Home » Language IDEs » ServerTools (WTP) » Creating solo tags (i.e. <tag .../>) with WST XML api
Creating solo tags (i.e. <tag .../>) with WST XML api [message #231843] Mon, 25 May 2009 14:00 Go to next message
I have an XML file that I process using the WST API (StructuredDocument,
etc). I use XPath for various parsing jobs and I insert nodes via the
standard DOM API (i.e. node.append(document.createElement(...));).
Is there a way to create an Element that will be saved in the xml file
using it's "short" form (i.e. <a_tag attr1=".."/> instead of <a_tag
attr1=".."></a_tag>.
Thanks in advance,
Cristi.
Re: Creating solo tags (i.e. <tag .../>) with WST XML api [message #231864 is a reply to message #231843] Tue, 26 May 2009 10:22 Go to previous messageGo to next message
Only by using IDOMElement.setEmptyTag(true) before inserting it into
the Document. I don't know of a DOM API way of controlling it
before you transform it into a stream, and even then it's a
transformer-specific parameter.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Creating solo tags (i.e. <tag .../>) with WST XML api [message #231893 is a reply to message #231864] Tue, 26 May 2009 16:34 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
This isn't a DOM issue, it's a serialization issue. So this is
something as Nintin says has to be handled by the IDOMElement extension
to the w3c.org.Element interface.
In general, if you don't have a Text node or another Child Node, then
most serializers will serialize it out as <tag/>, otherwise they may
serialize it as <tag></tag>, depending on the serializer.
Dave
Nitin Dahyabhai wrote:
>> (StructuredDocument, etc). I use XPath for various parsing jobs and I
>> insert nodes via the standard DOM API (i.e.
> Only by using IDOMElement.setEmptyTag(true) before inserting it into the
> Document. I don't know of a DOM API way of controlling it before you
> transform it into a stream, and even then it's a transformer-specific
> parameter.
Re: Creating solo tags (i.e. <tag .../>) with WST XML api [message #231909 is a reply to message #231893] Wed, 27 May 2009 06:27 Go to previous message
Dear Nitin,
>> parameter.
It worked. Thanks a lot!
Dear David,
This is not the case of the WST serializer.
Best regards and thanks again for your answers.
Cristi.
Previous Topic:CSS displaying in JavaDoc
Next Topic:runtimePath variable in Component Core
Current Time: Thu Jul 24 22:54:38 EDT 2025
Powered by FUDForum. Page generated in 0.43079 seconds
