageEditorPart and Actions [message #232042 is a reply to message #232033] |
Thu, 22 March 2007 09:35   |
Hi Johan,
About the method being protected; just override it and change the modifier
to public ;-)
About 'del' key not working once you switch to text-editor, I have a post to
the group for which I couldn't get any answer :-(. Maybe we can get cracking
at it now together.
About cut, copy and paste use the following code in your GraphicalEditor
implementation:
/* (non-Javadoc)
* @see org.eclipse.gef.ui.parts.GraphicalEditor#createActions()
protected void createActions() {
super.createActions();
ActionRegistry registry = getActionRegistry();
IAction actionCut;
actionCut = new CutAction(this);
actionCut.setId(ActionFactory.CUT.getId());
registry.registerAction(actionCut);
getSelectionActions().add(actionCut.getId());
IAction actionCopy;
actionCopy = new CopyAction(this);
actionCopy.setId(ActionFactory.COPY.getId());
registry.registerAction(actionCopy);
getSelectionActions().add(actionCopy.getId());
IAction actionPaste;
actionPaste = new PasteAction(this);
actionPaste.setId(ActionFactory.PASTE.getId());
registry.registerAction(actionPaste);
getSelectionActions().add(actionPaste.getId());
You would need to write your own implementation for cut, copy and paste
depending on the model that you use.
Prashanto
news:8b40c4b04da75232776d3260674a1298$1@www.eclipse.org...
> Thanks a ton Prashanto! Now I'm getting at least some progress. A few more
> questions then,
> are you running?
> graphical editor?
> thanks and regards
> /Johan
>> Hi Johan,
>> a working application, I can share a few points with you.
>> /* (non-JavaDoc)
>> part : null;
>> that you update actions based on the currently active editor?
>> /* (non-Javadoc)
>> * @see
>> problem.
>> Hope this helps.
>> Regards,
>> Prashanto
>>> graphical editor and they don't interfere with each other. But delete
>>> does not work at all apart from being able to delete from the text with
>>> the "del" button no matter which editor I'm looking at. How come
>>> redo/undo automagically works, but I cannot get delete to work at all
>>> (it is disabled in my graphical editor contextmenu)?
>>> regards
>>> /Johan
>>>> this newsgroup.
>>>>> of two editors, one TextEditor and one subclassed GraphicalEditor. I
>>>>> want, as one example, to have a delete button that deletes text in the
Re: MultiPageEditorPart and Actions [message #232050 is a reply to message #232042] |
Thu, 22 March 2007 11:00   |
Thank you, thank you, thank you!!
Now I'm back on track, now let's hope someone picks up our silent cry for
help on the key registration thing.
/Johan
> Hi Johan,
> to public ;-)
> at it now together.
> implementation:
> /* (non-Javadoc)
> IAction actionCut;
> IAction actionCopy;
> Regards,
> Prashanto
>> questions then,
>> are you running?
>> graphical editor?
>> thanks and regards
>> /Johan
>>> Hi Johan,
>>> /* (non-JavaDoc)
>>> part : null;
>>> /* (non-Javadoc)
>>> * @see
>>> problem.
>>> Hope this helps.
>>> Regards,
>>> Prashanto
>>>> regards
>>>> /Johan
>>>>> this newsgroup.
Re: MultiPageEditorPart and Actions [message #234214 is a reply to message #232050] |
Tue, 15 May 2007 11:35   |
Originally posted by: rudolf.hornig.gmail.com
put the following code in your GrahicalEditor.configureGrahicalViewer:
String id = ActionFactory.UNDO.getId();
getEditorSite().getKeyBindingService().registerAction(regist ry.getAction(id));
id = ActionFactory.REDO.getId();
id = ActionFactory.DELETE.getId();
this will register the commands belonging ti UNDO/REDO/DELETE to the
graphical editor too. It seems that the text editor steals the key
bindings when activated, and does not restore the original state when
deactivated.
Rudolf
> for help on the key registration thing.
> /Johan
>> Hi Johan,
>> modifier to public ;-)
>> post to the group for which I couldn't get any answer :-(. Maybe we
>> can get cracking at it now together.
>> GraphicalEditor implementation:
>> /* (non-Javadoc)
>> IAction actionCut;
>> IAction actionCopy;
>> paste depending on the model that you use.
>> Regards,
>> Prashanto
>>> version are you running?
>>> key only works in the graphical editor until I display the text
>>> editor, then text editor overrides the key and all "del" key events
>>> goes to the text editor. Guess I need to reset this somewhere when
>>> changing back to graphical editor?
>>> but this might be out of the scope for this discussion since I
>>> probably miss some fundamental stuff here.
>>> thanks and regards
>>> /Johan
>>>> Hi Johan,
>>>> have a working application, I can share a few points with you.
>>>> /* (non-JavaDoc)
>>>> (ITextEditor) part : null;
>>>> being that you update actions based on the currently active editor?
>>>> /* (non-Javadoc)
>>>> * @see
>>>> selection) {
>>>> problem.
>>>> Hope this helps.
>>>> Regards,
>>>> Prashanto
>>>>> contextmenu that I made. Functionality 100% correct in both text
>>>>> editor and graphical editor and they don't interfere with each
>>>>> other. But delete does not work at all apart from being able to
>>>>> delete from the text with the "del" button no matter which editor
>>>>> I'm looking at. How come redo/undo automagically works, but I
>>>>> cannot get delete to work at all (it is disabled in my graphical
>>>>> regards
>>>>> /Johan
>>>>>> Search this newsgroup.
>>>>>>> Could someone give me a hint or point to some decent examples ion
>>>>>>> this?
>>>>>>> consisting of two editors, one TextEditor and one subclassed
>>>>>>> GraphicalEditor. I want, as one example, to have a delete button
>>>>>>> that deletes text in the TextEditor (this works) and graphical
>>>>>>> objects in the GraphicalEditor. But I cannot even get deletion of
>>>>>>> graphical objects to work at all. My problem seems to boil down
Re: MultiPageEditorPart and Actions [message #235529 is a reply to message #234214] |
Wed, 13 June 2007 01:42  |
Thanks Rudolf for replying on this, did not check this thread for a long
time since I thought it was dead more or less.
Anyway, I actually added the single line:
getEditorSite().getKeyBindingService();
in configureGraphicalViewer() the other week after some debugging internal
Eclipse classes and that resolved my problem. Now getKeybindingService is
deprecated so this feels like a temporary workaround for sure.
regards
/Johan
> deactivated.
> Rudolf
>> /Johan
>>> Hi Johan,
>>> /* (non-Javadoc)
>>> IAction actionCut;
>>> IAction actionCopy;
>>> Regards,
>>> Prashanto
>>>> thanks and regards
>>>> /Johan
>>>>> Hi Johan,
>>>>> /* (non-JavaDoc)
>>>>> /* (non-Javadoc)
>>>>> * @see
>>>>> selection) {
>>>>> problem.
>>>>> Hope this helps.
>>>>> Regards,
>>>>> Prashanto
>>>>>> regards
>>>>>> /Johan
>>>>>>>> this?
Current Time: Sun Jul 27 14:34:42 EDT 2025
Powered by FUDForum. Page generated in 0.06019 seconds
